The Stress part of the Stress - Energy - Momentum Tensor
The discussion revolves around the nature and implications of the stress-energy-momentum tensor in the context of general relativity. Participants explore the roles of stress, shear stress, and pressure within the tensor, as well as their effects on spacetime curvature. The conversation touches on theoretical concepts, mathematical representations, and hypothetical scenarios related to the tensor's application.
  • Some participants express confusion about the role of stress and shear stress in the energy-momentum tensor, questioning whether stress refers to the influence of mass on spacetime.
  • One participant suggests that stress is mechanical stress acting on physical objects, which can have an "anti-gravitational" effect that opposes pressure effects.
  • Another participant discusses the distinction between pressure and stress, noting that pressure is an external push while stress is an internal pull, with both having the same units.
  • There is a proposal that if the components of the stress-energy tensor are equal, it represents pressure, while unequal components indicate stress.
  • Some participants mention the relationship between shear stress and viscosity, suggesting that shear may not contribute to gravitational effects in static conditions.
  • Questions arise about whether the stress-energy tensor can represent an entire object or only small elements, and whether metrics are derived from summing multiple tensors.
  • References to external sources, including Wikipedia, are made to clarify concepts related to the stress-energy tensor.
Participants generally express uncertainty and confusion regarding the definitions and implications of stress, shear stress, and pressure within the energy-momentum tensor. Multiple competing views and interpretations remain, particularly concerning the effects of stress and shear on gravitational measurements.
Some limitations include the dependence on definitions of stress and pressure, as well as unresolved mathematical steps regarding the application of the stress-energy tensor in different scenarios.
WannabeNewton
Hey guys I'm having trouble understanding the full nature of the energy momentum tensor. I understand the whole "matter flow and energy flow" affects the curvature of the space time metric being used. What I don't understand is the role of stress and shear - stress. Is the stress being described the stress that the mass places on space - time? Thanks.
Remember how 0,1,2,3 correspond to different components of the Stress energy momentum tensor. mu can be thought of the energy time component and nu can be though of the momentum, x,y,z components.
Also remember, that pressure is the external push and stress is internal and pull. So we can think of pressure as T11, T22, and T33. Ever component against itself that does not include energy density is stress. Energy density, pressure, and stress also have the same units.
Energy density = Energy / Area * Distance
Energy density = Force * Distance / Area * Distance
Energy density = Force / Area
Pressure = Force / Area
Stress = Force / Area
Cool thanks. Just another quick (kind of unrelated) question:
If one wants to solve the field equations for a particular Energy Momentum Tensor then would one introduce that tensor into the equations solving for the metric? I'm asking because doesn't the metric also determine energy - momentum distribution? Or do you use a metric that would best suit the kind of mass distribution you wish to solve for and then solve to find the metric of the space - time with that specific mass distribution? (Like in the case of the schwarzschild metric where you use static spherical mass distribution and the metric for spherical coordinates) - sorry for sounding like a completely confused idiot.
Hi WN, this is my very casual superficial understanding that I am posting in the hopes that some real expert can correct/refine what I am saying here. The stress is mechanical stress acting on a physical object and its effect on gravity acts in the opposite sense to the pressure terms. For example if we had a spherical shell with a nuclear bomb inside it and if the shell was strong enough that it could contain the explosion, then the gravitational measurements outside the sphere would be the same before and after the explosion. The increase in pressure inside the sphere due to the explosion results in increase in the (shear?) stress in the skin of the shell as it resists the pressure. The increased stress has an "anti-gravitational" effect that offsets the effects due to increased pressure. I think it would be impossible to design an anti-gravity machine based on the negative stress effect because it would be impossible to design a system that had significant stress without it having more significant pressure/energy/mass. Like I said it is just a superficial understanding that may be way off the mark, so feedback would be welcome and might be helpful for both of us.
yuiop said:
Hi WN, .. For example if we had a spherical shell with a nuclear bomb inside it and if the shell was strong enough that it could contain the explosion, then the gravitational measurements outside the sphere would be the same before and after the explosion. The increase in pressure inside the sphere due to the explosion results in increase in the (shear?) stress in the skin of the shell as it resists the pressure. The increased stress has an "anti-gravitational" effect that offsets the effects due to increased pressure...
