On the Physical Separation of Time
The discussion revolves around the concept of temporal separation in curved spacetime, particularly focusing on the notion of "physical time" and its dependence on various factors such as path and coordinate system. Participants explore the implications of these dependencies for theoretical investigations and experimental observations in the context of general relativity.
  • Some participants propose that temporal separation in curved spacetime is path-dependent and not unique for a pair of events, depending on the nature of the metric.
  • Others argue that the concept of "physical time" lacks clear physical meaning and may not be useful for practical calculations or experiments.
  • A participant questions the relevance of measuring "physical time" and asks for specific experimental contexts where it would apply.
  • Another participant emphasizes the importance of theoretical estimates of physical time differences, noting that they may not have unique values in general cases.
  • Some participants highlight the practical implications of gravitational time dilation, particularly in systems like GPS, where different rates of time passage must be accounted for.
  • There is a discussion about the proper time along worldlines and the conditions under which it may be path-independent.
Participants express differing views on the utility and interpretation of "physical time," with some questioning its relevance and others defending its importance in theoretical contexts. The discussion remains unresolved regarding the definitions and implications of temporal separation in curved spacetime.
The discussion includes assumptions about the nature of metrics and the conditions under which certain integrals may be path-independent. There are also unresolved questions about the applicability of the proposed concepts to complex metrics beyond simple cases.
  • #31
I would request you to consider #29 with a view to understanding physical time and its importance in relation to the GPS. I have talked of the difference of physical time and proper time there. Coordinate separation of time interval is same at the satellites as well as on the ground. The physical separations are different.The idea has been clearly explained in #9.
  • #32
The variable in the integral mentioned in #1 has been clearly stated. Coordinate time is the independent variable while the result of the integration is physical time.The values of the integrand depend on the choice of path.The limits of integration also have been stated.
  • #33
It's still unclear because one can easily use t as the parameter with which to parametrize any specific timelike worldline (at least ones outside the horizon, since the t coordinate becomes spacelike inside the horizon), you just need functions r(t), theta(t), and phi(t), then any point on the worldline will have coordinates of the form [t, r(t), theta(t), phi(t)]. In this case the integral I wrote before, [tex] \int_{p_0}^{p_1} \sqrt{(1 - r_s / r(p)) * (dt/dp)^2} \, dp[/tex] (which is analogous to the integral for proper time that I wrote down afterwards, it just drops all the parts of the metric aside from [tex]g_{tt}[/tex]), would reduce to [tex]\int_{t_0}^{t_1} \sqrt{(1 - r_s / r(t))} \, dt[/tex]. Is this what the more detailed form of your integral would be? or do you want the r in (1 - rs/r) to be a constant rather than a function r(t)? (and if it's a constant, what constant value should it take? After all the two events we're interested in may have different r-coordinates)
  • #34
r changes as we move along the curve from one point to the other during the process of integration.In fact we can have several such curves which is a basic feature of the problem[especially, in relation to general type of metrics which may be complicated functions of the coordinate variables even in the stationary case. We are excluding the explicit dependence of the metric,g(00) on coordinate time].
  • #35
So is this equation correct?
If so, you agree that different curves between the same events could have different functions for r(t) and so you could get different answers by evaluating it along different curves?
  • #36
g(00) is not a function of time in a direct or an explicit manner[for stationary fields].But as we move along the curve of integration ,g(00) changes from point to point. So we may construct a relationship between t and r for the purpose of integration.
  • #37
I understand that your "physical time" is different from proper time, I don't understand it's "importance" though. Do you agree that all calculations that physicists use to synchronize GPS clocks are done using coordinate time and proper time, not your notion of "physical time"?
It isn't "clear" to me. Could you please just give a direct answer to my question from post #30?
What do you mean "set of intervals"? If transmission is a single event, what "interval" would be associated with it? I can only see how there would be an interval of some quantity--say, coordinate time--between two events, like the event of transmission and the event of reception.
