Resultant time dilation from both gravity and motion
The discussion revolves around the resultant time dilation experienced by a frame moving in relation to an observer at infinity while situated in a gravitational well. Participants explore the interplay between gravitational and motion-induced time dilation, examining various expressions and models, including those derived from the Schwarzschild metric. The scope includes theoretical considerations and mathematical reasoning related to general relativity and special relativity.
  • Some participants propose that the resultant time dilation can be expressed as a sum of motional and gravitational dilations, represented mathematically as t=τ(γ-1g-1).
  • Others argue against the summation approach, suggesting that the correct expression should be derived from the Schwarzschild metric, indicating that the relationship is more complex than a simple sum.
  • One participant mentions that for objects in circular orbits, the total time dilation is a product of gravitational and velocity-based time dilation, while noting that other cases may be more complicated.
  • Another participant discusses the use of Newtonian theory in non-relativistic situations, suggesting that the combined effects of time dilation can be treated as additive fractions based on energy ratios.
  • Several participants engage in clarifying and correcting expressions related to time dilation, particularly focusing on the differences between radial and circular motion, and the implications of using coordinate versus local velocities.
  • One participant asserts a specific equation for time dilation that applies to various motions, emphasizing the need for proper definitions of velocity in the context of local observers.
Participants do not reach a consensus on the correct expression for time dilation, with multiple competing views and models presented throughout the discussion. Disagreements persist regarding the validity of specific expressions and the interpretation of results derived from the Schwarzschild metric.
Limitations include potential misunderstandings of the Schwarzschild metric and the definitions of velocity used in different contexts. Some expressions may depend on specific assumptions about the motion and the gravitational field, which remain unresolved.
  • #61
kev said:
A more general equation is:
[tex]\frac{\text{d}\tau}{\text{d}t}= \sqrt{\frac{1-r_s/r}{1-r_s/r_o}} \sqrt{1- \left (\frac{1-r_s/r_o}{1-r_s/r} \right )^2 \left (\frac{\text{d}r}{c\text{d}t} \right )^2 - \left (\frac{1-r_s/r_o}{1-r_s/r} \right ) \left(\frac{r \text{d}\theta}{c\text{d}t}\right)^2 - \left (\frac{1-r_s/r_o}{1-r_s/r} \right) \left(\frac{r \sin \theta \text{d}\phi}{c\text{d}t}\right)^2 }[/tex]
where [itex]r_o[/itex] is the Schwarzschild radial coordinate of the stationary observer and r is the Schwarzschild radial coordinate of the test particle and dr and dt are understood to be measurements made by the stationary observer at [itex]r_o[/itex] in this particular equation.
For [itex]r_o = r[/itex] the time dilation ratio is:
[tex]\frac{\text{d}\tau}{\text{d}t} = \sqrt{1-\frac{v'^2}{c^2}}[/tex]
No, you are missing a lot of terms.
  • #62
starthaus said:
Are you even reading what I am writing? Can you re-read posts 2,6,39,47?
Post 47 was by espen180, and as to the others, yes you derived equations for special cases that were closer to a product of gravitational time dilation and something else, but since you didn't use the concept of local velocity the "something else" (i.e. the second part of the product that didn't look like the gravitational time dilation equation) didn't look very much like the SR velocity-based time dilation equation. Since espen180's original post was asking about the total time dilation in relation to the gravitational time dilation and velocity-based time dilation formulas, I thought kev and pervect's equations were relevant to the OP. Again, I'm not saying your equations are wrong in any way, but you haven't made a convincing case that kev's are wrong either--if you still maintain that, please answer the questions in my previous post.
  • #63
Because it isn't. Both effects are GR effects, in fact, there is only one effect. There is no such thing as an SR effect. The effect falls out the Schwarzschild metric.I have already explained this here
I have answered your questions, I would like you to answer mine.
  • #64
starthaus said:
Because it isn't. Both effects are GR effects. There is no such thing as an SR effect.
This is a strawman, I didn't say anything about "SR effect", I just said that the formula for total time dilation of an orbiting object calculated using GR (not SR) broke down into the product of two formulas that look like the formulas for gravitational time dilation for a stationary object and velocity-based time dilation for a moving object in SR.
