Crossing the Event Horizon of a Black Hole
The discussion centers on the behavior of particles crossing the event horizon of a black hole, particularly regarding their speed as they approach and cross this boundary. Participants explore concepts from general relativity, including geodesics, observer frames, and the implications of Hawking radiation. The conversation includes theoretical considerations and mathematical derivations related to the velocities of infalling particles.
  • Some participants assert that a particle following a geodesic towards a black hole reaches the speed of light when crossing the event horizon, regardless of its initial position.
  • Others challenge this claim, arguing that the statement lacks context regarding reference frames and observer measurements, suggesting that it may not be universally applicable.
  • One participant references specific pages in "Exploring Black Holes" to support their view, noting that shell observers would measure the particle's speed differently depending on its starting point.
  • Mathematical derivations are presented, with participants calculating velocities of infalling particles and discussing discrepancies in their results.
  • Some participants introduce the concept of different types of infalling objects (drip, rain, hail) and their velocities as observed from various frames, indicating that all types reach the speed of light at the event horizon.
  • There is a discussion about the difference between what an infalling observer experiences versus what distant observers measure, with references to the bookkeeper metric.
  • One participant suggests that the answer may depend on careful handling of limits and quantum mechanical uncertainties related to particles emitted near the event horizon.
Participants express differing views on the behavior of particles at the event horizon, with no consensus reached. Some agree on the theoretical framework while others dispute specific claims and interpretations of the text.
Discussions include limitations related to the definitions of velocity in different reference frames and the assumptions underlying the mathematical models presented. The complexity of observer-dependent measurements and the implications of quantum mechanics are also noted.
DiamondGeezer
Reading "Exploring Black Holes" I find that a particle following a geodesic towards a black hole always reaches the speed of light c when crossing the "event horizon" regardless of the reduced circumference that the particle begins at (1mm or 10 million light years).
This would also apparently happen to a particle which has appeared out of the "quantum foam" where its anti-particle manages to escape (the basis of the so-called "Hawking Radiation")
Is this correct? (I have a supplementary question if this is so)
Where in the book do you find this claim? On its face, it seems patently false, and also there is no reference frame for the velocity given. Do you have more info? I have the book right here for reference.
It seems reasonable to me, if you take it as a statement about the Doppler shift of light emitted from the horizon and observed at infinity. The observer at infinity can take the infinite Doppler shift as indicating motion of the source at c.
From "Exploring Black Holes" by Taylor and Wheeler, as I said in the original post. Pages 3-14 onwards talk about the speed of the "particle" as approaching the speed of light as measured by shell observers outside of the event horizon and at the bottom of page 3-15 we find
At the reduced Circumference r=8M or four times the Schwarzschild radius (2M) the particle falling from rest at infinity is moving inward at half the speef of light, as witnessed by shell observers. As the particle crosses the event horizon at r=2M, nearby shell observers record it as moving at the speed of light...​
I have the book in front of me. You say that the book's statement holds "regardless of the reduced circumference that the particle begins at (1mm or 10 million light years)," but I don't see anywhere in the book that it says that. Lots of the equations have labels like "[24. from rest at [itex]r=\infty[/itex]]." This part of the book also goes into excruciating detail about different observers and their measuring procedures. Your statement that "a particle following a geodesic towards a black hole always reaches the speed of light" is expressed in a way that doesn't take these distinctions into account. I think the observer they refer to as the "shell observer" won't agree that all particles zip by at c, no matter where they're released from.
Hrm.. they derive:
[tex]v= -\sqrt{\frac{2M}{r}}[/tex]
But I did a quick derivation and keep getting,
[tex]\frac{dr}{d \tau} = -\sqrt{\frac{2M}{r}} \left(1-\frac{2M}{r}\right)^{1/2}[/tex]
For the infalling particle (assumed stationary at infinity), I get,
[tex]u^\alpha = \left(\left(1-\frac{2M}{r}\right)^{-1},-\sqrt{\frac{2M}{r}},0,0\right)[/tex]
And for an observer stationary at some radius R,
[tex]u'^{\alpha}= \left(\left(1-\frac{2M}{R}\right)^{-1/2},0,0,0\right)[/tex]
So,
[tex]\frac{dr}{dt} = \frac{\frac{dr}{d\tau}}{\frac{dt}{d\tau}}= \frac{u^r}{u^t} = -\sqrt{\frac{2M}{r}} \left(1-\frac{2M}{r}\right)[/tex]
And then,
[tex]\frac{dr}{d\tau'} = \frac{dr}{dt} \frac{dt}{d\tau'} = \frac{dr}{dt} u'^{t} = -\sqrt{\frac{2M}{r}} \left(1-\frac{2M}{r}\right) \left(1-\frac{2M}{R}\right)^{-1/2}[/tex]
And in the case where r=R,
[tex]v = -\sqrt{\frac{2M}{R}} \left(1-\frac{2M}{R}\right)^{1/2}[/tex]
Did I mess something up or am I simply not calculating the same thing as them?
