Where is the center of the universe?
  • Context: Undergrad
  • Thread starter Thread starter JediSouth
    Center Universe
The discussion revolves around the concept of the center of the universe, particularly in the context of the Big Bang theory and cosmic inflation. Participants explore the implications of an expanding universe and the nature of space and time as they relate to the origins of the universe.
  • Some participants question where the center of the universe is if it began with inflation, suggesting that everything must have expanded from a single point.
  • Others argue that the universe appears homogeneous in all directions, implying that there is no center to the universe.
  • One participant uses an analogy of being on a mountain to illustrate that looking in any direction yields a similar view, supporting the idea of no central point.
  • Another participant mentions the cosmic microwave background (CMB) being uniform in all directions, which they argue contradicts the notion of Earth being at the center of the universe.
  • Some participants discuss the implications of the Big Bang, suggesting that every point in the universe could be considered a center, although this remains a theoretical perspective.
  • There is a challenge to the balloon analogy often used to describe cosmic expansion, with concerns that it implies a center of expansion that does not align with the current understanding of the universe.
  • One participant emphasizes that the Big Bang did not occur at a single point in space, as space itself was created during the event.
Participants express a range of views on the existence of a center of the universe, with some supporting the idea of no center based on observational evidence, while others maintain that the Big Bang implies a central origin. The discussion remains unresolved, with multiple competing perspectives presented.
Participants acknowledge limitations in understanding the universe's structure, including the implications of the Hubble horizon and the nature of cosmic expansion. There are also references to unresolved theoretical concepts such as dark matter and energy.
  • #31
russ_watters said:
No. The explosion analogy is not appropriate precisely because the Big Bang was not an explosion. That's a pop-media misconception.
Russ,
Thank you for your reply. I confess to having active subscriptions to pop-sci magazines, and nonetheless hope that you will readdress this issue,
Between 1965 and 1979 I did pioneering work in applying computer to technology, beginning with instrumentation and pointing control for the first space telescope and first ground based totally computer controlled instrument. My degree is simply a B.S. in physics, but I do have a minor paper on variable stars, co-authored of course. I read, learn, and argue, and during this time was seriously interested in the then-unresolved conflict between Hoyle's and LeMaitre's theories. (I have a yellowed paperback copy of Gamow's Creation of the Universe, deep in storage because I regarded most of it as unsupportable, illogical bunk.)
I never found either the steady-state or big-bang theory sufficiently logical to adopt, and never felt that it was necessary to choose between two opposing fallacies. I've kept track of the evolution of Big Bang theory as it rose to ascendancy. Until around the turn of the century, its precursor was regarded as very tiny "particle" containing all the mass/energy of the current universe.
That was an absurd and unprovable notion from the outset, and I angered many a righteous astronomer explaining why. But sure enough, eventually cosmologists figured out the same thing, and solved the problem by renaming their cosmic micro-pea (which, back then, had acccording to theory, blown up), a physical singularity.
Now since I've written pointing code for telescopes, I know what a mathematical singularity is. But a physical singularity is, in my not very humble opinion, invented nonsense. Its parallel in human thought is the omnipotent infinite God concept.
Of course you are correct, that the Big Bang could not have been an explosion, because a "physical singularity" cannot do anything, much less explode.
But, if the "singularity" did not explode, what have you renamed what it actually did? Inflated? Really?
Best I can tell, the expansion velocities of post-bang matter are sufficient to make a thermonuclear bomb analogous, by comparison, to the result of a drunken college student igniting his fart.
Most of us would call a really awesome explosion, at the very least, a "Big Explosion." Few would dub it inflation. I've inflated rubber boats, kiddie pools, and truck tires. I've set off firecrackers and tickled some dry nitrogen tri-iodide. I know the difference. When did Orwellian linguistics creep into astrophysics? More importantly, why?
Can we have a real discussion about this? Can anyone out there consider the possibility that current Big Bang theory is on a level with religious dogma, and that there must be a better explanation?
