Physicist | What Does It Mean to be a Physicist?
  • Thread starter Thread starter Legion81
    Physicist
The discussion centers around the definition and implications of the title "Physicist," particularly regarding the qualifications necessary to use this title. Participants explore whether a bachelor's or master's degree in physics suffices to claim the title, and how employment context influences this designation. The conversation touches on various international perspectives and certification processes related to the title.
  • Meta-discussion
  • Some participants propose that anyone with a degree in physics or working in a physics-related field can call themselves a physicist, regardless of the degree level.
  • Others argue that the title "Physicist" is often reserved for those with a PhD, suggesting that it may be misleading for someone without this qualification to use the title.
  • A participant notes that in Poland, the title "Engineer" requires certification, while "Physicist" does not, indicating a difference in title requirements across countries.
  • Another participant mentions that in the US, the title of "Professional Engineer" (PE) requires specific qualifications and does not extend to those with a physics degree, highlighting the certification process for engineers.
  • Some contributions discuss the variability of titles based on job roles, with examples of physicists being labeled as engineers in certain employment contexts.
  • A participant from Canada mentions a professional designation for physicists (P.Phys) that recognizes working physicists with an undergraduate degree and relevant experience, suggesting a formal acknowledgment of the title's use.
  • There is a discussion about the historical context of engineering titles in the Netherlands, noting changes in the educational system and title recognition over time.
  • One participant clarifies the distinction between academic titles conferred by degrees and job titles, indicating that the original question may not have been fully addressed.
Participants express differing views on the qualifications necessary to be considered a physicist, with no consensus reached on whether a PhD is required or if a bachelor's or master's degree suffices. The discussion reflects multiple competing perspectives on the title's use across different contexts and countries.
The conversation reveals limitations in the definitions of titles, which may depend on regional regulations, employment contexts, and personal interpretations of qualifications. There are also unresolved questions about the implications of using the title "Physicist" without formal certification.
Legion81
"Physicist" title
I'm not sure what section to post this in, so I guess this one will have to do.
I was recently told by an engineer that they have the title "Engineer" with a bachelor degree. I have always assumed the title "Physicist" was reserved for someone with a phd. But that got me to wondering, what do you call someone with a bachelor's or master's degree in physics? Does it depend on the place of employment? It seems misleading for someone to say they are a physicist if they don't have a phd.
hi,
if you work or earn with the help of physics...then you can call your self as physicist.
but i always think physicist are persons who understand the theory behind physics of some process and write some codes/programs for theory..
Anyone with a physics degree, or working in physics, can call him/herself a physicist.
However, titles like this are often dependent on the nature of your job and your employment. There are many physicists who are called "Engineers", because that is the title of the job they do at the place of employment. The same is true for engineers that take on the responsibility of a physicists. So very often, your employment dictates your official title.
Zz.
In Poland to call yourself Enginner you need to be certfied as one, Physicist is not a title that requires certification. Not sure about details, but from what I haerd some system of certifications works in US as well.
Zz.
I second this. When I did research at the Air Force Research Labs, my title was "Research Engineer (pay grade GS ___)" although at the time my only degree was a bachelor's in physics... but I had one friend whose degrees (up through Ph.D.) were in engineering, and he was labeled a "Research Physicist, GS___."
In the US (and many countries) there is a certification process for engineering -- here in the US known as becoming a "Professional Engineer (PE)." To do that, at least presently in the US, you need a Bachelor's degree in engineering from an accredited university, a few years experience in the field of engineering, and you need to then pass a series of tests, including a test in your particular field/branch of engineering. Note, I can't qualify for the PE tests because my undergraduate degree is in physics, even though I have a Master's in Engineering... so under the present system I can't ever get to a "PE" (although there's starting to be some talk about allowing individuals to take the tests if their degree is in a related field and they have an MS from an accredited engineering program).
Same here, degree/Phd in physics - but so far into experimental physics that it was really engineering.
Here in Canada you can't even be an MSCE (microsoft certified engineer) because only PEng can use the title engineer - it involves a certain amount of creative writing in technical job descriptions.
This seems to differ in each country. In The Netherlands, we used to have 2 engineering titles, ing. and ir. The first required a diploma from a special kind of school, comparable to bachelor level. The second one required a university diploma (comparable to masters degree, those universities didn't give out "bachelors", you'd ave to complete the whole program) in an engineering field.
For physicists there was no special title: you either was drs. (from latin docterandus, "he who must become doctor", masters degree), dr. (PhD) of ir. (masters in applied physics).
This has changed now and we are moving to a bachelor/master system (mostly for international contacts, a university bachelor is still looked uppon as someone who didn't finisch his or her study), however, many (like me) still prefer to use our "old" titles. Must be some kind of snobism. :-)
I think you are confusing with the "title" of a conferred degree to the title being given in terms of "job description". I don't think the former is what is being asked here.
Zz.
The Canadian Association of Physicists has, for about a decade now, been promoting the recognition of working physicists with a professional physicist designation, P.Phys.
To qualify, you essentially need to have a recognized undergraduate degree in physics and have some experience with physics-related work (the definition of which is quite broad). While I don't agree or disagree that a legal designation is necessary, I think what this demonstrates is a formal recognition (in Canada anyway) of who should be called a "physicist."
For anyone interested:
http://www.cap.ca/en/node/1086
  • · Replies 53 ·
10K
  • · Replies 26 ·
  • · Replies 19 ·
  • · Replies 22 ·
