Register to reply
Can commutativity of multiplication and addition under real numbers be assumed?
Share this thread:
sapnpf6
#1
Sep27-10, 05:44 AM
P: 3
1. The problem statement, all variables and given/known data
so.. let the operation * be defined as x*y = x + y + xy for every x,y ∈ S,
where S = {x ∈ R : x ≠ -1}. Now i have proven associativity, existence of an identity and inverses, all without commutativity, but i must show that this is an abelian group, so now i have to show commutativity. I know that multiplication is not always commutative, but i am not using matrices, just reals/{-1}.
2. Relevant equations
the operation * is defined by x*y = x + y + xy.
3. The attempt at a solution
i simply say that first, addition is commutative on the reals, so x+y=y+x, by the commutative law of addition of real numbers, and second that xy=yx, by the commutative law of multiplication of real numbers. this would show that x*y=y*x. Is this allowed or do i have to show commutativity without assuming addition and multiplication are commutative on real numbers? and if i have to show commutative without the assumptions above, can someone point me in the right direction on the proof?
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
sapnpf6
#2
Sep27-10, 06:08 AM
P: 3
in case i did not show enough of an attempt at a solution, here is a more detailed attempt summary...
the operation * is commutative if for every x,y∈{x∈R:x≠ -1} such that x*y = y*x.
But, x*y = x + y + xy, and
y*x = y + x + yx,
= y + x + xy (by commutative law of multiplication of real numbers)
= x + y + xy (by commutative law of addition of real numbers)
So x*y = y*x, and thus, * is commutative.
this is my original solution but i am not entirely sure whether it holds up. it seems like using the law of commutativity of multiplication/addition of real numbers might be too "flimsy" to use in this kind of proof. it would sure be great if i could hear some feedback.
VeeEight
#3
Sep27-10, 06:10 AM
P: 611
You are correct in your reasoning. If x*y = x+y + xy, then y*x = x+y +yx, which holds since addition and multiplication are commutative in the reals.
sapnpf6
#4
Sep27-10, 06:14 AM
P: 3
so it is not necessary to prove commutativity of addition or multiplication in real numbers here? just making sure...
HallsofIvy
#5
Sep27-10, 07:33 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,357
No, you do not have to "reinvent the wheel" for every problem. You do not have to prove the properties, that have already been proven, for the "usual" operations on the real numbers. if you are given some new operation, defined using the "usual" operations, you can assume all of the properties of the "usual" operations in order to prove (or disprove) those properites for the new operation.
Register to reply
Related Discussions
Commutativity of Tensor Field Multiplication Special & General Relativity 11
Checking commutativity property with addition table General Math 4
?, exponentiation, multiplication, addition, ? General Math 5
Multiplication=addition 2*2=2+2=4 Linear & Abstract Algebra 12
Multiplication and Addition General Physics 25