Please, no reference to "intervals" unless you specify what specific particular pair of physical events (for example, the event of a ground clock sending a signal and the event of a satellite receiving that signal) you are taking an interval between. Perhaps you are talking about an "interval" between two successive events of a signal being sent from the ground, and comparing with an "interval" between two successive events of a satellite receiving a signal?
  • #38
You still haven't given a direct answer to my question--was the equation I wrote down in post #35 the same as what you had in mind for "physical time", yes or no?
  • #39
With out the notion of physical time you cannot have clocks running at different rates at different points.
Coordinate separation [temporal] cannot produce this effect, typical of General Relativity.
Proper time is not related to this issue.
In #30 the Wikipedia reference relates to PROPER TIME and not PHYSICAL time
I would request you not to complicate your own thinking.Just think of a pair of events occurring in curved spacetime [at finite separation]. How do you calculate the physical time difference?
I am not meandering with my responses. I am trying to get the point to you which you are unwilling to accept
  • #40
The equation you wrote in #35 can be meaningful only if the path is specified.I have clearly indicated that[you may consider #1 and some others also] , and we can get different results for different curves--and that is the crux of the problem.
  • #41
What do you mean "cannot have"? Do you actually mean that you think you'll get some different predictions about local events (like the times that a particular clock receives signals from another clock) if you don't make use of "physical time" in your calculations? (please give a direct yes or no answer to this question) Or would you agree with me that all predictions about local coordinate-invariant facts are the same regardless of what method we use to calculate things, but you think "physical time" is necessary if we want to define some non-coordinate-invariant notion (i.e. a coordinate-dependent notion) of the "rate" that clocks run at different points? The normal way of defining the "rate" of a clock in a coordinate-dependent way is just to look at [tex]d\tau/dt[/tex], the rate proper time is increasing relative to coordinate time. Certainly it is true in Schwarzschild coordinates that [tex]d\tau/dt[/tex] will be smaller for a clock hovering at a lower radius than for a clock hovering at a greater radius, which is what physicists say when they talk about low-altitude clocks "running slower" than high-altitude clocks.
I didn't ask you to address the entirety of post #30, I asked you to address this particular question from post #30:
There is no "wikipedia reference" in this question. Please address this question, specifically.
This isn't helping me to understand what you meant with your comment that prompted my question above, namely:
In the above example we have two sequences of events:
1)Transmission of information--one set of intervals
2)Reception of events--another set
Communication is going to be impossible if each time you make a statement which I find confusing and I ask you a question about it, you avoid answering the question and just make some new confusing statements. So please, let's straighten out what you meant by distinguishing "one set of intervals" associated with "transmission" and "another set" associated with "reception" before moving on to other issues. What is the exact nature of the "intervals" associated with transmission? What events are you calculating the intervals between?
  • #42
Anamitra said:
The equation you wrote in #35 can be meaningful only if the path is specified.I have clearly indicated that[you may consider #1 and some others also] , and we can get different results for different curves--and that is the problem.]
That doesn't answer the question of whether #35 actually captures what you meant when you wrote the equation in post #1. Yes or no? If no, does that mean you meant #1 to possibly have an interpretation where the value of the integral would not depend on the choice of path?
  • #43
For events occurring at a fixed point[spatial point] proper time difference is the same as physical time difference. But for events occurring a pair of distant points in curved spacetime physical time difference and proper time difference are not the same. To get the proper time one has to travel from one point to the other between the events with the clock in his hand.But I am standing at a third point and I am not ready to move---I am in a laboratory.I want to have an estimate of the time difference.Coordinate time difference would not help me----it may have units different from time in certain types of metrics.What should I do in such a situation?