Space news on Phys.org
  • #32
hmm I have a quick question - if we make the big bang analogous to a huge explosion, then would that not that contradict the uniformity of the universe? A popular example of showing how the universe is a little different from the common definition of "explosion" is dropping a balloon full of paint - it splatters everywhere - with random blobs of paint clumped together, not a uniform filled in circle of the paint. From what I have heard the reason why the difference is imperative is our universe would be a very different picture if it was in fact an "explosion", for it would contradict evidence such as wmap, no?.. pardon my ineptness if my comments are incorrect or if I have misunderstood your post.
  • #33
The paint balloon analogy does not seem to fit. When the balloon hits the ground, it is subject to asymmetrical forces. The bottom will likely break while the top is intact. The paint will be emerging from a non-spherical container which flexes in process. Shards of rubber block the flow of paint.
A more approximate analogy might be a perfect sphere of paint sitting in deep space, with a tiny symmetrical explosive charge placed at its center that releases its energy in about 10exp-40 second. I suspect that this would produce an evenly distributed pattern of paint.
As for the WMAP images, I've looked at them again and again and keep wondering why astrophysicists insist that they show a symmetrical energy distribution. There are blobs and lumps all over the place. I make it a point to keep in practice recognizing such things by studying a centerfold image monthly. Haven't lost my skills. The WMAP images look to me like the result of a sloppy, asymmetrical paint balloon explosion.
Thanks for your reply. Please don't worry about sharing your thoughts with me. I don't treat PF like a physics class where the answers are in the professor's private supplementary text. The PF is a place where awesome ideas could be formed if people share their honest thoughts and best ideas, post interesting questions and expect a variety of answers.
  • #34
Science relies on observational evidence to formulate theory. The big bang concept is supported by a vast body of observational evidence. Liking the evidence is optional. The burden is on dissenters to formulate a theory that more cleanly fits observation.
  • #35
Which kind of journal, if I may ask? And which kind of practice? :blushing:
Yeah, great. Maybe sometimes you'll find the scale of these false color pictures. Try http://www.astro.ucla.edu/~wright/CMB-DT.html" for a start..
  • #36
Awesome link! Thank you! There is obviously more I can learn there before coming back on this issue. So, I will be getting back to studying.
Back in '75 when we were developing the imaging technology, we called it pseudo-color. "False color" is upfront and honest.
It never occurred to me to check the scale, which was stupid. (Of me, not the scale.) A difference of 0.018% seems downright negligible.
One curiosity, which I did not find answered on the page--- Is the low effect of galactic emission the result of a limited instrumentation bandwidth?
I appreciate your assistance and sense of humor, equally welcome.
  • #37
Actually, I had thought that BB theory was derived from observational evidence, more a half vast body, but good evidence nonetheless.
I find the theoretical basis for the BB an issue. I do not believe in physical singularities or omnipotent gods. What caused the "singularity" to become a universe? Did it suddenly "decide" to become unstable?
Physics works as an effective combination of observation and theory. In the instance of the origin of the universe, I find good reasons to seek a theory which does not include a mystery hypothesis. Religion does that quite well already.
  • #38
Yes, they're measuring in the microwave region only. You get a relatively undisturbed signal there.
Thanks, my humor is normally lost in translation, so I'm happy I could get through with it for once.
You know, BB theory works backwards. We see the evidence now, obviously, and trace back the history. And there was definitely something hot and dense. This knowledge is independent of musings about the origin.
You could also start from the beginning with the exact moment we know nothing about. But that's not science, that's philosophy or religion.
  • #39
Me too! I suspect that your style of humor will generally be lost on those who take themselves seriously.
I find the method by which we've derived BB theory fully plausible. But, where it gets us does not feel right. I don't mean feeling in the emotional sense, but in the logical sense.
It seems to me that if we got there from here, we should be able to get here from there. That does not appear to be the case. This makes BB theory logically asymmetrical.
