Quick way of raising matrices to indicies
  • Thread starter Thread starter thomas49th
    Matrices
The discussion revolves around finding a specific term in the matrix A(x) raised to a power, specifically A^5(x) for x = 18°. The matrix is defined as a rotation matrix involving trigonometric functions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore methods to compute higher powers of the matrix without direct multiplication, considering patterns and trigonometric identities. Some suggest finding A^2 first and observing any emerging patterns, while others express confusion about specific entries in their calculations.
Participants are actively discussing various approaches to compute A^5, with some suggesting the use of trigonometric identities and others questioning the accuracy of their previous calculations. There is recognition of a potential pattern, but no consensus has been reached on the exact method to derive A^5.
Some participants note the relationship between the matrix and rotation angles, while others express frustration over missing a straightforward pattern or identity that could simplify their calculations. The discussion reflects a mix of attempts to clarify definitions and assumptions regarding matrix powers.
thomas49th
A given matrix [tex] A(x) =\left | \begin{array}{cc} cos(x)&sin(x)\\ -sin(x)&cos(x) \end{array}\right | [/tex]
Find the term in the first row and second column A^{5}(x) when x = 18°
Instead of multiplying the matrix again and again by itself in a iterative procedure is there any quicker way?
Thanks
Thomas
For this particular matrix, why don't you find A^2 for general x, and use your knowledge of trigonometric identities...then you may see a pattern.
A^2 = [ cos2x 2cosxsinx
-2cosxsinx cos2x ]
what I want is cos²x + sin²x so i get one, but what I got at the mooment doesn't seem to get me any where :( I wanted somthing like if the power is odd then you get -1 and even 1 in the first element, but can't see that happening :(
Since 2 cos x sin x = sin 2x, a pattern is emerging, just not the one you thought.
aha so the formula for that specific elemnt is [tex]\sin 2^{n-1}x[/tex]
Correct?
Thanks
Tom
Maybe for [tex]A^{2^{n-1}}[/tex] but that doesn't help with [tex]A^5[/tex].
In other words, multiply [tex]A^2[/tex] by [tex]A[/tex], not by [tex]A^2[/tex], to find [tex]A^3[/tex].
(I know you know this -- your brain just went into overdrive and caused a blunder.)
ahhh I am getting
A^3
[tex] <br /> A(x) =\left | \begin{array}{cc} cos(x)cos(2x)-sin(x)sin(2x)& cos(x)cos(2x) +sin(x)sin(2x)\\ -cos(x)cos(2x)-sin(x)sin(2x)& cos(x)cos(2x)-sin(x)sin(2x) \end{array}\right | <br /> [/tex]
where is this pattern? I can see they're all similar
I might as well just expand to A^5 now :(
What is the trig identity for cos(A+B)? For sin(A+B)?
Also, your A^3 has two incorrect entries.
cos(A+B) = cosACosB - sinAsinB
sin(A+B) = sinAcosB + cosAsinB
right?
I can see how we can use RCos(x+a) for A^3 but I want to get A^5. There must be some relationship!
Which of the terms are incorrect in A^3btw for A^2 i got [cos2x sin2x
-sin2x cos2x]
Thanks
Thomas
I am sure BB means something much faster, but whenever I hear about anything raised to large integer power I think in terms of powers of 2, in this case it means A5=A*(A2)2 - that means just three multiplications instead of 5. The larger the exponent, the more you save.
-sin2x cos2x]
Can't you guess the correct pattern just from this! :smile:
Additional hint: A(x) corresponds to rotation through an angle of x.
I can see A^2 = sin2x
but I cannot see why that is so argghh! must be something really simple!
A=
[cos x sin x
-sin x cos x]
A^2=
[cos 2x sin 2x
-sin 2x cos 2x]
A^3=
what would you guess! Yes, it's very simple, sorry. :smile:
Now compute A^3, and if it doesn't match your guess, then your computation is probably wrong, not your guess!
You might also note that
[tex]\begin{bmatrix}cos(\theta) & sin(\theta) \\ -sin(\theta) & sin(\theta)\end{bmatrix}[/tex]
corresponds to a rotation by -x degrees. Multiplying it by itself 5 times is the same as rotating by -5x degrees. In this case that is -5(18)= -90 degrees. The result is suprisingly simple.
yeah I didn't think of that!
still need to expand it manually to see the maths but bed time now
Thanks for the help!
Thomas
  • · Replies 46 ·
9K
