Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > General Engineering
Reply
image Help Required - Beam Curve Measurement Share It Thread Tools Search this Thread image
Old Nov1-09, 07:24 AM                  #1
Dafty
Dafty is Offline:
Hi wonder if there is anyone out there who can help me !!
Whats the easiest formula for working out the measurement of curveture in a simply supported structural horrizontal monorail beam.
Any help most appreciated. - thanks
Old Nov3-09, 01:48 PM                  #2
Scudley
Scudley is Offline:
Re: Help Required - Beam Curve Measurement
Do you want to know how to measure the actual curvature of an existing structure or predict the curve of a planned structure?
If you want to predict: If the beam is straight and and a steel section, it is not that complicated, it gets more complicated if the monorail track is concrete. It get very complicated if the beam curves. There are mathematics that allow you to calculate the curve of the unloaded beam as well as under load.
Old Nov3-09, 06:56 PM                  #3
jamesd2008
jamesd2008 is Offline:
Don't know if this is any help but here is the engineers bending theory equation
M/I=sigma/y=E/R
were
M=moment
I=second moment of area
Sigma=stress
y=neutral axis
E=youngs modulus
R=The radius of curviture of the beam
Old Nov4-09, 05:05 AM                  #4
Dafty
Dafty is Offline:
Thanks for yor reply Scudley - i need to take curveture measurements from an existing horizontal simply supported monorail beam - whats the easiest way of measuring and working out radius curve - eg 60 - 90 degrees.
Thanks in advance Scudley - Iam the dafty here
Old Nov4-09, 05:07 AM                  #5
Dafty
Dafty is Offline:
M/I=sigma/y=E/R
were
M=moment
Sigma=stress
y=neutral axis
E=youngs modulus
Thanks for your support reply James - i need to work out curviture of an existing beam
Old Nov4-09, 07:57 AM                  #6
FredGarvin
FredGarvin's Avatar
Engineer Guru 2008
FredGarvin is Offline:
Recognitions:
PF Contributor PF Contributor
What size is this beam? Are we talking something that is very large or just a lab experiment?
Old Nov4-09, 09:33 AM                  #7
Dafty
Dafty is Offline:
Fred this beam is currently in situ - runs approx 60ft long simply supported via vertical welded supports and constructed from standard American stardard I beam 4 " Wide x 8 " High has one curve of which iam trying to determine easiest way to measure and work out radius curve.
Thanks
Old Nov4-09, 12:28 PM                  #8
FredGarvin
FredGarvin's Avatar
Engineer Guru 2008
Recognitions:
With something that long, have you looked into the possibility of a transit used by surveyors? They can be quite accurate.
Old Nov10-09, 08:28 AM                  #9
Dafty
Dafty is Offline:
Hey iam stuck here !! have only got plum lines and a measuring tape, does anyone know the answer to my query - beam is approx 60ft long and has one curve - looks like 90 degree although again i,am looking for the easiest formula to determine.
Thanks
Old Nov11-09, 03:19 AM       Last edited by CarlAK; Nov11-09 at 03:19 AM.. Reason: typos            #10
CarlAK
CarlAK is Offline:
Measure the length along the curve (beam), the chord (straight line distance from beginning to end of the curve, and the maximum distance between the straight line and the curve. Actually you only need any 2 of these measurements. Now draw a sketch of an arc, center of arc, radius, chord, angle of arc, and use some trigonometry.
image image
Reply
Tags
curve measurement
Thread Tools
Similar Threads for: Help Required - Beam Curve Measurement
Thread Thread Starter Forum Replies Last Post
C-V curve measurement ssanagal Atomic, Solid State, Comp. Physics 1 Sep16-08 07:58 PM
Do you calculate the amount of load a beam can take based on when the beam cracks? perfectchaos180 Materials & Chemical Engineering 6 Feb7-08 09:00 AM
Beam-break sensors for ignition delay measurement saguntripathi Mechanical Engineering 3 Feb5-08 06:16 PM
Required frictional force for a car to keep it from sliding off a curve. galuda Introductory Physics 4 Nov12-07 12:30 AM
Force required to lift beam pityocamptes Mechanical Engineering 2 Aug17-06 02:35 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