Then there is the persistent observation that we live in a cause-effect universe; where then is the Big Bang's cause?
50 years ago I gave up my belief in God for several reasons, one in particular being the absurd motivations attributed to this entity for the creation of mankind. BB theory seems to me to suffer from the equivalent failing--- lack of plausible cause.
Wherever we start can be fairly regarded as an hypothesis. Whether an hypothesis becomes the core of effective physical understanding, or the basic dogma of another religion, depends upon what we do with it.
If we can derive it mathematically from a bit of observational evidence, and test it empirically, then it's usually science. If it predicts something we'd otherwise not have known, then it is almost certainly science.
But if we insist that an hypothesis came inscribed on golden tablets, since removed to heaven, and cannot possibly test it, then it's religion.
If we wake up some morning suddenly knowing the secrets pf the universe, and wrap a bunch of coherent polysyllabic words around our notions but never bother to test any assumptions or trouble ourselves with predictions, we've got another philosophy.
IMO BB theory is in the neverland of what I'd call, physical theology. While derived by scientists, it lacks some properties which we normally associate with sound science. Moreover, the Big Bang's mysterious precursor shares more characteristics with the God of Christianity than with any known physical phenomenon. (Mysterious or non-existent origin, containing/creating all matter and energy, yet doing so without credible cause or purpose.)
Something's not right with BB theory.
  • #40
The singularity part is still conjecture. A number of prominent physicists currently suggest alternatives. Given that [according to most physicists] time [in this universe] originated with the BB, your causal complaint is irrelevant.
Feel free to submit your alternative explanation that fits the body of evidence.
  • #41
The original big bang theory is just the claim that the large-scale behavior of the universe is described by a member of a particular class of solutions to Einstein's equation. The theory that's built up around that equation (general relativity) describes an enormous range of phenomena including but not limited to: objects falling to the ground, the orbits of planets, the decay rates of fast-moving elementary particles, the fact that two clocks on different floors of the same building are ticking at different rates, redshift of distant galaxies (given that matter is distributed homogeneously and isotropically across the universe), the rate by which the frequency of a pulsar is changing (due to emission of gravitational waves). It makes predictions about all those things, predictions that are almost absurdly accurate. And you think the theoretical basis isn't sound!? That's very naive. This is the best theory in all of science, except possibly for quantum mechanics.
It's not a hypothesis. It's what the theory (general relativity) says must be the case if matter is distributed homogeneously and isotropically. (And according to the singularity theorems, if matter is distributed in any way that resembles what we see through a telescope). The comment about religion is just silly. You should probably refrain from making condescending remarks until you have some idea what the various big bang theories are saying.
That's clearly an emotional argument, not a logical one.
Even if all events have a cause, that principle doesn't apply to the big bang (in the original big bang theory) since the big bang isn't an event. There's no first event in the big bang theory.
That's absolutely false. No one who understands the big bang theories or knows what science is would make a claim like that.
  • #42
Fredrik said:
... Even if all events have a cause, that principle doesn't apply to the big bang (in the original big bang theory) since the big bang isn't an event.
If it isn't an event could you tell us what it is?
  • #43
You may well be correct, but would you kindly explain why the non-existence of time eliminates the need for a cause--- specifically some force which rendered the micropea or singularity unstable?
Good plan. I came up with a few strange ideas a few days ago while being kicked around by Darwinists on a statistical thread, and they seem promising. (The ideas, not the Darwinists.) It will take a few months to work them out and put them on paper, and getting them published if they do work out seems an uphill struggle, but I will definitely follow your suggestion. Thank you!
