| Thread Closed |
Water flow true a hole. |
Share Thread | Thread Tools |
| Oct13-10, 03:42 AM | #1 |
Hello every one.
This is my first post here so be gentle if i placed my topic in the wrong section. My problem is as following. I am trying to calculate the speed of the water wich exits true a metal plate full of cirkulare holes. The metal plate is square and and has 14 holes each with a diameter of 14mm. On top of the plate is a watercolum with a total hight of 50cm. The water runs true the plate in to free air so there is no pressure working against the flow. I want to use the calculated speed of the water to make a graph wich shows water mass on the x-axis and pressure drop on the y-axis. I have come across following formulas: Volume = surfuce area of holes * speed of water press loss = zeta * (1/2)*zeta*water speed^2 I am not sure that the last calculation is correct and i have bin unable to find the zeta value in any books of mine. im guessing its a value wich relates to the size of the hole and the dynamics of water. I have that some of you can give me a push in the right direktion. Sorry for spelling errors. Best regards. |
| Oct13-10, 03:03 PM | #2 |
This is how I would do it:
In the following pictures, there are the following quantities: p - pressure [N/m^2] rho - density of water [kg/m^3] v - speed of flow [m/s] z - height of a water particle before and after the hole (the difference is approx. 0) The weird greek letter for which I can't remember the name at the moment is a coefficient of losses for this very case ( = 1.8). I got that from my engineering handbook. Don't forget the following:
Have fun, kandelabr |
| Oct13-10, 06:55 PM | #3 |
Recognitions:
ZalienMC: Assuming you have atmospheric pressure above the water surface in the tank, the drainage hole stream exit velocity, and the total flow rate, as a function of tank water depth, are as follows.
v = [2*g*z/(1 + ko)]^0.5 = Cd*(2*g*z)^0.5 = 2.6572*z^0.5,where v = drainage hole stream exit velocity (m/s), z = tank water depth (m), Q = total flow rate (L/s), ko = 1.778, Cd = 0.60, g = 9.8067 m/s^2, and d = drainage hole diameter = 0.014 m. E.g., if z = 0.500 m, you have v = 2.6572*0.500^0.5 = 1.879 m/s, Q = 5.7265*0.500^0.5 = 4.049 L/s. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Water flow true a hole.
| Thread | Forum | Replies | ||
| flow problem with a two diemsional water flow divider | Mechanical Engineering | 0 | ||
| Tap water flow and water diameter at end of it (Bernoulli eqzn...) | Introductory Physics Homework | 4 | ||
| rate of flow through a hole | Advanced Physics Homework | 4 | ||
| flow over a hole | Mechanical Engineering | 1 | ||
| HELP! relationship between rate of flow of water and height of water column | Introductory Physics Homework | 1 | ||