Nabeshin said:
Hrm.. they derive:
So,
And then,
No, you're fine.
The result of all that is that when R=2M, the velocity v=-1 (ie the speed of light, c, in natural units in the opposite direction to R)
So does that mean we accept that infalling particles that follow geodesics get to the speed of light at the event horizon of a black hole?
According to Wheeler and taylor, there are three types of in-falling radial plunger-
Drip (dropped from rest at ro)
Rain (dropped from rest at infinity)
Hail (hurled inward at speed vfar from a great distance).Velocity of in-falling object relative to shell frame (vshell) (i.e. as observed from a specific radius)-
Drip
[tex]v_{shell}=-\left(1-\frac{2M}{r_o}\right)^{-1/2}\left(\frac{2M}{r}-\frac{2M}{r_o}\right)^{1/2}[/tex]
Rain
[tex]v_{shell}=-\left(\frac{2M}{r}\right)^{1/2}[/tex]
Hail
[tex]v_{shell}=-\left[\frac{2M}{r}+v_{far}^2\left(1-\frac{2M}{r}\right)\right]^{1/2}[/tex]which all equal c at the EH. In all three cases, multiply by [itex](1-2M/r)[/itex] for the velocity of the in-falling object as observed from infinity- dr/dt. Hypothetically, if you were to hover very close to a BH's event horizon, you would see an in-falling object approach close to c, then as it passed you and approached the EH, it would slow down and appear to freeze at the EH relative to you. This would always be the case, regardless of how close you hovered to the EH, technically you would have to be exactly on the EH to see the object cross at c.
I think that the answer I would give is that there is a big difference (which is covered at length in EBH) between "seeing" and "inferring from measurements at various distances". It is clear from the text that an infalling astronaut would experience the black hole rushing towards him/her at an ever increasing speed and could infer that the speed at the event horizon would be c
I think this refers to the bookkeeper metric rather than what is actually "seen" by shell observers.
Can we take this as read and move on?
Thanks, stevebd1, for that very informative post.
I think the answer to your question may require some delicate handling of limits. For example, let's take the case of a drip from [itex]r_o/2M=1+2\epsilon[/itex], observed by a shell observer at [itex]r/2M=1+\epsilon[/itex]. So for example, an observer 1 mm above the event horizon could be observing something infalling from 2 mm above the event horizon. In this situation, I get [itex]v_{shell}=-1/\sqrt{2}[/itex], not -1.
If I'm understanding your original question correctly, you're saying we have two particles, A and B, emitted near the event horizon. A is going to escape, and B is going to fall in. Here we have an [itex]\epsilon[/itex] that's on the order of the Planck length divided by the mass of the black hole. I think the quantum-mechanical uncertainty in the initial position of each particle is also on the order of the Planck length.
Do you have material particles in mind, or photons? If they're photons, then of course their velocity is c according to any local observer, but it isn't necessarily c as measured in Schwarzschild coordinates.
Nabeshin said:
Hrm.. they derive:
So,
And then,
You didn't calculate the same thing. You calculated (change in radial coordinate)/(change in shell observer proper time), but speed measured by a shell observer is given by (change in shell observer proper distance)/(change in shell observer proper time). Think about how to do this, and, if you need any hints, just ask.
Here is another (slick) way to calculate relative physical (not coordinate) speed between two observers who are coincident at an event. Suppose the two 4-velocities are [itex]u[/itex] and [itex]u'[/itex]. Then, [itex]\gamma = \left( 1 - v^2 \right)^{-1/2} = g \left( u , u' \right) = g_{\alpha \beta}u^\alpha u'^\beta.[/itex] This is an invariant quantity, and, consequently, can be calculated using any cordinate system/basis. What do you get for speed when you use your 4-velocities above?
