Electrical Engineering- Capacitor Resistor Circuit
The discussion revolves around a capacitor-resistor circuit in the context of a homework problem from an electrical engineering course. Participants explore the behavior of the circuit when a switch is closed, specifically focusing on the conditions required to maintain a voltage above 4.9 volts across the resistor for a duration of 1 millisecond. The conversation includes theoretical considerations, mathematical reasoning, and practical implications of circuit behavior.
  • Homework-related
  • One participant outlines the circuit and asks for help in determining the minimum capacitance needed to keep the voltage across the resistor above 4.9 volts when the switch is closed.
  • Another participant suggests that the RC time constant must be sufficiently large to ensure minimal voltage drop across the resistor, emphasizing the need to consider the charging and discharging equations of capacitors.
  • Several participants discuss the implications of assuming constant current discharge versus time-varying discharge, noting that the latter has not yet been covered in their coursework.
  • One participant mentions that the textbook provides a specific capacitance value of 198 micro-Farads and seeks assistance in deriving this value using the equations provided in the text.
  • Another participant encourages the use of Kirchhoff's Voltage Law and suggests rearranging equations to express capacitance in terms of known quantities.
  • Some participants express frustration over the timing of the problem in relation to their coursework, indicating that the topic of transients has not yet been introduced.
  • There is a discussion about the nature of models in engineering, with one participant noting that assumptions can significantly affect the validity of a model.
Participants express a range of views on the assumptions made in the problem, particularly regarding the treatment of current and voltage as constant versus time-dependent. There is no consensus on the best approach to solve the problem, and the discussion remains unresolved regarding the implications of these assumptions.
Participants note that the problem involves assumptions about the behavior of capacitors that may not align with the theoretical understanding of transient responses. The discussion reflects a mix of theoretical and practical considerations, with some participants feeling unprepared due to the timing of the topic in their curriculum.
This discussion may be useful for students studying electrical engineering, particularly those grappling with concepts related to capacitor-resistor circuits, time constants, and the implications of different modeling assumptions in circuit analysis.
n00bcake22
Electrical Engineering-- Capacitor Resistor Circuit
Hello all. First time posting so excuse any fourm faux pas I may make. I was wondering if anyone could lend some help with the circuit below (ignore the *, they are just space holders to prevent reformatting of the circuit):
|*****C*****C*********R********** |
****************Switch
Here are the details of my question:
C1=C2=C (value unknown, used as the energy source, and both charged to 2.5V initially)
R=500 Ohms
Question: Find the minimum value of capacitance such that when the switch is closed at t0 = 0 to t=1ms, the voltage across the resistor (R) does not drop below 4.9 Volts. Please show/explain equations and work.
Below is what I have (let me know if any of it is wrong):
Kirchhoff Voltage Law
- v_c - v_c = v_r
2 * v_c = v_r
Inserting voltage equations for v_c and v_r
2 * ( 1/C * Integrate( i_c(t) dt, t0, t) + v_c0 ) = i_r(t) * R
Series circuit so i_c(t) = i_r(t) = i(t)
2 * ( 1/C * Integrate( i(t) dt, t0, t) + v_c0 ) = i(t) * R
Now I'm stuck; how can I express i(t) as a function of knowns and/or C.
Thanks again for all the help!
I've attached a paint picture of what I think you were aiming for, which came out looking weird on my screen.
Essentially, you need to find a value of capacitance for the circuit so that when the switch is closed, the RC time constant is sufficiently large so that less than 0.1V is discharged, i.e. more than 4.9V across the resistor at all times during the 1ms that the switch is open.
This forum has a knowledge repository which is quite useful, here is a link to the section on capacitors:
https://www.physicsforums.com/library.php?do=view_item&itemid=112"
Specifically, if you check out the voltage and current charging/discharging exponential equations, you may be able to rearrange and solve. Additionally, keep in mind how voltages in series combine, and how capacitors in series combine.
I appreciate the help. This question is actually Problem 3.26 in Electrical Engineering: Principles and Applications, 3rd (Hambley). Up to this point, transients (and, therefore, time constants) have not been discussed (covered in the next chapter) so I was wondering how to come up with the correct answer using what has been covered thus far. If anyone else could offer some advice I would really appreciate it. Below are the "primary" equations for capacitors offered so far by the text (note: i will use _ to indicate subscript, i.e. v_0 would stand for initial voltage):
q = C*v : (q= charge, C= capacitance, v= voltage)
i = C* dv/dt : (i = current)
q(t) = integrate(i(t) dt, t_0, t_f) + q(t_0)
v(t) = 1/C * integrate(i(t) dt, t_0, t_f) + v(t_0)
w(t) = 1/2 * C * (v(t))^2 : (w(t) = stored energy)
w(t) = 1/2 * v(t) * q(t)
w(t) = (q(t))^2 / (2*C)
The book states that the correct value for C is 198 micro-Farads. If anyone could help me out with how to arrive at this answer using the above equations and basic circuit laws (KVL, KCL, etc.) I would really appreciate it. Thanks again everyone!
Well, let's not let a little thing like having not been taught get in the way! How are you with algebra and calculus?
Using Kirchoffs Voltage Law around a closed loop (assuming the two capacitors voltages are adding together to create one source for now), your original equation is slightly wrong.
After you correct it, see if you can rearrange those voltages into currents and resistances.
Next, see if you can solve the differential equation.
Next, rearrange the result of this differential equation algebraicly to get C as your target.
Next, stick in the values and solve.
Keep in mind the way capacitors combine in series, and presto chango you should see ~197.99uF. This is a very 'first principles' and mathematical way of doing things, and hopefully you won't have to do it too often, because its difficult and time consuming and really only needs to be done to see how much nicer it is when you can jump to the final equation instead of doing it all from scratch.
Hello again. Well, I was able to get a look at the solution and they did some simplifying of the problem. They "assumed" a constant current discharge instead of time variant (which makes sense, I suppose, as they haven't yet discussed transients) and that's where I ran into my little conundrum-- knowing that, in reality, that is not the case.
Thanks again for all your help. I am a mech. eng. so I get to have a super crash course in EE with little time to digest each topic before being rushed onto the next. Sigh... time to dig up my old electromagnatism text. Yahoo!
So that was just rearranging [tex]I\ =\ C\frac{dV}{dt}[/tex] for C and plugging in the numbers? Turns out that that is a reasonable approximation in this case.
Sorry for overly complicating things, I thought I was helping an EE! Good luck with the next topic too.
Yeah that is exactly what they did, but in a rather strange way (they fixed both current and voltage throughout the delivery pulse--which makes no sense for a capacitor... right?). In my opinion, this was a terrible problem to have without first discussing transients (they should have saved it for the following chapter). It was an unnecessary, oddly worded problem.
Anyways, thanks again Zryn for all your assistance; btw, I actually enjoy the "complexity" of engineering. It's amazing how much better you understand the material once you understand all of the underlying theory and mathematics.
All the best!
p.s. I'm going out on a limb here. This website... best find in 2010!
Well, any model representing something (capacitors for example) can be "correct" depending on the assumptions that govern it. Not defining those assumptions makes the understand part a bit difficult though.
In reality both current and voltage are not fixed throughout the delivery pulse indeed. In theory they discharge as a time dependent exponential ... which is asymptotical around zero and thus takes infinite time to reach ... and yet in practice they do reach zero within five (ish) time constants. there's always assumptions.
And I concur, this website is a strong contender for my best find in 2010 too!
  • · Replies 16 ·
  • · Replies 28 ·
