Register to reply
What's in an electronics hobbyist's toolbox?
by MATLABdude
Tags: electronics, hobbyist, toolbox
Share this thread:
MATLABdude
#1
Nov3-09, 05:33 AM
Sci Advisor
P: 1,724
I've occasionally been asked by some of the students I've mentored or TA'd over the years, "What's in your toolbox? What do you recommend for someone who's just starting off to put in their toolbox?" I thought it might be fun / helpful to list some of your contents / essentials!
In my (electronics) toolbox (and piled on top/around it), I have:
  • multimeter (Meterman 37XR, purchased after a few lower-quality multimeters gave up)
  • bits of wire made into various probing bits for the above
  • nice multi-bit screwdriver (Megalok)
  • multi-bit mini-screwdriver set (think jeweller's tools)
  • allen key set on a handle (so you don't lose any)
  • several pairs of needle nose pliers (regular to really, really narrow)
  • several pairs of side cutters (in various stages of being chewed up)
  • Greenlee inductive probe
  • needle- and blunt-tipped tweezers
  • spring-loaded mini grabber thingamajig
  • fancy self-adjusting wire strippers (I had an employee discount)
  • breadboard + a small roll of 22 gauge solid-core wire
  • adjustable-temperature Weller soldering station, fine (lead) solder, and braid
  • hot glue gun
  • hot air gun
  • small box-cutter
  • pair of handy-hands
Plus some assorted components / odds-and-ends I haven't file away into the appropriate storage case.
Phys.Org News Partner Engineering news on Phys.org
Comfortable climate indoors with porous glass
Crash-testing rivets
Customized surface inspection
berkeman
#2
Nov3-09, 11:24 AM
Mentor
berkeman's Avatar
P: 40,730
In addition to my toolbox, I also carry a Leatherman Wave on my belt all the time. So many times it's saved me a trip back to my toolbox when working on something in the lab or elsewhere.
Bob S
#3
Nov3-09, 11:35 AM
P: 4,663
Besides the excellent above list, I still (surprise!) have my 50-year-old Simpson (model 260) multimeter. I have an old 1 KVA Variac mounted in a box. I also have a good collection of npns, n-channel fets, Hall effect sensors, LM324's, 741's etc. No digital stuff though.
Bob S
waht
#4
Nov3-09, 04:40 PM
P: 1,636
A bundle of crocodile clips
A variable voltage power supply is a big plus. I still use one I built in high school which has four independent outputs controlled by LM317, LM337 (negative voltage). I can't count how many times I had to use all outputs at once.
DC load. It seems useless when you don't have it. I pulled a bunch of dale 1% tolerance power resistors from a junk 3 phase motor driver. I didn't know what to do with these, so just put them in a box, with switches, and with a current monitor. It turned out to be very handy, and many times, I use it in parallel with a multimeter.
dlgoff
#5
Nov3-09, 05:25 PM
Sci Advisor
PF Gold
dlgoff's Avatar
P: 2,704
Crimpers for spade lugs etc.
Crimpers for RJ connectors.
Wire ties
Shrink tubing
30ga wire wrap wire for repairing some circuit traces
soldering iron with solder (low and high temp)
solder sucker
wire nuts
misc. machine screws
weitao
#6
Nov5-09, 12:40 AM
P: 32
I have some LEDs , Diodes , Transistors , capacitors and resistors . But don't have solar panel.
davidrit
#7
Dec3-09, 01:56 PM
P: 44
Pretty good stuff already listed. I would add
Calipers and metal edged ruler
Tweezers with magnifier attached on hinge
"Dental" picks to use for scraping off epoxy, lifting leads
Flashlight
Banana jack to BNC and BNC to clip lead adapters
turbo
#8
Dec3-09, 02:43 PM
PF Gold
turbo's Avatar
P: 7,363
I have almost the same "kit" as MATLAB. I would add a couple of pairs of ratcheting heomostats. They are excellent heat-sinks to protect delicate components during soldering/de-soldering. I restore old tube amps from time to time, and sometimes the solder joints in tag-board eyelets require a lot of heat, so heat-sinking is important. Also an ancient cardboard chart of component value color codes. Also, a representative set of tested-good vacuum tubes, and plug-in SS rectifiers that I made by gutting burnt tubes and soldering diodes to the appropriate pins inside the bases. And jumpers! After discharging the caps in the amps power-supply (before sticking any fingers in there), clip a really brightly colored jumper (so you'll remember to remove it before an on-bench power-up) to an appropriate place and the other end to the chassis, to keep the caps from re-growing some charge. Can of paste flux - maybe not necessary when building new circuits, but a real help when working on old circuitry. A small piece of soft leather to protect the fingers from heat. Tubes get pretty hot, and I'm sometimes impatient. Shorting plug or alligator clip. Got no pedal with an old Fender amp? Short the Vibrato jack to see if the vibrato works. Speaker motor with no cone or frame. Want to probe the amp with an O-scope to see what it's doing? Need a nice quiet load that's not purely resistive. There's more, but that's the stuff I need.