  • #44
but the History Channel said there is a center point from where the Big Bang occurred and they had various scientists on there as well...is the History Channel wrong? are the scientists on there wrong? must i not watch History Channel? :(
  • #45
I'm here to learn, and appreciate your sharing your understanding with me. I'll do my best to honor that with honest questions, which by my standard, are those which I think are important, and to which I do not have the answers. It has been a long time since I learned what I could about general relativity, and my math skills were not up to the job of understanding either its full derivation or its implications. I am aware of most of the effects you mention, and like you, I've marveled at their powerful predictive value. (That's real science!) But isn't time dilation, the most notably accurate of Einsteinian predictions, described by special rather than general relativity?
I'd not known about the pulsar frequency changes. Nor was I aware that gravitational waves have been experimentally detected. I imagine that this would not be essential to pulsar theory, but have noted that all too often, things which cannot be detected turn out not to exist.
Perhaps more relevant, I thought that general relativity can be interpreted as leading to the possibility of a Big Bang, not that it necessarily does so. Moreover, it cannot solve the initial condition problems. Envisioning a collapse of the universe if we run time backwards, it seems clear that time is greatly affected by the concentration of mass-energy in a tiny space. I'd expect the general relativity equations to collapse well before the universe became (running time backwards) the size of a golf ball, and to become absurd afterward.
Also, the concentration of all mass-energy in a tiny space will produce the great grandmother of all black holes, a black hole without an event horizon, and the absence of time would preclude quantum effects at the event horizon from evaporating the hole.
Do you know if these issues have been dealt with theoretically, and where I might locate the papers?
Clearly, the cosmological view of homogeneity differs from mine. I look into the universe and see subdivisions of lumps. If I poured out a bottle of homogenized milk with as many lumps as our solar system, or galaxy, I'd toss it as being spoiled.
Perhaps I should clarify it. If we can determine theoretically that there must have been a Big Bang (getting there from here), then we should also be able to determine, theoretically, why the Big Bang occurred. (Getting here from there.) I honestly do not understand what is emotional, or non-logical about that proposal. Clarify, please.
The "no event" notion smacks of religious beliefs in an omnipotent God who always existed without origin or cause, always knowing everything.
Nickelodion has replied to this more cogently, and I hope that you will answer him.
There, you are nearly correct. I will put my understanding of what science is, at both the ideal and practical levels, up against yours or anyone's. But I've been out of practice for a few decades, so lay no claim to actually being any kind of scientist, despite having done a fair amount of it.
You are correct in that I do not understand Big Bang theory. This could be because I am stupid, or could also be because Big Bang theory is not correct. I'm asking questions in hopes of correcting one or both of these issues.
  • #46
IMO the History Channel does a lot of what I'd call, "speculative science." They are more imaginative than NitGeo, and I appreciate their willingness to explore ideas openly.
I also think that there are many fields of inquiry which mankind has pursued since our beginning, which are now dominated by scientists instead of theologians and philosophers. This is a potentially good thing, but I am noticing that many science followers take the same dogmatic attitude to the currently approved theories that religionists apply to their own beliefs. This is not a good thing, because dogmatism always stifles creative thought.
So, if you truly believe that science has correctly answered all important questions about the beginning of the universe and the origin of life, Thou Shalt Not Watch the History Channel. Else, perhaps Thou Must Watch It.
  • #47
but science has not answered all important questions about universe and life...just theories and possible explanations for mostly everything...that keep changing everyday due to new discoveries...hence making us buy new textbooks every semester
  • #48
I did not take the time to read all posts, so someone may have pointed this out: If there is an edge to the universe, then there is a center. If there is no edge to the universe, then it is infinite, and there is no center.
But, would not expansion imply that there is an area outside of the universe to expand into? Or, if it is infinite, expansion is within and along the line of infinity?
I need to nap now, i overtaxed myself.
Having a center does not mean that it is a fixed point, as expansion may be uneven.
  • #49
It can be finite without having an edge. Think of the surface of a sphere for example.
No. Think e.g. of an infinite line with distance markings on it, and imagine the distance between the markings growing with time. The scale is changing, but the total size isn't.