What questions of yours have I not answered? You didn't even ask any questions in this post! Anyway, there are several questions in that previous post #59 that I have asked variations on in the past and you have not answered, such as "again, do you agree that the type of orbit I described is a physically valid one?" (referring to the type of orbit I mentioned earlier in post 56) and "Yes or no, do you acknowledge that the arguments you made against kev's derivation prior to the new argument you've made in the posts here and here were flawed?" and "Do you deny that the general formula would reduce to the specific formulas found by pervect/kev in the specific case they were considering, namely an infinitesimal section of a circular orbit where the radial coordinate and one of the two angular coordinates are constant?" If you are interested in good-faith debate here, please answer the questions I ask you (and I will do likewise of course) rather than just picking one part of my post to criticize and ignoring everything else.
  • #65
That does not exclude the possibility to identify them as separate things.
For instance in the Gullstrand–Painlevé chart you can readily identify the Lorentz factor for relative motions.
But in non-stationary spacetimes this will obviously be a very daunting task.
  • #66
Because, contrary to kev's claims, the term [tex]\frac{dr/dt}{\sqrt{1-r_s/r}}[/tex] does not represent "local velocity". It represents nothing. We had a very lengthy discussion in another thread, if you want the correct formula for local velocity you can find it in my blog, in the file "General Euler-Lagrange derivation for proper and coordinate acceleration".
Because it doesn't. Because it has absolutely nothing to do with any "SR velocity-based time dilation".
One very basic one: that the derivation and the result I gave are the rigorous, complete ansers. Yes or no?
Sure I did, you need to look at the sentences ending with question marks.
If you are happy with hacks and with formulas that are correct for restrictive conditions , like only in the equatorial plane, the answer is yes. Happy?
  • #67
starthaus said:
Because, contrary to kev's claims, the term [tex]\frac{dr/dt}{\sqrt{1-r_s/r}}[/tex] does not represent "local velocity". It represents nothing. We had a very lengthy discussion in another thread, if you want the correct formula for local velocity you can find it in my blog.
What thread did you discuss it? Do you also dispute DrGreg's derivations which he linked to in post #8?
"Has to do with" is a rather ill-defined phrase. I'd say that if it uses the same equation as "SR velocity-based time dilation", then it "has to do with" it in at least some limited sense.
Your derivation seems rigorous but you'll have to define what you mean by "complete". Do you just mean that it's the most general case, and that all more specific answers would be derivable from it? If so then I agree. But if you're saying that from a pedagogical point of view it's "complete" in the sense that there's no point in discussing any more specific cases, I disagree, the more specific cases may be more helpful for gaining physical intuitions than the more general equation.
When I said "in this post" I meant the post I was responding to (the one where you said 'I have answered your questions, I would like you to answer mine'). There were no sentences ending with question marks in that post. If there were questions in other posts that you think I didn't address and you'd still like answers to, just point them out.
Not completely, because your comments about "hacks" and "restrictive conditions" still seem to imply you think there is something better about your own suggestion here that we should set [tex]d\theta[/tex] to 0 rather than [tex]d\phi[/tex], when in fact this would be every bit as restrictive in terms of the set of circular orbits that would meet this condition--do you disagree that both are equally restrictive? Anyway, as I think espen180 pointed out earlier, because of the spherical symmetry of the Schwarzschild spacetime, for any circular orbit you can always do a simple coordinate transformation into a coordinate system that still has the same metric but where the circular orbit now meets this condition, so in fact kev's final equation should apply to arbitrary circular orbits. If you're familiar with the phrase without loss of generality in proofs, kev could have said "without loss of generality, assume we're dealing with a circular orbit where [tex]d\phi[/tex] = 0" and a physicist would understand the implied argument about why the final results should apply to all circular orbits.
  • #68
Here
DrGreg's time dilation formula is a subset of mine, so "no". The point is that the quantity in discussion ([tex]v[/tex]) is not what you and kev claim it is. The correct formula can be found in my blog.
That's what you said. And I explained to you that it has nothing to do with any "SR-based time dilation. ".
It either is or it isn't. Can you answer with yes or no, please?
