Quark Mass and Size: Is There Any Data?
  • Context: Graduate
  • Thread starter Thread starter cbd1
    Data Mass Quark
The discussion centers on the mass and size of quarks, exploring whether there is any empirical data regarding their dimensions. Participants examine theoretical perspectives on the size of quarks and electrons, the implications of quantum mechanics, and the challenges in measuring such properties.
  • Some participants suggest that while the masses of the six quarks are known, their sizes remain uncertain, with one proposing that heavier quarks might be larger.
  • There is a belief among some that quarks and electrons are similar in size, although this is characterized as a weak theoretical argument.
  • One participant asserts that electrons are point particles with "zero size," and posits that quarks may also be point-like, complicating the definition of size due to the absence of free quarks.
  • Another participant mentions that proposed sizes for quarks and electrons are vague due to the probabilistic nature of quantum mechanics, suggesting that estimates could be made using degenerate matter's density.
  • One reply challenges the mixing of classical and quantum mechanics, stating that what can be measured is the charge density distribution rather than a physical size.
  • Some participants note that current experimental evidence treats elementary particles as point-like, with no definitive size established, while also mentioning ongoing searches for potential substructure in quarks and leptons.
  • There is a discussion about string theory as a framework for considering non-zero sizes for elementary particles, with some uncertainty expressed about the feasibility of defining size for elementary fermions.
  • One participant emphasizes that the size of hadrons is attributed to their compositeness rather than the size of the constituent fermions.
  • Another participant raises the concept of defining the size of hadrons in terms of charge distributions and form factors, highlighting the complexities involved in such definitions.
Participants express a range of views on the size of quarks and electrons, with no consensus reached on whether these particles can be said to have a defined size. The discussion reflects multiple competing perspectives and uncertainties regarding the implications of quantum mechanics and theoretical frameworks.
Participants note limitations in measuring particle sizes due to the probabilistic nature of quantum mechanics and the challenges in reconciling classical and quantum descriptions. The discussion also highlights the dependence on theoretical models and the unresolved nature of certain mathematical aspects.
cbd1
I know that we (believe) we have found the mass of the 6 quarks. But, I have not been able to find anywhere if we have any idea of their various sizes. I would gesture that the heavier quarks would be larger. Does anyone know if there is any data on this?
I think we have thought quarks and electrons are about the same size, but it seems to me this is mostly weak theoretical argument..
Electrons are point particles, I guess you could say they have "zero size".
As far as I know the same is true for quarks, although the concept of size is even less well defined since there is no such thing as a free quark.
That sounds pretty accurate to me, there are proposed sizes for electrons and quarks but the nature of the quantum world makes such measurements somewhat vague since each particle is a wave of probability.
Couldn't you make a fairly accurate estimate using degenerate matter's maximum density to approximate their minimum size since they are on the edge of failing the pauli exclusion principle? I guess you could really only get the minimum size of neutrons, but when matter is that dense does the physical size of the neutron also get compressed?
No you can't, you are trying to mix classical and quantum mechanics here, finite extended objects are not compatible with QM. What you can measure is the charge density distrubution (aka the Form factor) and as far as we know, the charge density function for electrons is a delta function.
All "elementary particles" (quarks, leptons, gauge bosons) are point particles (with "zero size") as far as we can determine experimentally. [Edit to add that the standard model and its usual extensions treat elementary particles as exactly pointlike, in agreement with experiment.] There have been (and will be at the LHC) interesting searches for quark and lepton substructure, which would be the first sign that they are actually composite (non-elementary) objects with non-zero size.
So far, the tightest upper bound on the electron radius that I'm aware of is [tex]r_e < 10^{-22}[/tex] meters, from http://www.iop.org/EJ/abstract/1402-4896/1988/T22/016/. For quarks, high-energy collider experiments have probed down to [tex]r \sim 10^{-18}[/tex] meters (which the LHC will improve), at which distance quarks and leptons still look pointlike. See also this thread.
If you try to make models where elementary particles have non-zero size, you generally enter the Realm of String Theory.
Or not. I am not sure if we have some calculation for the size of a elementary string in each of the four sectors (RR, RNS etc). I believe that early calculations by Susskind hit some kind of problem.
Besides, are we sure that it is possible to get a "size" for elementary fermions? Yes, protons and neutrons have a size, but it comes from the boson glue, not from the fermions. There is some kind of paradoxic clash between having a size and not having classical limit.
The size of hadrons comes from compositeness, plain and simple. I don't see any need to worry about spin & statistics here.
I am not a string theorist, so please correct my misconceptions. I was merely parroting the popular wisdom that in string theory "the fundamental constituents of reality are strings of the Planck length (about [tex]10^{-33}[/tex] cm)", which I just copied-and-pasted from http://en.wikipedia.org/wiki/Superstring_theory#Basic_idea".
define size of a Hadron...
Form factors are observables. They can be linked, without any approximation, to the distributions of charges in the transverse plane when the hadron is on the light-cone. The "no approximation" comes from the galilean subgroup of transverse boosts (please request references if you want). The Sachs formalism, relying on non-relativistic approximation, is in the hadron rest frame. The distributions in the rest frame and on the light cone are not supposed to be the same anyway. There are attempts to make it rigorous in the rest frame, but it's not necessarily very useful.
Sorry I am not string theorist neither :frown: I had expected the form factor for scattering of a probe string against a "R-NS" fundamental state to be calculated somewhere in the textbooks and then its graph plotted and a size of the order of the square root of the string tension to be shown. Very dialectical, I would hope. Perhaps too trivial for a string theory textbook?
humanino's response is probably best, but if you're after something more qualitative and hand-wavy, think of the volume within which the hadron's (valence) quarks are confined. Quantum mechanics makes this fuzzy.
In my own field of lattice QCD, we tend to use the Compton wavelength to quantify the "size" of mesons, [tex]r_C \sim 1 / m_C[/tex] in units where [tex]c = \hbar = 1[/tex].
  • · Replies 46 ·
  • · Replies 17 ·
  • · Replies 20 ·