The stress in the shell will be bi-axial tension - which is not shear but negative pressure. Some links dealing with that sort of thing: http://arxiv.org/abs/gr-qc/0505040" The role of shear in the energy-momentum stress tensor was my first question on this forum. Apart from my own observation that static shear stress in a solid aught to make no contribution (shear can be resolved into orthogonal tensile and compressive stresses that cancel as sources of 'gravity'), no satisfactory answer was offered. There seems to be some link to viscosity (turbulence in fluids?), but it is hard to find anything clear and specific.
The wikipedia page on the stress-energy tensor http://en.wikipedia.org/wiki/Stress–energy_tensor sheds some light on this.
It states that "[itex]T^{ii}[/itex] (not summed) represents normal stress which is called pressure when it is independent of direction." where i ranges from 1 to 3 as indicated by the diagonal green "pressure" band in the diagram.
These may be a key observation. The "bi-axial" forces in the shell are classed as stress, but if the forces are equal in all directions then it is classed as pressure. Would I be right in thinking that if [itex]T^{11}=T^{22}= T^{33}[/itex] then that represents pressure, but if those elements are not equal, then it represents stress?
Wikipedia also states the orange triangular sections of the tensor diagram [itex]T^{ik}, \quad i \ne k[/tex] represents shear stress so the shear stress components are distinct from the normal stress components. The same components are sometimes described as viscosity in other references and presumably the distinction depends on whether we are talking about solids or liquids, even though that distinction is not always clear cut. <br /> <br /> Wikipedia also hints that the "box" labelled "momentum flux" in the above diagram is basically the same as the stress tensor used in engineering.<br /> <br /> Also, if we had a large planet sized sphere, would I be right that in thinking that a stress-energy tensor cannot represent the whole object but just some small finite (infinitesimal?) element of the large object? Is a metric basically the result of summing numerous stress-energy tensors that make up the composite whole?[/itex]
yuiop said:
The wikipedia page on the stress-energy tensor http://en.wikipedia.org/wiki/Stress–energy_tensor sheds some light on this...It states that "[itex]T^{ii}[/itex] (not summed) represents normal stress which is called pressure when it is independent of direction." where i ranges from 1 to 3 as indicated by the diagonal green "pressure" band in the diagram.
You are correct in that strictly speaking pressure is defined as uniform triaxial stress. What I had in mind was that for a thin shell incapable of supporting any radial stress, uniform bi-axial stress can be thought of as a 2D 'pressure'. For a thick shell circumferential stress differentials in the radial direction apply, though there is still no shear.
Wikipedia also states the orange triangular sections of the tensor diagram [itex]T^{ik}, \quad i \ne k[/tex] represents shear stress so the shear stress components are distinct from the normal stress components. The same components are sometimes described as viscosity in other references and presumably the distinction depends on whether we are talking about solids or liquids, even though that distinction is not always clear cut.[/itex]
[itex] That's the point - it's all very vague as to how one specifically applies the off-diagonals as source terms in T. Haven't come across one single reference. If someone on this forum can point to one, please inform! As I have noted, uniform shear in solids is a null contribution. For fluids, what happens? There will be heat generation. But that represents energy which automatically is subsumed in the T<sub>00</sub> term. There will be a velocity gradient - laminar flow or vortex motion (spin). But that is automatically subsumed in the momentum flow terms T<sub>10</sub>,T<sub>20</sub>,T<sub>30</sub>. Integrating a shear gradient in any direction leads to stress differentials, which are automatically subsumed in the diagonals. So what's left? Nothing as far as I can see. Can't help feeling these terms are there as formal 'padding', and have no fundamental significance in the way the other terms do. As an outsider though could be quite wrong.<br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Wikipedia also hints that the "box" labelled "momentum flux" in the above diagram is basically the same as the stress tensor used in engineering. </div> </div> </blockquote>Correct.<br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Also, if we had a large planet sized sphere, would I be right that in thinking that a stress-energy tensor cannot represent the whole object but just some small finite (infinitesimal?) element of the large object? Is a metric basically the result of summing numerous stress-energy tensors that make up the composite whole? </div> </div> </blockquote>About the only objects I could think of where your observation would not be true would be say a rotating thin hoop under uniform circumferential tensile stress, or a balloon inflated under uniform pressure. Though even here one would still need to integrate over the entire object to get the contribution to the curvature terms exterior to the source.<img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" />[/itex]
  • · Replies 33 ·
  • · Replies 26 ·
  • · Replies 21 ·