Good. This is what I meant.
Absolutely.[tex]d \theta=0[/tex] means no motion along the meridian whereas [tex]d \phi=0[/tex] means no rotation, contradicting the problem statement. Why are we even discussing this?
Of course I do, how many posts do we need to waste on this obvious issue?
That's not the point. [tex]\phi[/tex] and [tex]\theta[/tex] are not intechangeable. They have different meanings , both mathematically and physically. They have different domains of definition, [tex]\omega[/tex] is [tex]\frac{d\phi}{dt}[/tex] (and not [tex]\frac{d\theta}{dt}[/tex]). If you insist on interchanging them, you would need to exchange their domains of definition ([tex]\theta[/tex] would need to be in the interval [tex][0,2\pi][/tex]), you would also need to rewrite the Schwarzschild metric. This is not what kev did in his hack.
This is incorrect, since [tex]\phi[/tex] and [tex]\theta[/tex] are not intechangeable.
  • #69
starthaus said:
-The correct answer to Dmitry7's question is:
[tex]\frac{d\tau_1}{d\tau_2}=\sqrt{\frac{1-r_s/r_1}{1-r_s/r_2}}\sqrt{\frac{1-(r_1sin\theta_1\omega/c\sqrt{1-r_s/r_1})^2}{1-(r_2sin\theta_2\omega/c\sqrt{1-r_s/r_2})^2}}[/tex]
-The correct answer to espen180's question is :
[tex]\frac{d\tau}{dt}=\sqrt{1-\frac{r_s}{r}}\sqrt{1-(\frac{r\omega sin(\theta)}{c \sqrt{1-r_s/r}})^2}[/tex]
I hope that this clarifies things once and for all.
This is not the correct answer to the question posed by espen180 in the OP of this thread. Here it the original question again to remind you:
espen180 said:
When a frame is moving in relation to an observer in his rest frame at infinity, and the frame is in a gravitational well, is the resultant time dilation simply the sum of the motional and gravitational dilation, e.g.
[tex]t=\tau\left(\gamma^{-1}+\gamma_g^{-1}\right)=\tau\left(\sqrt{1-\frac{v^2}{c^2}}+\sqrt{1-\frac{GM}{c^2r}}\right)[/tex]
Where [tex]\tau[/tex] is proper time and [tex]t[/tex] is measured by the observer?
If, not what is the correct expression?
Espen is asking about the resultant time dilation due to motional and gravitational dilation. He asks about the contribution due to motion but does not specify that the motion should be orbital. You supposedly "correct answer" is for the limiting case of orbital motion only. This might seem a bit picky, but you have set the standard here:
You have put a restrictive condition of only considering orbital (horizontal) motion. The complete general and correct answer to the OP was given by DrGreg in #8 and I quote him again here:
DrGreg said:
I believe that the equation
[tex] \frac{dt}{d\tau} = \frac{1}{\sqrt{1-v^2/c^2}\sqrt{1 - 2GM/rc^2}}[/tex]​
always applies (for radial, tangential or any other motion) where v is speed relative to a local hovering observer using local proper distance and local proper time.
I derived this in posts #9 and #7 of the thread "Speed in general relativity"[/color] (and repeated in post #46).
DrGreg's conclusions agree with the conclusions of pervect and myself.
You seem to think that you equation given in #7:
[tex]\frac{d\tau}{dt}=\sqrt{1-\frac{r_s}{r}}\sqrt{1-(\frac{1}{c^2}\frac{dr/dt}{1-r_s/r})^2}[/tex]
and my equation:
[tex]\frac{d\tau}{dt}=\sqrt{1-\frac{r_s}{r}}\sqrt{1-\frac{(dr'/dt')^2}{c^2}[/tex]
are in disagreement, with yours right and mine wrong and fail to understand that they are numerically identical.
[EDIT] Well they would be numerically identical, when you correct the error in your equation. Your equation in #7 should read:
[tex]\frac{d\tau}{dt}=\sqrt{1-\frac{r_s}{r}}\sqrt{1-(\frac{1}{c}\frac{dr/dt}{(1-r_s/r)})^2}[/tex]
  • #70
:lol:
How do you get the "general solution" from the truncated metric you've been using? Run this by us again, please.
