Voltage drop and current for each resistor
The discussion revolves around a circuit problem involving voltage drops and currents across resistors, specifically focusing on a circuit with both series and parallel resistor configurations. The original poster seeks guidance on the steps to solve the problem without receiving direct answers.
  • Participants discuss the calculation of voltage drops and currents using Ohm's law, with some suggesting the need for clarity in the original poster's request for help. There are attempts to combine resistors in series and parallel, and questions arise regarding the rules of the forum about providing complete solutions.
Some participants have provided detailed calculations and reasoning regarding the circuit, while others emphasize the importance of adhering to forum rules against giving complete solutions. The conversation reflects a mix of helpful guidance and reminders about the learning-focused approach of the forum.
There is a mention of a specific forum rule that discourages providing complete solutions, which some participants question and discuss in relation to the nature of homework help.
alan1592
heres a picture of the problem. Please don't give me the answer just tell me what are the steps to complete it. thanks.
http://i307.photobucket.com/albums/nn296/alan1592/download-1.jpg
V=IR
1/6+1/3=2 Ohms
Ok, so you now have two resistors in the circuit- you can calculate the voltage drop across each resistor and, using Ohm's law, the current. You need to be a little more specific with what you're looking for so you can get more help.
Im looking to find those items. The voltage drop and the current. I don't know how.
Since there is one indepedent voltage source of 20 Volts that means the voltage drop across all the resistors should equal 20V.
I would have made this look nice but the LaTex Isn't working.
First Combine the Resistors in Parrallel:
1/R =(1/R_1)+(1/R_2)+...(1/R_N)
1/R = (1/6 Ohm) +(1/3 Ohm)
1/R = (1/6 Ohm) + (2/6 Ohm)
1/R = (3/6 Ohm) = (1/2 Ohm)
1/(1/2 Ohm) = R = 2 Ohm
So now you have
|___________________|
Sorry for the bad drawing
( --||-- = voltage source, ^^^^ = resistor)
Now combine the resistors in series
R= R_1 +R_2+...R_N
R= 3 Ohm + 2 Ohm
R = 5 Ohm
So now you have
|____________|
Using V = IR you can solve for the current:
V=IR
(20 Volts) = I * (5 Ohm)
I = 4 Amperes
Now split the circuit back up so that it is 2 resistor in series.
Resistors in series have the same current
So for the first resistor (3 Ohm resistor)
V = IR
I = 4 Ampere
R = 3 Ohms
V = (4 Ampere)(3 Ohm)
V= 12 Volts
Voltage on the 3 Ohm resistor directly right of the independent voltage source is 12 volts
Now for the second resistor (2 Ohm Resistor)
V = IR
I = 4 Ampere
R = 2 Ohms
V = (4 Ampere)(2 Ohms)
V = 8 Volts
Voltage on the 2 Ohm resistor directly right of the 3 Ohm resistor is 8 volts.
Split it up so you are back with the circuit you were first with.
|___________|----^^^^--|
Resistors in parrallel have the same voltage so:
6 Ohm Resistor in Parrallel:
V=IR
(8 volts) = I * (6 Ohm)
I = (4/3) Amperes
3 Ohm Resistor In parrallel:
V= IR
(8 Volts) = I * ( 3 Ohm)
I = (8/3) Ampere
So,
Resistor 1:
Resistor(R)= 3 Ohm
Voltage Drop(V) = 12 Volts
Current(i) = 4 Amperes
Resistor 2:
Resistor(R) = 6 Ohm
Voltage Drop(V) = 8 Volts
Current(i) = (4/3) Ampere
Resistor 3:
Resistor(R) = 3 Ohm
Current(i) = (8/3) Ampere
Cheesus128 said:
Whats the point of that rule?
So the members here don't do your homework
Hahahaha that made me smile
Oh well every forum has its own rule.
But still its not like he is posting his whole paper or HW here, he is only posting one question so wouldn't that be something else?
I mean mostly you can only find how something works by knowing the answer and the exact way of getting there.
Hence you need the full explanation?
Yeah he was very helpful to me too. I deff learned how to do the problem and that's what i wanted. Thanks man!