This works in all coordinate systems in both special and general relativity.
Thanks for the response. I'll try and stick with the way I was doing it originally, and then look at your "slick" trick afterwards. If I understand you correctly, you're saying I need something like this:
[tex]\frac{dr}{d\tau'} \frac{dr'}{dr} = \frac{dr'}{d\tau'}[/tex]
Nearest I can reckon, the best way to proceed now is to take r=R and..:
[tex]\frac{dr'}{d\tau'} = \frac{dr}{d\tau'} \gamma = \frac{dr}{d\tau'} \left(1-\left(\frac{dr}{d\tau}\right)^2\right)^{-1/2} = -\sqrt{\frac{2M}{R}} \left(1-\frac{2M}{R}\right) \left(1-\frac{2M}{R}\right)^{-1/2} \left(1-\frac{2M}{R}\right)^{-1/2}=-\sqrt{\frac{2M}{R}}[/tex]
Now let's see about what you were talking about...
[tex]\gamma= g_{\alpha \beta} u^{\alpha} u'^{\beta} = g_{t t} u^{t} u'^{t}[/tex]
Since u'^r is equal to zero...
[tex]\gamma=-\left(1-\frac{2M}{R}\right) \left(1-\frac{2M}{R}\right)^{-1} \left(1-\frac{2M}{R}\right)^{-1/2}=-\left(1-\frac{2M}{R}\right)^{-1/2}[/tex]
[tex]\left(1-v^2\right)^{-1/2}=-\left(1-\frac{2M}{R}\right)^{-1/2}[/tex]
So the minus sign is a little bit troubling here, but proceeding anyways...
[tex]v=\sqrt{\frac{2M}{R}}[/tex]
Which is the same up to a sign, but I'm content with that. Pretty cool, George :approve:
Very nice.
It looks like you're using Lorentaz contraction. I'll have to think a little about this. Another way is to use the metric to compute proper distance directly, as is done on page 2-21, 2-22 of Exploring Black holes, and in the middle (just after "End of Motivation") of a previous post by me,
https://www.physicsforums.com/showthread.php?p=621802#post621802.
Which signature did you use for the metric? The expression(s) that I gave are valid for a + - - - metric. For a - + + + metric, the expression is [itex]\gamma = - g \left( u , u' \right)[/itex]. With the - + + + metric, the "inner product" of any two future-directed timelike 4-vectors (as the two 4-velocities are) is negative.
To move from v^2 to v, you took a square root, which introduces +/-. If v is treated purely as a speed (no direction involved), then use the + sign. If more information is given, then a choice between signs can be made. In our example, where one observer is falling down, if the shell observer chooses a coordinate system that: increases in the direction away from the black hole (up), a negative sign is needed; increases in the direction towards the black hole (down), a positive sign is needed.
Another old post (slightly more abstract mathematics) of mine that vaguely is related to this thread:
https://www.physicsforums.com/showthread.php?p=848684#post848684.
Ah yeah, I'm used to the - + + + convention so that's what I've been using throughout, and your comments clear up the choice of sign with the square root.
Lorentz contraction should be legitimate, but with the caveat that r=R since we can treat that part of spacetime as locally minkowski, right? At least that's the way it seems to me.
George Jones said:
Very nice.
So can you confirm George that the speed of an infalling particle at the EH is the speed of light?
Lorentz contraction (used correctly) is always legitimate in GR. Lorentz contraction and time dilation often confuse me, and, personally, I almost always use the interval (metric) to compute times and distances, even in special relativity.
Very loosely, and I wouldn't say that. There is no shell observer at "r = 2M". A more precise statement (echoing bcrowell) is that as r approaches 2M, the relative speed between the infalling observer and the shell observer *approaches* the speed of light.
Note that it is possible to have two different observers coincident at an event on the event horizon, but, even in this case, the relative speed between the observers is always less than the speed of light.
Though I'm no expert on general relativity, I have heard on good authority that if you observe something falling into a (nonrotating uncharged) black hole, you actually never see it fall in. A clock falling into a black hole would appear to continually slow down (approaching 0 velocity) while getting more and more redshifted and ticking slower and slower, forever. I guess once the photons are redshifted enough, they just blend in with the background/vacuum radiation.
Why does that sound so evasive, George? The equations say that the particle *does* reach the speed of light at the EH, regardless of whether the particle is thrown at the black hole or simply falls in, and regardless of the starting position above the EH.