If you don't understand the use of Schwarzschild solution in deriving the answer, then ask and I'll try to help you.
  • #71
Congratulations, you found a missing closed/open parens after [tex]\frac{1}{c^2}[/tex]. You are good at finding typos. :-)
The complete equation is obviously correct:
[tex]\frac{d\tau}{dt}=\sqrt{1-\frac{r_s}{r}}\sqrt{1-(\frac{1}{c^2}\frac{dr/dt}{1-r_s/r})^2}=\sqrt{1-\frac{r_s}{r}}\sqrt{1-(\frac{v/c}{1-r_s/r})^2}[/tex]
  • #72
Let us say an exam question asks what is the time dilation ratio [itex]d\tau/dt[/itex] of a particle moving in Schwarzschild coordinates with velocity components [itex]dr/dt = 0[/itex], [itex]r d\theta/dt = 0[/itex] and [itex]r d\phi/dt = 0.5[/itex] and numerical values for G, M, c and r are given.
Student A states that is not possible to give a numerical solution because the value of [itex]\theta[/itex] has not been given.
Student B realizes the spherical symmetry of Schwarzschild coordinates allows him to re-orientate the axes of the coordinates and interchange [itex]d\phi[/itex] and [itex]d\theta[/itex] so that he can obtain a correct numerical solution, even though the value of [itex]\theta[/itex] is not known.
Who deserves the most points for their answer? Student A who is plugging numbers into a formula or student B who is using understanding of the physical situation and using a bit of ingenuity to actually obtain the required numerical answer?
  • #73
kev said:
Let us say an exam question asks what is the time dilation ratio [itex]d\tau/dt[/itex] of a particle moving in Schwarzschild coordinates with velocity components [itex]dr/dt = 0[/itex], [itex]d\theta/dt = 0[/itex] and [itex]d\phi/dt = 0.5[/itex] and numerical values for G, M, c and r are given.
And he's right.
Try doing that and I'll show you where the mistake is.
Neither, student C who knows how to use the general (not the truncated) Schwarzschild solution such that he/she produces the correct general solution that has [tex]\theta[/tex] as a parameter. How would you do this , kev, without resorting to silly hacks?
  • #74
espen180 said:
Why not just contract the angle differentials into [tex]\text{d}\theta^2+\sin^2\theta\text{d}\phi^2=\text{d}\Omega^2[/tex] and avoid the problem alltogether?
starthaus said:
Because [tex]\phi[/tex] and [tex]\theta[/tex] are independent coordinates. So your hack is illegal.
LOL. In which countries is this illegal?
I have seen this equation given by espen used in enough references to be fairly certain it is legitimate and pretty much standard procedure.
  • #75
calculus is not your strong suit.
  • #76
In post #8 DrGreg said that his v stood for "speed relative to a local hovering observer using local proper distance and local proper time". Do you disagree with this definition? If not, what do you think kev "claims" that is different? (I haven't claimed anything about it myself, so the phrase 'what you and kev claim' is pure imagination on your part)
I don't think you understood my point. I was saying that "has to do with" is a semantically ambiguous phrase, and that under one reasonable definition of "has to do with", the fact that the term in the total GR time dilation equation for circular orbits looks just like the SR time dilation equation would by definition mean it "has to do with" the SR time dilation equation, since "has to do with" can be defined in a broad way that does not imply any deeper connection besides a superficial similarity in equations. You certainly never "explained" why it doesn't have to do with SR time dilation, since you never gave any meaningful definition of the vague phrase "has to do with".