  • #44
Let's say point A has (spatial) coordinates [itex]x^{i}[/itex] and point B is infinitesimally close with coordinates [itex]x^{i} + dx^{i}[/itex]. We shine a light signal from B to A at time [itex]x^{0}[/itex] according to B. The signal travels towards A, reflects and reaches B again. Since it is traveling along a null geodesic, the equation for the light beam is:
[tex] g_{0 0} (dx^{0})^{2} + 2 g_{0 k} dx^{k} \, (dx^{0}) + g_{i k} dx^{i} dx^{k} = 0[/tex]
This is a quadratic equation w.r.t. [itex]dx^{0}[/itex] and it has two solutions:
[tex] (dx_{0})_{1/2} = \frac{-g_{0 i} dx^{i} \mp \sqrt{(g_{0 i} g_{0 k} - g_{0 0} g_{i k}) dx^{i} dx^{k}}}{g_{0 0}}[/tex]
corresponding to the time coordinates [itex]x^{0} + (dx^{0})_{1}[/itex] and [itex]x^{0} + (dx^{0})_{2}[/itex] according to A when the emission and reception of the light beam at B took place. The midpoint of the two:
[tex] x^{0} + \frac{(dx^{0})_{1} + (dx^{0})_{2}}{2} = x^{0} + g_{; i} dx^{i}, \; g_{; i} \equiv - g_{0 i}/g_{0 0}[/tex]
is, by the operational definition of synchonization, synchronous to the event with time coordinate [itex]x^{0}[/itex] at A when the reflection took place. Thus, the synchronization of the clocks at A and B requires an offset by an amount:
[tex] d(\Delta x^{0}) = g_{; i} \, dx^{i}[/tex]
If the points are separated by a finite amount, then we need to integrate:
[tex] \Delta x^{0} = \int{g_{; i} dx^{i}}[/tex]
Notice that this integral is along a spatial curve. Also, it still depends parametrically on [itex]x^{0}[/itex]. If you require path independence of this integral, it means that the integral:
[tex] \oint{g_{; i} dx^{i}} = 0[/tex]
should be zero along any closed spatial curve. For this, it is necessary and sufficient that the integrand is a gradient:
[tex] g_{; i} = \frac{\partial \psi}{\partial x^{i}}[/tex]
But, the mixed second derivatives of the function [itex]\psi[/itex] need to be equal, which means:
[tex] \frac{\partial g_{; i}}{\partial x^{k}} = \frac{\partial g_{; i}}{\partial x^{i}}[/tex]
Substituting the expression for [itex]g_{; i}[/itex] and performing the differentiation leads to:
[tex] g_{0 0} \left(\frac{\partial g_{0 i}}{\partial x^{k}} - \frac{\partial g_{0 k}}{\partial x^{i}}\right) - \left(g_{0 i} \frac{\partial g_{0 0}}{\partial x^{k}} - g_{0 k} \frac{\partial g_{0 0}}{\partial x^{i}}\right) = 0[/tex]
I am still not sure how to express this condition in terms of the Christoffel symbols.
  • #45
Are you claiming that there must be a single objective truth about "the time difference"? Or are you just looking for some definition that will allow you to define a "time difference" between an arbitrary pair of events in curved spacetime, without any notion that this definition is physically preferred over other possible ways we might define "time difference"?
In the latter case, my understanding is that as long as a spacetime is globally hyperbolic it should be possible to "foliate" it into a series of spacelike surfaces, so you could always build a coordinate system where each spacelike surface is a surface of constant t-coordinate, and then I would guess it should then be possible to define the coordinate system in such a way that all curves of constant position coordinate would be timelike curves. In this case, coordinate time difference between two events should always have units of time. The only spacetimes that aren't "globally hyperbolic" are ones with weird properties, like spacetimes containing closed timelike curves (i.e spacetimes where it is possible to 'travel backwards in time' and revisit events in your own past light cone). In the case of a nonrotating uncharged black hole, if you choose Kruskal-Szekeres coordinates it will be true that any curve of constant position-coordinate is a purely timelike curve, so the difference in coordinate time between any two events in these coordinates should have units of time, even if one event is outside the event horizon and the other is inside.