It's a mathematical property of a class of solutions of Einstein's equation. It can be characterized in many different ways. The most interesting detail is that the distance between two objects that stay at fixed coordinates in space goes to zero as the time coordinate goes to zero.
Each solution of Einstein's equation defines a spacetime. We're talking about a class of solutions, so we're also talking about a class of spacetimes. An event is a point in spacetime. A coordinate system is a function that assigns four coordinates (t,x,y,z) to each event. There's a specific coordinate system that's very convenient to use when we're dealing with these spacetimes. When I mention coordinates, that's the coordinate system I have in mind. If I e.g. mention "the time since the big bang", what I'm talking about is the t coordinate assigned by that coordinate system. (Everyone who understands this does the same thing. That phrase is defined to mean precisely that).
It's very important to understand that there is no event in any of these spacetimes that's assigned t=0 (or t<0) by this coordinate system.
There are lots of garbage claims in documentaries about these things, but I doubt that they had astrophysicists on the show who said that. It's definitely wrong.
Special relativity is one specific solution of Einstein's equation. There's time dilation in all of them.
They haven't. GR predicts that the frequency will change because energy is lost in the form of gravitational waves, and that prediction has been verified to an absolutely ridiculous degree of accuracy, by measuring the frequency.
All homogeneous and isotropic solutions have an initial singularity. That was known in the 1920's. The singularity theorems of Penrose and Hawking showed that a much larger class of solutions have initial singularities.
You're right that GR isn't expected to be accurate for very small values of t. But that's not a reason to think that your intuition about what things are like under those conditions are any better than GR. The theory that describes time in an intuitive way is Newtonian mechanics in Galilean spacetime. That fact that its predictions about results of experiments are much worse than the predictions of GR proves that our intuition is wrong about the properties of time.
If you mean the issues at times when GR doesn't hold, then no. Those require a quantum theory of gravity. If you're saying that GR says that the early universe would have turned into a black hole, that's just wrong. The solutions that say that a large concentration of mass in a small region will form a black hole, are only telling you what would happen if the rest of the universe is empty. In the "big bang solutions", the density is the same everywhere. It's a very different scenario.
It's approximately homogeneous and isotropic on large scales, but not on small scales. (Here "small" can mean millions of light-years). That's why the universe is expanding on large scales (distances to far away galaxies are increasing), but not on small scales (e.g. in the solar system).
Do I really need to clarify why "it seems to me" isn't a logical argument?
GR describes the relationship between how matter is distributed in spacetime and how it must move. If you plug in the (approximate) current distribution of matter, the resulting description of its motion includes a big bang (which is a property of spacetime, but not an event in it). The singularity theorems prove that it's not an artifact of the approximation.
This theory is also the best theory of time that we have. Experiments have proved that our intuition about time is wrong (certainly much more wrong than how this theory describes time). So it makes absolutely no sense to argue that there must have been a time before the events that these solutions mention.
To ask "why" there was a big bang (of the sort described by this theory), is to ask why Einstein's equation is an accurate description of the relationship between the distribution and motion of matter. That's a perfectly valid question, but you have to understand that it can only be answered by another theory.
That's the kind of comment I would expect from a creationist who isn't at all interested in learning what this theory says or what a theory is. (Edit: I changed this comment a bit because it sounded too aggressive).
Those are not the only two options. And to prove a theory wrong, you have to perform experiments. Just asking questions isn't going to do it.
  • #50
Thanks for your extensive replies. I have difficulty trying to picture the Big Bang as a property of a class of solutions of Einstein's equations. Sorry but my maths is not up to much - by 'class of solutions of' do you mean 'subset of formulas derived from'? If you can't assign the value t=0 to the formulas, presumably due to fear of infinities, but you can assign t=0 + a miniscule amount, then it still feels like an event to me.
Einstein is reported to have said 'Most of the fundamental ideas of science are essentially simple, and may, as a rule, be expressed in a language comprehensible to everyone'. I guess this example is the exception :-(.
