Rotating bodies, Car around a corner
The discussion revolves around two physics problems: one involving the acceleration of a car turning a corner while braking, and the other concerning the moment of inertia of a square sheet pivoted about an axis. The first problem is situated within the context of rotational dynamics and kinematics, while the second pertains to the principles of rotational motion and the parallel axis theorem.
  • Mixed
  • Participants explore the calculation of tangential and centripetal acceleration for the car problem, questioning the correctness of their methods and assumptions. Some express confusion regarding the distinction between different components of acceleration and the application of relevant formulas. In the second problem, there is a request for hints and clarification on the parallel axis theorem.
There is an ongoing exploration of the first problem, with participants attempting to clarify their calculations and understanding of acceleration components. Some guidance has been provided regarding the need to consider both tangential and centripetal acceleration. The second problem remains less developed, with participants seeking foundational understanding and hints to progress.
Some participants indicate a lack of familiarity with certain concepts, such as the parallel axis theorem, which may be affecting their ability to engage with the second problem. Additionally, there are references to missing diagrams that are essential for understanding the second question.
Sakura22
A car turns a corner with a radius of curvature of 11.1 m while braking to reduce its speed. If the brakes generate an angular deceleration of 0.5 rad/s2 what is the magnitude of the acceleration of the car half way through the corner when the car's linear speed is 9.6 m/s?
Tangential velocity= wr
arc lenth=r(theta)
equation: w^2=(w0)^2 + 2 (angular acceleration)(theta)
What I did was I converted the linear speed into angular speed by using the first formula, then I found the time, and halved it, but the answer I'm getting for acceleration HALF WAY is not correct, I have no clue what I did wrong.
Please help
A square sheet with a uniform density and total mass m is pivoted about an axis A in one corner of the sheet and perpendicular to the plane of the sheet as shown below. If the moment of inertia of the sheet about this axis is \frac{8}{3}ma^2, what is the sheet's moment of inertia about a parallel axis, B, at the mid-point of one of its sides?
http://moodle.phys.uAlberta.ca/file.php/2/questions/images/rotation/rotation-parallelaxis.png
Welcome to PF, Sakura.
I can't tell what you did wrong - you haven't shown your work!
Hey! Sorry about that..but here it goes..
a(tangential) = wr
= 11.1m x 0.5 rad/s^2
=5.55 m/s^2
Then I used the formula
v=v0 + at
v= at
v= 5.55 m/s^2 x t
t= 9.6 m/s^2 / 5.55 m/s^2
t= 1.73
t/2 because it asks for the deceleration half way through the curve
Then I used the v=at again with half the time = 0.865 ..
then v=at
a=v/t --> 9.6 m/s / 0.865 seconds
= 11.098 m/s^2
Please tell me what I did wrong..thanks again for your help.
For the 2nd question I have no clue, so please give some hints, so I can get something going in my head.
Sakura22 said:
a(tangential) = wr
=5.55 m/s^2
You found the tangential component of the acceleration. So far, so good!
v=v0 + at
v= at
v= 5.55 m/s^2 x t
t= 1.73
then v=at
= 11.098 m/s^2
Not sure what you're doing here. You need the radial component of the acceleration. Note that they tell you the speed, so no need for any kinematics. (Hint: The motion is circular.)
What is the radial component? I don't understand. Is that the centripetal acceleration?
Eactly! (The "radial" direction is along the radius, thus perpendicular to the tangential direction.)
I am not sure about the formula BUT..here is what I think should work..please tell me if its correct a(centripetal)= w^2 r
Also, please give me some hints about the second problem, thanks
That's perfectly correct. You can also use a different formula for centripetal acceleration (equivalent of course) expressed in terms of tangential speed v, instead of ω.
The diagram is not viewable. Hint: Make use of the parallel axis theorem.
Try posting the diagram to a publically accessible image hosting site.
I missed the class on The parallel axis theorem, and now I looked it on the wikipedia website, I don't understand it.
Your textbook should describe it. Also read this: http://hyperphysics.phy-astr.gsu.edu/hbase/parax.html"
18K