The reason I said "seems" is that I looked at your answer in post #13 and got the gist of how you derived it, the approach seemed fine but I didn't check the details of the math, trusting you probably got it right. If you insist that I double-check your work in detail, fine:
[tex] (cd\tau)^2=(1-r_s/r)(cdt)^2-(1-r_s/r)^{-1}(dr)^2-(rd\theta)^2-(rd\phi sin\theta)^2[/tex]
[tex]d\tau /dt = (1/c)\sqrt{(1-r_s/r)c^2-(1-r_s/r)^{-1}(dr/dt)^2-(rd\theta/dt)^2-(rd\phi/dt sin\theta)^2}[/tex]
Strictly speaking this equation is itself the most general answer for the time dilation for an object moving along an arbitrary worldline where [tex]dr/dt[/tex], [tex]d\theta/dt[/tex], and [tex]d\phi/dt[/tex] might all be nonzero. But then if we introduce the condition that we are looking at a portion of an orbit where [tex]dr = d\theta = 0[/tex] as you did in post #6, and set [tex]\omega = d\phi/dt[/tex], then this reduces to:
[tex]d\tau /dt = (1/c)\sqrt{(1-r_s/r)c^2 - (r sin\theta \omega)^2}[/tex]
Factoring out [tex]\sqrt{(1-r_s/r)c^2}[/tex] gives:
[tex]d\tau /dt = \sqrt{1 - r_s/r}\sqrt{1 - (r sin\theta \omega)^2 / (1-r_s/r)c^2}[/tex]
or, to make it closer to the form you chose:
[tex]d\tau /dt = \sqrt{1 - r_s/r}\sqrt{1 - (r sin\theta \omega/ c\sqrt{1-r_s/r})^2}[/tex]
Then for the ratio of times for two clocks in circular paths with r1 and r2 and [tex]\theta_1[/tex] and [tex]\theta_2[/tex] and [tex]d\phi_1/dt = \omega_1[/tex] and [tex]d\phi_2/dt = \omega_2[/tex] we'd have:
[tex] \frac{d\tau_1}{d\tau_2}=\sqrt{\frac{1-r_s/r_1}{1-r_s/r_2}}\sqrt{\frac{1-(r_1sin\theta_1\omega_1/c\sqrt{1-r_s/r_1})^2}{1-(r_2sin\theta_2\omega_2/c\sqrt{1-r_s/r_2})^2}}[/tex]
This is almost like the equation you got, but you do seem to have made the minor error of leaving out the "c" that appears in my equation (yours is not dimensionally correct, since [tex]\omega[/tex] has units of 1/time), and also you just wrote [tex]\omega[/tex] in both parts of the fraction, neglecting to account for the possibility that [tex]\omega_1[/tex] differs from [tex]\omega_2[/tex]. An additional thing to note is that if you want to have a circular orbit where [tex]d\theta = 0[/tex] as opposed to an arbitrary circular path, you must pick [tex]\theta = 0[/tex], so that [tex]sin\theta = 0[/tex] and the whole thing reduces to [tex]\frac{d\tau_1}{d\tau_2}=\sqrt{\frac{1-r_s/r_1}{1-r_s/r_2}}[/tex]; a circular path with [tex]d\theta = 0[/tex] but [tex]\theta[/tex] not equal to zero would be one where the center of the path did not coincide with the center of the Schwarzschild coordinate system at r=0, like how a line of latitude on the Earth forms a circle whose center does not coincide with the center of the Earth (unless it's latitude 0, in which case the line of latitude would just be the equator), so this would not actually be a physically valid "orbit".
In what sense do you imagine that your suggestion of setting [tex]d\theta = 0[/tex] is less "restrictive" than setting [tex]d\phi = 0[/tex]? Setting [tex]d\theta=0[/tex] is equivalent to picking a circle of constant latitude on a globe (latitude varies 180 degrees from the South Pole to the North Pole, just like the [tex]\theta[/tex] coordinate varies over half a circle from 0 to [tex]\pi[/tex]), like the first image on http://literacynet.org/sciencelincs/showcase/drifters/activity1b.html:
Whereas setting [tex]d\phi = 0[/tex] is equivalent to picking a circle of constant longitude on a globe (longitude varies 360 degrees from 180 west of the prime meridian to 180 east of it, just like [tex]\phi[/tex] varies in a full circle from [tex]-\pi[/tex] to [tex]\pi[/tex]), like the second image:
It should be clear that all the infinite possible circles with [tex]d\phi = 0[/tex] have centers that coincide with the center of the coordinate system at r=0, whereas only a single circle with [tex]d\theta = 0[/tex] has a center that coincides with the center of the coordinate system (the one at [tex]\theta = 0[/tex]). So if you're interested in circular orbits, [tex]d\theta = 0[/tex] seems more restrictive, not less restrictive! But either way you could also find an infinite number of circular orbits at different angles relative the coordinate system such that neither [tex]d\theta = 0[/tex] nor [tex]d\phi = 0[/tex] would apply.