Mike_In_Plano
#9
Dec10-09, 11:35 PM
P: 560
Magnifying glasses - sigh...
Wetmelon
#10
Dec27-09, 07:31 AM
P: 154
Cracked me up.
Quote Quote by Mike_In_Plano View Post
I tried not to laugh... but I had to! *sympathy*
To add, banana posts & plugs. Always handy. Soldering paste. Junk from the 70's that still apparently works. (I inherited my dad's Electronics box from his days at Algonquin) One of these (Just happens to be the same one!)
Redbelly98
#11
Dec27-09, 04:10 PM
Mentor
Redbelly98's Avatar
P: 12,068
I'll add a few:
  • A 2nd multimeter, for simultaneous current and voltage measurements.
  • Mini clip-ons for multimeter probes.
  • Small resistors (eg. 0.01 or 0.001 Ω) for measuring currents outside the range of the meter.
  • Not a toolbox item per se, but some circuit design & analysis software for quickly testing ideas. (LTSpice in my case)
MATLABdude
#12
Dec29-09, 11:50 AM
Sci Advisor
P: 1,724
Quote Quote by Wetmelon View Post
Quote Quote by MATLABdude View Post
Cracked me up.
Okay, okay... Lenline calls it a pick-up tool:
http://www.e-sonic.com/aboutus/cat/I...inated%201.pdf
Since you can find these in a magnetic form as well, I think you have to add in the word 'claw'. For instance, this mini claw pick-up tool (distinguishing it from the giant doggy-doo ones):
http://www.chi-mark.com/detail/226049/226049.html
story645
#13
Mar8-10, 03:37 PM
P: 670
Since there have been tons of questions on this, I'm adding in the hobbyist microcontroller:
Arduino
Mike_In_Plano
#14
Mar9-10, 02:32 PM
P: 560
I don't keep a microprocessor, but I do keep some communications tools. The SPI/I2C box known as the Ardvaark has been great. Also, a couple of generic programmers and JTAG interfaces.
berkeman
#15
Mar12-10, 09:24 PM
Mentor
berkeman's Avatar
P: 40,730
Looks like Lattice has an attractive special offer on a CPLD Evaluation Board through the end of March 2010 (probably still not too bad after that):
http://www.latticesemi.com/corporate...ceNews031210EN
Find the Right Balance of Price, Power and Package Size
The low-cost ispMACH 4000ZE Pico Development Kit is a compact platform to help you evaluate and prototype the ispMACH 4000ZE.
The ispMACH 4000ZE Pico Development Kit is designed to help you evaluate the ispMACH 4000ZE technology, verify the data sheet specifications for your application, learn the device features and operation, and prototype your own design. The Kit is available for a special price of $36 until March 31, 2010.
The battery-powered ispMACH 4000ZE Pico Development Kit includes:
Pre-programmed Pico Power demonstration design
LC4256ZE-5MN144C CPLD, a 256-macrocell CPLD
Power Manager II ispPAC-POWR6AT6 device for power monitoring
7-segment LCD panel for visual feedback
Expansion header for I2C, JTAG, and I/O interfacing
PicoView for Windows, an I2C interface utility
Battery or USB power source
QuickSTART Guide
USB cable
For maximum ease-of-use and user experiments, the board is programmed via a standard USB cable connected to a PC. No additional power supply or programming hardware is required. Simply plug the board into your PC, and you’re up and running in minutes. Power consumption can then be accurately measured via an ammeter in-series with the ispMACH 4000ZE.
The board features a number of LEDs, LCDs, buttons and switches for general-purpose inputs and outputs. I/Os are accessible from a header landing. This can be valuable if you wish to measure the I/O response to different load conditions with different programmable I/O types.
Mike_In_Plano
#16
Mar14-10, 01:29 AM
P: 560
This is a super deal as the mach is a good starting point for a VHDL beginner, and it appears that Lattice is licensing the compiler + tools for 1 year for free!
mdjensen22
#17
Aug6-10, 02:42 PM
P: 161
Aside from those already listed:
Electrical tape
bread board
Batteries
Adjustable Wall-wart
An Exacto (with extra blades) - this comes in handle for cutting and exposing traces
A few small pieces of Vectorboard
Topher925
#18
Aug27-10, 12:18 PM
Topher925's Avatar
P: 1,672
I would add to the list
-a good set of tweezers (fine point especially)
-architects lamp
-a GOOD multimeter (cheap chinese DMMs don't count, I recently got an Agilent u1242B and it changed my life)
Register to reply
Related Discussions
What's in your differential geometry toolbox? Special & General Relativity 12
Matlab symbollic toolbox help Engineering, Comp Sci, & Technology Homework 2
How to capture live video/image using Matlab without Image acq toolbox Math & Science Software 1
MATLAB signal processing toolbox (sptool) Math & Science Software 1
ELECTRONICS 2 Electrical Engineering 1