  • #51
I mean a subset of the set of all solutions to Einstein's equation. Each solution describes a spacetime, so I'm talking about a subset of the set of all possible spacetimes. Specifically, the set of all 4-dimensional spacetimes that can be "sliced" into 3-dimensional "spacelike hypersurfaces" (sorry about using another technical term) that are are all homogeneous and isotropic (in a technical sense). We can think of these hypersurfaces as "space, at different times". If we label them with a parameter t>0, it's a fact that in any of these spacetimes, the distance between any two objects that are "floating freely in space" (like two galaxies) goes to zero as t goes to zero.
The value of this parameter t is assigned in a way that ensures that the word "time" is appropriate.
I suppose it does, but we're talking about the theory that tells us what time is, so we can't assume that time has different properties than what the theory is saying. If the theory doesn't even mention a t=0, how can we?
I can think of lots of examples that are much worse than this.
  • #52
Yes there were astrophysicists, theoretical physicists, cosmologists, etc. etc...but even if the astrophysicists on there didn't say something like that, the fact that they were on the show i think implies that they clearly support the idea and have nothing against it...otherwise why would they be part of it?
  • #53
Selective editing quite often completely changes what someone actually said.
  • #54
Fredrik said:
That's exactly the kind of ridiculous and insulting nonsense I would expect from a creationist who isn't at all interested in learning what this theory says or what a theory is.
Fredrik,
You've provided excellent and well-considered replies to most of my questions. Thank you for both understanding and direction.
I'm not particularly interested in proving any theory wrong. I'm a theorist (and I do seriously care about what a theory is), probably because budget limitations have precluded the purchase of my own space telescope. I'm asking questions not to be a pest, but in hopes of finding the right theoretical direction. Only a crackpot would develop a theory which skirts evidence, or attempts to re-explain something which is already fully covered by a well-proven existing theory.
After more thinking I may come up with other questions, and will take the liberty of apprising you accordingly in case you care to engage them. You set a high standard for this forum. Thank you.
  • #55
huh?
  • #56
Fredrik said:
All homogeneous and isotropic solution have an initial singularity.
All expanding homogeneous and isotropic solutions with sufficient matter/radiation density and appropriate conservation laws have an initial singularity.
There are solutions without an initial singularity or without singularities at all, but they don't match observational evidence (with the possible exception of some inflationary models).
It doesn't matter anyway, the singularity itself is not part of the Big Bang model. The hot, dense state at the beginning is undoubted.
  • #57
Some of them are probably really bad at finding appropriate ways to simplify what the theory says. And I assume that most of them don't know if it will be a good documentary or a bad one when they're being interviewed, so I don't think the fact that they agreed to be in it means anything.
  • #58
blank.black, here is a hypothetical example. A scientist is approached about giving an opinion on black holes for a show. After they are filmed, the title of the show turns out to be "black holes don't exist". The footage of the scientist is cut into snippets and a narrator makes comments and then out of context snippets from the scientist are inserted, making it sound like the scientist is backing the narrator up. This happens not only in films and documentaries, but in written articles for popular news and magazines.
I'm not saying this happens frequently, but it seems to happen a bit too often, and to varying degrees.
  • #59
  • #60
Thank you.
Yes, a circle or surface of a sphere has no edge or start/stop point.
But a sphere does have a boundary/edge. And we are speaking more of a sphere, which i think has an edge/boundary, moving though it may be. There are many references to the universe's edge by astrophysicists. What are they referring to?
As for the universe expanding without changing size, that makes no sense.Though i admit that such a thing may be possible in this strange universe. Where are the galaxies on the edge of this universe going as they move away from all the others? Distances between galaxies is real, is it not?
Unless you insist that expansion without a change in size is occurring.
Maybe the math that these theories are derived from does not compute using analogies. But, thanks for the effort.
  • · Replies 20 ·
  • · Replies 44 ·
  • · Replies 21 ·
  • · Replies 23 ·