Do you disagree with any of the above? If so, which part? If not, can you explain your reasoning behind calling [tex]d\theta = 0[/tex] the less "restrictive" condition?
No, you would not need to rewrite the Schwarzschild metric, that's exactly what I meant when I said "Anyway, as I think espen180 pointed out earlier, because of the spherical symmetry of the Schwarzschild spacetime, for any circular orbit you can always do a simple coordinate transformation into a coordinate system that still has the same metric but where the circular orbit now meets this condition". Just as the metric has exactly the same form in the different inertial coordinate systems used in flat spacetime, so it is also true that because of the spherical symmetry of the Schwarzschild metric, one can find a family of different spherical coordinate systems with the [tex]\theta = 0[/tex] and [tex]\phi = 0[/tex] axes oriented in different directions (all of them having the same r=0 point), but with the same Schwarzschild metric applying to all these coordinate systems. And for any circular orbit whose center is at r=0, there will be one member of this family of spherical coordinate systems where the orbit has a constant [tex]\theta[/tex] coordinate, and another where the orbit can be divided into two halves that each have a constant [tex]\phi[/tex] coordinate. Do you disagree?
  • #77
It's a typo, corrected in many subsequent posts. See 37 for example.
If you insist to have the objects rotating a different angular speeds, yes. But the post is about different clocks at different altitudes and different latitudes. Remember that I was answering Dmitry67's question. So, the clocks share the same [tex]\omega[/tex]
  • #78
starthaus said:
And he's right.
OK, I will concede this one. They are only interchangeable if [itex]\theta = \pi/2[/itex] which is what espen and pervect specified. It is often a practical convenience to orientate the axes so that this condition is met, a bit like orientating the x axes of two inertial frames with each other and parallel with the relative motion of the two frames in SR even though this is not the most general situation.
  • #79
Fair enough, now can you please answer the questions I asked in that post? Specifically the sentences ending in question marks.
  • #80
I think you explained it to yourself. [tex]\theta[/tex] gives you the latitude of the plane of the circle defined by [tex]0<\phi<2\pi, \theta=constant[/tex]. So, the angular speed is [tex]\frac{d\phi}{dt}[/tex], not [tex]\frac{d\theta}{dt}[/tex] that you keep trying to justify. You wrote it yourself , remember? [tex]\omega_1=\frac{d\phi_1}{dt}[/tex] and [tex]\omega_2=\frac{d\phi_2}{dt}[/tex] .
You are trying to justify the inadvertent replacement of [tex]\phi[/tex] (the correct coordinate) with [tex]\theta[/tex] (the incorrect coordinate).
If you insist on doing that, at least do it correctly, the new metric should look like this:
[tex]ds^2=(1-r_s/r)(cdt)^2-\frac{dr^2}{1-r_s/r}-(rd\phi)^2-(rsin(\phi)d\theta)^2[/tex]
So, you now have to make [tex]dr=d\phi=0[/tex] in order to get the time dilation and you are now obviously stuck with the term in [tex]sin(\phi)[/tex]
  • #81
They aren't interchangeable unless you are in the business of producing hacks.There is a reason for the presence of [tex]sin(\theta)[/tex] in the metric.
  • #82
That would only be the angular speed of a circle that happened to coincide with the equator (which would actually be [tex]\theta = \pi/2[/tex] rather than [tex]\theta = 0[/tex] as I incorrectly stated earlier). Do you disagree that any great circle on a sphere would correspond to a valid circular orbit, including a circle which could be divided into two halves of constant longitude (i.e. constant [tex]\phi[/tex]), or plenty of circles where neither longitude nor latitude were constant?