  • #46
Response to #44
The initial and the final points are the same spatiallyin the procedure given by Dickfore [at least in stationary fields]and so the spatial separations [tex]{{\Delta}{x}}_{i}{=}{0}[/tex]
So the quadratic equation should undergo a drastic modification.
We consider each term [spatial]=[tex]{g}_{ij}{{\Delta}{x}}_{i}{{\Delta}{x}}_{j}[/tex]
For varying fields the value of g(ij) may change with time. But what about the spatial elements [tex]{{\Delta}{x}}_{i}[/tex] if these terms are considered individually?
[May I refer to the picture/Diagram given in Landau and Lifgarbagez["The Classical Theory of Fields" Chapter--10,Section83] for the visualization of the procedure given by Dickfore in the initial part of the treatment]
  • #47
Section 83 in the previous post should be replaced by Section84, Figure 18
  • #48
The first equation in #44 could represent the travel of light in either direction from A to B or from B to A.So the two roots can represent the two times and the process has been worked out by the mirror.But if we consider the total travel from B to A and than back to B we still have a null geodesic[if a sharp bend/reflecting point in the path is given due consideration].Now the spatial elements work out to zero value and at the same time ds =0. Therefore dt=0.
What would be the case like if we make the sharp bend smooth without increasing the path in an appreciable manner?One does not have to consider a sharp bend in such a situation.
  • #49
We consider the travel of a light ray between the spatial points A and B[A light ray traveling from B to A to report an event at B]
Physical Element[Spatial], [tex]{dL}{=}{\sqrt{{g}_{11}{dx1}^{2}{+}{g}_{22}{dx2}^{2}{+}{g}_{33}{dx3}^{2}}[/tex]
Now,
[tex]{ds}^{2}{=}{g}_{00}{dt}^{2}{-}{g}_{11}{dx1}^{2}{-}{g}_{22}{dx2}^{2}{-}{g}_{33}{dx3}^{2}[/tex]
Implies,
[tex]{ds}^{2}{=}{g}_{00}{dt}^{2}{-}{dL}^{2}[/tex]
For a null geodesic,
[tex]{dL}{=}{\sqrt{{g}_{00}}{dt}[/tex]
Time of travel of the light ray,
=[tex]{\int dL}[/tex] ,noting c=1 in the natural units.
=[tex]{\int {\sqrt{{g}_{00}}{dt}[/tex]
So physical time as considered in #1 is simply the time of travel of the light ray between the pair of points. In curved spacetime we may have several null geodesics connecting a pair of points[gravitational lensing]. The same event may appear to be occurring at different locations----why not at different instants of time?
[Stationary fields are being considered]
  • #50
Distance along the x-axis:[tex]{\int \sqrt{{g}_{11}}{dx}[/tex]
Distance along the y-axis:[tex]{\int \sqrt{{g}_{22}}{dy}[/tex]
Distance along the z-axis:[tex]{\int \sqrt{{g}_{33}}{dz}[/tex]
Analogously,distance along the time-axis should be:[tex]{\int \sqrt{{g}_{00}}{dt}[/tex]
This is to be interpreted as the time taken by a light ray to travel between the points so far as the general nature of the metrics is concerned.
  • #51
In #49 we have considered a pair of spatial points and have connected them by a light ray passing between them . But what about fixed space-time points? They may not lie on the natural path of a light ray,ie a null geodesic.
Well, in such a case we may think of some sort of a mirror arrangement/mirror combination that could work out the concept of physical time in a practical way. Perhaps, this could solve the problem.
  • #52
It's a little misleading to call this "distance along the x-axis". If we take two events, consider a path between them, and evaluate [tex]{\int \sqrt{{g}_{11}}{dx}[/tex] along that path, then the result will not necessarily be equal to the coordinate distance between the events along the x-axis (at least not if my interpretation of what it means to integrate the metric along a path in post #33 was correct, you never answered my question about whether that matched your own notion). Of course you can always take this integral to be a definition of your own invented phrase "physical distance" along the x-axis.
