Resolving Power: Abbe vs. Rayleigh Criterion
  • Context: Graduate
  • Thread starter Thread starter KFC
    Power
The discussion centers on the resolving power of lenses and the relationship between diffraction and resolution, specifically comparing the Abbe criterion and the Rayleigh criterion. Participants explore the mathematical formulations associated with these criteria and their implications in optics.
  • One participant presents the Abbe criterion formula, \(\sin\alpha = \lambda / (2 n D)\), and questions the origin of the factor 1.22 in the Rayleigh criterion formula, \(\sin\alpha = 1.22 \lambda / D\).
  • Another participant suggests that the difference in the formulas may arise from using a standard value for the refractive index, n, which they propose could be around 1.6 for common lens materials.
  • A participant seeks clarification on whether n refers to the refractive index of the lens, the medium, or both.
  • One reply explains that the Rayleigh criterion relates to the minimum size of an imaged point and mentions the Airy disk, noting that the factor 1.22 corresponds to the full-width half-max of the Airy function.
  • Another participant adds that the Rayleigh criterion was derived based on telescopes observing distant stars and highlights that "resolving power" is not well-defined in general.
  • There is a discussion about the approximation \(\sin(a) \approx a\) being related to the paraxial approximation used in geometrical optics, rather than being part of Rayleigh's criteria.
  • One participant mentions that the Airy criterion is an arbitrary limit chosen by Airy, which relates to distinguishing two stars by eye, and notes that information exists in the image below this limit.
  • Another participant questions the historical attribution of the Airy and Rayleigh criteria, seeking to clarify who first proposed the criterion associated with the factor 1.22.
  • A later reply corrects the spelling of Rayleigh and clarifies that the distribution of light is an Airy function, but the limit is attributed to Rayleigh.
Participants express various viewpoints regarding the relationship between the Abbe and Rayleigh criteria, with some suggesting they are related while others highlight differences. The discussion remains unresolved regarding the historical attribution of the criteria and the implications of the formulas.
Participants note that the definitions and interpretations of resolving power may vary, and there are nuances in the derivations of the criteria that are not fully explored in the discussion.
KFC
Hi there,
I am reading some material on resolving power of lens and diffraction effect. As I known, the first on who consider the relation of diffraction and resolution is E. Abbe in 1873, who gave the following relation
[tex]\sin\alpha = \lambda / (2 n D)[/tex]
where n is the index of refracion and D is aperature diameter. However, in the text of optics, I found something similar but different
[tex]\sin\alpha = 1.22 \lambda / D[/tex]
so what's the difference between these? How does the 1.22 come from?
BTW, later in the text, I also read a criterion call Rayleigh's criterion which just approximate [tex]\sin\alpha[/tex] as [tex]\alpha[/tex] (I guess), so does Rayleigh's criterion only an approximation of Abbe's expression?
Maybe they use a standard value for n and don't bother further. n = 1.6... reasonable lens material.
I forgot ... does the n stand for the refreactive index of the lens or the medium or both?
KFC said:
Hi there,
The second formula relates to the minimum size of an imaged point, and is called the Rayleigh criterion. That is, a point object will image to an Airy disk (insert caveats here), and the factor 1.22 is the full-width half-max of the Airy function (or sombrero function, or J_0(ax)/ax). This means two points have to be separated by a certain distance to be resolved as two points. The Rayleigh criterion was derived based on telescopes observing distant stars.
The first formula looks like the Abbe criterion, and is also related to the minimum resolving power of a lens. There are some slight nuances between the two (the Abbe criteria was derived based on Bragg scattering), but the bottom line to remember is that "resolving power" is not well-defined in general.
The approximation sin(a) ~ a is not Rayleigh's criteria, it's the paraxial approximation, and is used in geometrical optics.
Does that help?
It's also worth knowing that the Airy criterion (the 1.22) is only an arbitrary limit picked by Airy - it's roughly the point at which you can distinguish two stars by eye. There is information in the image below this limit
The n is the general case but it is of the medium between the lens and the object which is almost always either space (n=1) or air (n=1 and a bit) so it gets forgotten about.
Thank you all of you. Now it is clear.
So ... you call the criterion (the 1.22) as Airy criterion? I wonder who, Airy or Rayleigh, is the first one who propose that criterion? Do you know which paper first present this idea?
Sorry should be the Raleigh criterion (another British astronomer around the same time) the distribution of the light is an Airy function (invented by Airy before Raleigh was born) but the limit is due to Raleigh
10K