You might say that say that it asymptotically reaches the speed of light, but then it also asymptotically reaches the EH as well. Unless the EH represents some kind of hard barrier which causes everything to bounce off and never cross the EH, then that's what the equations suggest.
I'm not trying to be evasive, I'm trying to be careful :smile:.
By "equations", I think you mean equations [42] and [47] from the chapter 3. Again, I have to point out that there only shell observers for (strictly) [itex]r > 2M[/itex], so these equations are not valid on or inside the event horizon.
There is a distinction between coordinate speed and physical speed. Physical speed can only be measured locally. Let any observer measure the speed of a photon that whizzes by in his local neighbourhood. The answer is the same (the speed of light) for all observers, above, at, or below the event horizon. Also, the measured speed (again by an observer above, at, or below the event horizon) of any matter in a local neighbourhood will also be less than this speed.
This shows that there is a fundamental physical difference between massive and massless particles.
Even in special relativity, there are (somewhat natural) coordinate-based definitions of "speed" according to which massive particles can have speeds greater than c (e.g., the Milne universe).
I think George has been very generous with his time in his thread, and has very carefully tried to cooperate with the other people in this thread in working out the issues in detail. DiamondGeezer, it seems like you keep insisting on a yes/no answer, but if you look back over the discussion, the entire thrust of the discussion has been that the original question was posed in a way that ignored some important distinctions. The question doesn't have a yes/no answer.
I accept that. But it does lead to a problem. Let's take the shell observers to the limit as [tex]r \rightarrow 2M[/tex]
The reasoning is not so difficult but the implications of any particle actually reaching the event horizon of a black hole are very clear. From the perspective of any particle (or astronaut), the black hole appears to approach with ever increasing speed, until at the event horizon, that speed is c.
The shell observers do not see a particle (or astronaut) reach c, but they infer it from measurements as the infalling particle accelerates through the shells.
But that brings a problem:
Q: If an infalling particle asymtotically reaches c, the kinetic energy of that particle increases without limit. Yet the kinetic energy comes from the gravitational field of the black hole, so what happens when the kinetic energy of a particle exceeds that of the total energy of the black hole? Of the Universe?
It exceeds speed of light only in the coordinate system of a distant observer. GR has no problems with superluminal speed of far objects in curved spacetime.
So the superluminal speed has no physical consequences: you can not observe objects passing you faster then light, and all relative speeds, even inside the BH, are <c
Event horizon is not in object. The position of apparent event horizon is observer-dependent, so different observers do not agree on the position of the horizon. No observer (including freely falling) can reach horizon in his own frame. So, for the freely falling observer, the event horizon recedes in front of him, so he never reaches it.
Regarding the signularity, in non-rotating BH singularity is space-like, so it is in the future, so we can not say that 'it approaches at some speed'
This is the relative velocity as seen in a succession of local inertial frames. Even in SR a particle that is traveling with constant velocity relative to any particular inertial frame will increase its velocity as one changes inertial frame.
In GR energy conservation is generally weird, but a conserved energy for a freely falling particle in the Schwarzschild solution is given by Eq 7.38 and 7.41 of http://nedwww.ipac.caltech.edu/level5/March01/Carroll3/Carroll7.html
What's interesting is that no-one has pointed out that if a particle travels at the speed of light at the EH in one frame of reference then it travels at the speed of light in all of the others.
The particle does not travel at the speed of light at the EH relative to any local inertial frame at the event horizon.
There is no "local inertial frame" at the event horizon.
You should ring up Edwin Taylor and tell him, because he's under the strange delusion that the event horizon is reachable in the finite time of an infalling particle or astronaut. Especially as he devotes an entire chapter of "Exporing Black Holes" to describing just that.
This makes absolutely no sense at all.
There most certainly are local inertial reference frames at the event horizon
and what atty states is quite correct. This is very much related to
Might it be fair to say that as an object crosses the event horizon, the time dilation is zero at exactly 2M and according to Gullstrand-Painleve coordinates, time outside the EH increases to infinity (i.e., the universe outside the EH comes to an end) so the only frames of reference the in-falling object relate to once at/past 2M are those inside the EH.
  • · Replies 46 ·
10K
  • · Replies 73 ·
  • · Replies 51 ·
  • · Replies 40 ·
  • · Replies 22 ·
  • · Replies 20 ·
  • · Replies 43 ·