  • #53
I #50 I have talked of physical distances and not coordinate distances.These physical always have the dimension of length.
  • #54
But "physical distance" is just an arbitrary phrase you made up to describe that integral, which has no meaning apart from your definition--correct? If so you should be careful to use the full phrase "physical distance" and not just something more vague like "distance along the x-axis".
Well, coordinate distance does too as long as you use a coordinate system where surfaces of constant time are everywhere spacelike.
  • #55
Just think of two points an ordinary sphere[three dimensional-spatial]
[tex]{\int {{d}{\theta}}}[/tex] gives an angular distance, when integration is performed between the limits [tex]{(}{\theta}_{1}{,}{\theta}_{2}{)}[/tex]
While the integral,
[tex]{\int {r}{d}{\theta}}{=}{\int{\sqrt{{g}_{\theta\theta}}{d}{\theta}}[/tex]
Conforms to the idea of distance[it has the dimension of length] along the curve r=constant and phi=constant
"Physical distance" is not an arbitrary phase. It has a well defined physical concept behind it.
I would request the mentors to comment on the issue.
  • #56
While the integral,
And what if you pick some different curve with varying phi and/or r? In that case this integral will not necessarily correspond to the geometric length of the curve, do you agree?
Can you explain what that "well defined physical concept" actually is?
  • #57
I am measuring the distance along the axis defined by r=const and phi=constant[only theta changes along this direction]
  • #58
This seems like an artificial restriction since there is no mathematical reason that the integral couldn't be evaluated along paths where r and/or phi are allowed to vary. Besides, when it comes to defining "physical distance" and "physical time" in spacetime, you didn't mention any requirement that all the other coordinates besides the one being integrated must be constant, so if the sphere is supposed to be an analogy to what you're talking about in spacetime, imposing such requirements in one case but not the other seems to make the analogy break down.
Finally, if you can't actually explain what the "well defined physical concept" behind your notion of "physical distance" is supposed to be, then it follows that you don't actually have any well-defined concept in mind that you used to derive the equation.
  • #59
We can always calculate the physical distance along an axis.Let us consider the points[tex]{(}{r}{,}{\theta}{,}{\phi}{)}[/tex] and [tex]{(}{r}{,}{\theta}^{'}{,}{\phi}^{'}{)}[/tex]
We may calculate the distance between them along r=const,phi=[tex]{\phi}[/tex],[taken const]
or r=constant ,phi=[tex]{\phi}^{'}[/tex], [taken constant]
between the aforesaid coordinates using the second integral in #55
We may also calculate the distance between them along r=const,theta=[tex]{\theta}[/tex]
[taken constant]
or r=constant ,theta=[tex]{\theta}^{'}[/tex], [taken constant]
between the aforesaid points using the integral:
[tex]{\int{ \sqrt{g}_{\phi\phi}}{d}{\phi}[/tex]
For the two parallel lines[of latitude lying between the meridians concerned] we get different values. This is quite natural
[I am referring to a common,3D spherical surface,obviously a spatial one]
  • #60
If one wants to calculate the physical distance along some path connecting [tex]{(}{r}{,}{\theta}{,}{\phi}{)}[/tex] and [tex]{(}{r}{,}{\theta}^{'}{,}{\phi}^{'}{)}[/tex]
He/she can use the integral [tex]{\int{dL}}{=}{\int{\sqrt{{g}_{rr}{dr}^{2}{+}{g}_{\theta\theta}{{d}{\theta}}^{2}{+}{g}_{\phi\phi}{d}{{\phi}}^{2}}}[/tex]
Along the specified path lying on the surface of the sphere
  • · Replies 76 ·
  • · Replies 24 ·
  • · Replies 40 ·
  • · Replies 34 ·