No, you're just not getting it. I specifically said that despite the fact that the coordinate systems are different, the metric would have exactly the same form in each one:
Do you understand the analogy with "different inertial coordinate systems used in flat spacetime"? If we have two coordinate systems in flat spacetime related by the Lorentz transformation, you'd agree that even though their coordinate axes point in different directions, they would both still have the same metric [tex]d\tau^2 = dt^2 - (1/c^2)(dx^2 + dy^2 + dz^2)[/tex], right? If you can understand that, you should be able to understand how two spherical coordinate systems with their axes pointed in different directions can nevertheless have the same metric too. I believe that's essentially what the "spherical symmetry" of the Schwarzschild metric means, just like the Lorentz symmetry of Minkowski spacetime can be taken to mean that the metric is unchanged in the different inertial coordinate systems related by the Lorentz transformation.
  • #83
And the only valid circular orbit (i.e. a circular path whose center coincides with the center of the Schwarzschild coordinate system at r=0) where [tex]d\theta = 0[/tex] is one in the "equatorial" plane where [tex]\theta = \pi /2[/tex], in which case [tex]sin(\theta) = 1[/tex]. Do you disagree?
  • #84
This is a nit but if you want the coordinate speed, both at arbitrary [tex]r[/tex] and at the "hovering point" [tex]r_0[/tex], you can get it from the file I pointed out to you.
You are banging on a nit, I call [tex]\frac{dr/dt}{\sqrt{1-r_s/r}}[/tex] a nothing, you insist on calling it "speed relative to a local hovering observer using local proper distance and local proper time". How you name it does not affect the final result and that result is unique, it falls out the Schwarzschild metric. Do you dipute that?
I think I have answered all your sentences that end with "?". :-)
  • #85
Yes, so what?
The point is that it doesn't. The domain for [tex]\theta[/tex] is [tex][0,\pi][/tex]. Do you dispute that?
  • #86
So what? There is an infinity of other circles that do not share [tex]\theta = \pi /2[/tex],.
None of these are captured by the solution that uses the truncated metric. Why is this so difficult for you to understand?
  • #87
Yes, I understand it very well, this is why I gave you the counter-example that shows what happens to the metric when you exchange the roles of [tex]\theta[/tex] and [tex]\phi[/tex].
The point is that kev used a truncated metric. Do you dispute that?
Using a truncated metric, he got a particular solution, that isn't valid in the general case. Do you dispute that?
I posted the general solutions for both orbital and radial motion using the full metric. Do you dispute that?
Both solutions are correct. Do you dispute that?
Heck, I even posted a superset of the solution , using the Kerr metric. Do you have any complains about it?
  • #88
You obviously don't understand at all, since doing a coordinate transformation which changes the direction the [tex]\theta[/tex] and [tex]\phi[/tex] axes point in, and then finding the new metric in this coordinate system, is NOT equivalent to switching the places of the [tex]\theta[/tex] and [tex]\phi[/tex] coordinates in the metric equation. My whole point is that the "spherical symmetry" of the Schwarzschild metric means you can reorient the [tex]\theta[/tex] and [tex]\phi[/tex] axes in arbitrary directions and the metric will always remain unchanged, just like the metric remains unchanged under a Lorentz transformation with an arbitrary choice of velocity. The wikipedia article on spherically symmetric spacetimes supports this by saying a spherically symmetric spacetime is often described as one whose metric is "invariant under rotations".
I don't know what you mean by "truncated metric". The metric gives the proper time along an arbitrary path, and kev was considering a circular orbit, so he could set terms like dr/dt and [tex]d\phi/dt[/tex] to 0, dropping some terms. You did exactly the same thing in your derivation, only with [tex]dr = d\theta = 0[/tex]. Is that all you mean by "truncated"?
  • #89
Missing terms right off the bat.
I understand very well, please stop talking down to me. I asked you a set of questions, would you please answer them as a set (all of them in one post)? Thank you
  • #90
There are no circular orbits where [tex]\theta[/tex] is constant (so [tex]d\theta[/tex] = 0) and has a value other than [tex]\theta = \pi / 2[/tex]. There are other circular paths where the value of [tex]\theta[/tex] is some other constant, but they are like circles of constant latitude on a globe (aside from the equator), the center of the path does not coincide with the center of the coordinate system and thus they are not valid free-fall orbits. Do you disagree?
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 31 ·
  • · Replies 18 ·
  • · Replies 16 ·
