Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Atomic, Solid State, Comp. Physics
Reply
image How to differentiate conductors and semiconductors? Share It Thread Tools Search this Thread image
Old Nov15-09, 10:16 PM                  #1
y4ku24
y4ku24 is Offline:
Hello everyone,
I have a (simple?) question: How do you differentiate a material to be a conductor or a semiconductor? It is just only by examining the material's electrical resistivity/conductivity whether it is low or high? Because I have heard that even some metallic conductors have high resistivity.
For you information, I am currently working with a material called metallic glass, with a compound of Zr55Ni5Al10Cu30. It has high resistivity at room temperature and as heat treatment is applied the resistivity steadily decreases. But up to a certain point, it showed an abrupt decline (due to crystallization).
My point is, is the steady decline due to heat treatment be sufficient evident enough to conclude that the material is a semiconductor? In other words, does this behavior resides ONLY in semiconductors, and no conductors behave the same?
Or is there any other experiment(s) that I can do to justify whether the material is a semiconductor or not?
Thank you in advance.
y4ku24
Old Nov18-09, 01:07 PM                  #2
Buckethead
Buckethead is Offline:
Recognitions:
PF Contributor PF Contributor
Re: How to differentiate conductors and semiconductors?
y4ku24
By definition a semiconductor is a substance that has more resistance that a conductor and less than an insulator, but of course common resistors have this property as well, so that's not the complete answer. Since the common usage of the word semiconductor is used to refer to a substance that can potentially create an active electronic component, I would say that if you can dope it and make a diode out of it, then you could classify it as a semiconductor. That's not to say however that if you can't do this you still don't have a semiconductor, but if you can, I'd say you could. This is not a completely qualified opinion but hopefully it's a starting point.
Old Y, 12:10 AM                  #3
y4ku24
y4ku24 is Offline:
Thank you Buckethead for the lead.
Old Y, 04:50 AM                  #4
DrDu
DrDu is Offline:
In a metal, the single particle excitation spectrum has a discontinuity; the fermi level, In a semiconductor I think it doesn't.
image image
Reply
Tags
conductor, heat treatment, high resistivity, metallic glass, semiconductor
Thread Tools
Similar Threads for: How to differentiate conductors and semiconductors?
Thread Thread Starter Forum Replies Last Post
How to differentiate conductors and semiconductors? y4ku24 Materials & Chemical Engineering 9 Nov17-09 10:43 PM
Semiconductors yellowputty Advanced Physics 0 Nov14-08 04:00 PM
best semiconductors Rothiemurchus Atomic, Solid State, Comp. Physics 1 Apr9-07 07:49 PM
Semiconductors!! Arjumand General Physics 0 Apr20-05 11:02 AM
semiconductors islandguy General Physics 2 May11-04 09:33 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
