Value of a strange continued fraction
  • Context: Graduate
  • Thread starter Thread starter psychohistory
    Fraction Strange Value
The discussion revolves around the evaluation of a specific continued fraction: 1 + 1/(2 + 1/(3 + 1/(4 + ...)), and the exploration of methods for solving continued fractions with similar patterns. Participants also introduce another continued fraction involving imaginary numbers.
  • One participant questions the value of the continued fraction and seeks a general method for solving such patterns, noting their familiarity with periodic continued fractions.
  • Another participant suggests that the value can be expressed as a ratio of hyperbolic Bessel functions, referencing a specific mathematical publication.
  • A different participant expresses appreciation for the reference provided, indicating it was helpful for their inquiry.
  • One participant introduces a new continued fraction involving imaginary numbers and seeks insights on its evaluation.
  • Another participant discusses the use of recurrence formulas for continued fractions and presents a detailed approach involving generating functions and periodicity in the context of specific parameters.
  • Further elaboration on generating functions is provided, including specific forms for different values of parameters, and the implications of these forms on the behavior of the sequences generated.
  • One participant notes the oscillatory behavior of the solutions for certain parameter values and expresses uncertainty about solving those cases.
Participants do not reach a consensus on the evaluation of the continued fractions discussed. Multiple competing views and methods are presented, and the discussion remains unresolved regarding the best approach or final value.
Participants mention limitations in their approaches, including unresolved mathematical steps and the dependence on specific parameter values that influence the behavior of the continued fractions.
psychohistory
Howdy!
Question - What is the value of the continued fraction: 1 + 1/(2 + 1/(3 + 1/(4 + ...
The continued fraction can also be written: [1; 2,3,4,...]
Is there a general method for solving continued fractions with patterns like this? I tried using the recursive formula for the nth convergent, but I couldn't generalize it.
I know how to work with periodic continued fractions (in which case, the value is a quadratic surd), but anything beyond that and I'm clueless.
First post, btw. I'm actually a music major that dabbles in this crap on the side. Thanks!
The value is
[tex] \frac{I_0(2)}{I_1(2)}[/tex]
where [itex]I_n(x)[/itex] is a hyperbolic Bessel function
American Mathematical Monthly, solution E3264, vol. 97, 1990, p. 157
"general method" ... depends what you mean by "like this"
Wow, thanks for the very specific reference, g_edgar. No idea how you found that, but exactly what I was looking for.
and what about
[tex]\large\ F=\cfrac{1}{i+\cfrac{1}{i^2+\cfrac{1}{i^3+\cfrac{1}{i^4+...}}}}[/tex]
That hyperbolic-Bessel-function ratio was from Continued Fraction -- from Wolfram MathWorld
One can use the Fundamental recurrence formulas (Wikipedia) for them.
For a continued fraction
x = b0 + a1 /(b1 + a2/(b2 + ...))
we set up A's and B's such that
A(0) = b(0)
B(0) = 1
A(1) = b(1)*b(0) + a(1)
B(1) = b(1)
A(n) = b(n)*A(n-1) + a(n)*A(n-2)
B(n) = b(n)*B(n-1) + a(n)*B(n-2)
x(n) = A(n)/B(n) converges to the desired result as n -> infinity
So here we have a(n) = 1 and b(n) = in
I evaluated with Mathematica's function RecurrenceTable, and I found no convergence for the first 100 terms. In fact, I find that the values recur with a period of 24. The recurrence period of b(n), 4, evenly divides this, so this recurrence is exact.
So one ought to do the general case of a(n) = 1 and b(n) = c*bn[/sub], and then take c -> 1 and b -> i.
Let's do A and B together.
p(n) = c*bn*p(n-1) + p(n-2)
p(0) = q0
p(1) = c*b*q0 + q1
We can use a generating function:
P(t) = sumn from 0 to oo p(n)*tn
That gives us
(1 - t2)*P(t) - c*(b*t)*P(b*t) = q0 + q1*t
For b = c = 1, one gets the Fibonacci series:
P(t) = (q0 + q1*t)/(1 - t - t2)
where each power of t is a sum of powers of ((sqrt(5)+1)/2) and ((sqrt(5)-1)/2).
If b is an nth root of unity, one can solve this equation by taking t -> b*t, t -> b2*t, until the cycle is complete. One can then solve for P(t) by factoring out P(b*t), P(b2*t), etc.
One gets a rational function of t, implying a Fibonacci-like solution.
For c = 1 and b = -1, one gets a power series in 12th roots of unity, yielding a recurrence period of 12, and for c = 1 and b = i, one gets 24th roots of unity, yielding a recurrence period of 24.
So one ought to treat c = 1 as a limit, to be approached from below.
For b = -1, the roots' absolute values are offset by about sqrt(1-c)/2 from unity, and for b = i, about sqrt(1-c)/4 from unity.
My patience has run out here; it's fairly straightforward algebra the rest of the way.
I did the algebra, with the help of Mathematica, and I found these generating functions:
For b = 1,
[itex]P(t) = \frac{q_0 + t q_1}{1 - t - t^2}[/itex]
For b = -1,
[itex]P(t) = \frac{(1-ct-t^2)q_0 + t(1+ct-t^2)q_1}{1-(2-c^2)t^2+t^4}[/itex]
For b = i,
[itex]P(t) = \frac{(1+ict+(1-ic^2)t^2-c^3t^3+(-1-ic^2)t^4-ict^5-t^6)q_0 + t(1-ct+(1+ic^2)+ic^3t^3+(-1+ic^2)t^4+ct^5-t^6)q_1}{1-(2-c^4)t^4+t^8}[/itex]
One finds the solution by decomposing the generating function into this fractional form:
[itex]P(t) = \sum_k \frac{c_k}{1 - w_k t}[/itex]
It yields the solution:
[itex]p(n) = \sum_k c_k (w_k)^n[/itex]
The b = 1 case yields:
[itex]p(n) = \frac{1}{2\sqrt{5}} \left( ((1+\sqrt{5})q_0+2q_1) \left(\frac{1+\sqrt{5}}{2}\right)^n - ((1-\sqrt{5})q_0+2q_1) \left(\frac{1-\sqrt{5}}{2}\right)^n \right)[/itex]
which gives us each member of the Fibonacci series. Note that the exponential factors w = (1+sqrt(5))/2 and (1-sqrt(2))/2 make increasing and decreasing contributions, respectively, as n increases.
However, for b = -1, the exponential factors are
w = {1, -1} * exp((i/2)*arccos(1-c2/2))
and for b = i, the exponential factors are
w = {1, i, -1, -i} * exp((i/4)*arccos(1-c4/2))
These make |w| = 1 for c near 1, and thus oscillatory behavior, so the limit trick doesn't work there.
An alternative would be to take |b| near 1, then take the limit of |b| -> 1.
I don't know how to solve that case, and I don't even know if it will work.
  • · Replies 0 ·
  • · Replies 23 ·
  • · Replies 19 ·
33K
