How do I solve a series wiring problem with two resistances and a 12-V battery?
  • Thread starter Thread starter runfast220
    Series Wiring
The problem involves two resistances, R1 and R2, connected in series with a 12-V battery. The current changes when one resistor is removed, prompting the original poster to seek assistance in determining the values of R1 and R2 based on the observed current changes.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need for multiple equations to solve for the unknowns, suggesting relationships between voltage, current, and resistance. There is a focus on substituting known values into equations but uncertainty remains about how to isolate the variables.
Several participants have proposed equations based on the relationships between voltage, current, and resistance. There is ongoing exploration of how to manipulate these equations to find the unknowns, with some participants expressing confusion about the number of unknowns and how to proceed without knowing the current.
Participants note that the problem constraints include the fixed voltage of 12 V and the changes in current when resistors are removed. There is also a mention of potential misinterpretation of the problem statement, which may affect the approach taken.
runfast220
Two resistances R1 and R2, are connected in a series across a 12-V battery. The current increases by .20 A when R2 is removed, leaving R1 connected across the battery. However the current increases by just .10 A when R1 is removed, leaving R2 connected across the battery. Find(a)R1 and (b) R2.
V=12v
R1+R2=Rs V1+V2=V
I=V/R
I+20= V/R1 I+10= V/R2
I believe the two equations above would give me my answers but I'm stumped on how to go about finding the unknowns. I know V=12 but I can't figure out how find the current or resistances.
Can somebody point me in the right direction?
Looks like you need 3 equations for the 3 unknowns.
V = I*R looks like it yields all 3.
(R1 + R2) = V/I
R1 = V/(I + .1)
R2 = V/(I + .2)
Then solve right?
Using the three equations makes sense, but I can't figure out how to find the unknowns. All I know is V, and I need to know I to be able able to find R1 and R2.
my idea was to subsitute I=V/R into the equations and then try to solve for R1 and R2.
so R1= V/(V/Rs)+.1
but I don't know what Rs is either.
so R1= V/(V/Rs)+.1
Don't use Rs as that is by definition R1 + R2.
Otherwise, if you must, then you have 4 equations, with the 4th unknown now Rs where Rs = R1 + R2
ok but if I plug R1 + R2 into the equation I still have too many unknowns.
R1=V/(V/R1 + R2) +.1
In that equation I still don't know how to find R1 or R2.
Disregard; I misread the problem question.
You only have 3 unknowns : I, R1, R2, because V is 12.
(R1 + R2) = V/I
R1 = V/(I + .1)
R2 = V/(I + .2)
Rewriting you have
12 = I*R1 + .1R1
12 = I*R2 + .2R2
12 = I*R1 + I*R2
Adding equation 1 to equation 2 and subtracting equation 3 yields
12 = .1R1 + .2R2 or, ...
120 = R1 + 2R2
Surely it's down hill from there.
Here is my attempt at the solution:
(R1 + R2) = V/I R1 = V/(I + .1) R2 = V/(I + .2)
SO:
(V/(I+.1)) + (V/(I+.2))=V/I
(12/(I+.1)) + (12/(I+.2))= 12/I
24I^2 + 3.6I = 12I^2 + 3.6I +.24
12I^2 = .24
I=.02 A
R1 = V/(I+.1) = 12/(.02+.1) = 100 OHMS
R2 = V/(I+.2) = 12/(.02+.2) = 54.5 OHMS
runfast220 said:
here is my attempt at the solution:
(r1 + r2) = v/i r1 = v/(i + .1) r2 = v/(i + .2)
so:
(v/(i+.1)) + (v/(i+.2))=v/i
(12/(i+.1)) + (12/(i+.2))= 12/i
24i^2 + 3.6i = 12i^2 + 3.6i +.24
12i^2 = .24
i=.02 a
i = (√2)/10
I = .14 A
R1 = 50 ohms R2 = 35.3 ohms
Thank you for all your help.
  • · Replies 24 ·
  • · Replies 18 ·
