Energy conservation and string tension problem
The discussion revolves around a physics problem involving a block being pulled up a frictionless incline by a string exerting tension. The problem requires participants to analyze the work done on the block-earth system, changes in gravitational potential energy, and changes in kinetic energy as the block moves a specified distance.
  • Participants explore the application of the work-energy theorem and discuss the forces acting on the block, including tension and weight. There are attempts to calculate work done and changes in energy, with some questioning the role of the normal force and its contribution to work.
The discussion is active, with participants raising questions about the contributions of different forces to the net work done on the system. Some guidance has been provided regarding the roles of tension and gravitational forces, but there is no explicit consensus on how to proceed with the calculations.
Participants note that the problem defines the system as block-earth, which influences their understanding of which forces are considered external and how work is calculated. There is uncertainty about the treatment of the normal force and its impact on the work done.
crybllrd
A string exerts a tension force of 55N on a 10kg block as it moves a distance of 5m up a frictionless incline. The string pulls parallel to the incline.
A) Find the total external work done on the block-earth system as the block moves 5m up the incline.
B)Find the change in gravitational potential energy for the block-earth system as the block moves 5m up the incline.
C)Find the change in kinetic energy for the block-earth system as the block moves 5m up the incline.
[tex]KE=\frac{1}{2}mv^{2}[/tex]
[tex]PE_{g}=mgh[/tex]
Our teacher tells us to round gravity up to 10m/s/s.
A)The external force should be the tension, so:
[tex](55N)(5m) = 275J[/tex]
B)I used trig (3-4-5 triangle) to find the height to go up 3m.
[tex]mgh_{f}-mgh_{i}=\Delta KE[/tex]
[tex](10)(10)(3)-(10)(10)(0)=300J[/tex]
C)[tex]KE_{f}-KE_{i}=\DeltaKE[/tex]
I am not sure what to do here because I don't know how to solve for velocity.
What does the work-energy theorem say about change in kinetic energy?
[tex]W_{net}=KE_{f}-KE_{i}[/tex]
If this is right, then I can set 275J equal to
[tex]KE_{f}-KE_{i}[/tex]
[tex]\frac{1}{2}mv_{f}^{2}-\frac{1}{2}mv_{i}^{2}=275J[/tex]
[tex]5v_{f}^{2}-5v_{i}^{2}=275J[/tex]
But then I will have two variables [tex]v_{f}[/tex] and [tex]v_{i}[/tex]
I think I am on the wrong track.
This is right.
No, you cannot. Tension is not the only force that does work. What other force is there?
You don't care about the initial and final speeds. The problem is asking you to find the change in kinetic energy, not the initial and final speeds. If you find the correct Wnet, that is the change in kinetic energy.
It asks what the change for the block-earth system is. On a free body diagram for the block, I have three forces:
I have the Normal force (80N) by the ramp on the block,
the tension force (55N) ,
and a weight force (80N in y-dir, 60N in x-dir). (no friction)
Is the other force doing work the Normal force?
If so, then I am not sure how to calculate the work because the distance is perpendicular.
Yes there are three forces. As you say, the normal force does zero work. So what is the net work, i.e. the total work done by all three forces?
This is where I am getting confused.
The problem is defining the system as block-earth, so if I am not mistaken, the weight force is the only force not doing work on the system.
That would leave Normal and Tension forces.
Normal is perpendicular, so equal to zero,
Tension is 275J,
so total work is [275+0] 275 Joules.
You said earlier I can't set the equations equal to 275J because there are other forces. What am I missing here?
Do I need to add in the weight force? I think it should be included in the block-earth system, not as external work.
The tension increases both the kinetic energy and the gravitational potential energy of the Earth-block system. If you ignore the potential energy change, it is as if the incline is not there and the block moves across a horizontal surface.
  • · Replies 17 ·
