Finding Continuous & Differentiable Points of f in {R}^3
The discussion revolves around finding the continuous and differentiable points of a function defined in three-dimensional space, specifically at the origin and in its vicinity. The function is given piecewise, with a specific definition at the origin and a different expression elsewhere.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the limits of the function as it approaches the origin, questioning the continuity and differentiability at that point. Various paths are suggested for evaluating the limit, including specific coordinate transformations and direct substitutions.
The discussion is ongoing, with participants providing insights and suggestions for evaluating limits. Some participants have noted that the limit appears to be zero along certain paths, while others emphasize the importance of examining multiple paths to confirm the behavior of the function near the origin.
There is a focus on the implications of the limit being path-dependent, with participants reflecting on how this affects the continuity and differentiability of the function at the origin. Additionally, there are mentions of specific evaluations and transformations that have been attempted, but no consensus has been reached on the overall behavior of the function.
Combinatus
Find the continuous points P and the differentiable points Q of the function [tex]f[/tex] in [tex]{R}^3[/tex], defined as
[tex]f(0,0,0) = 0[/tex]
and
[tex]f(x,y,z) = \frac{xy(1-\cos{z})-z^3}{x^2+y^2+z^2}, (x,y,z) \ne (0,0,0)[/tex].
If you want to look at the limit I'm having trouble with, just skip a few paragraphs. I'm mostly including the rest in case anyone is in the mood to point out flaws in my reasoning.Differentiating [tex]f[/tex] with respect to x, y and z, respectively (when [tex](x,y,z) \ne (0,0,0)[/tex] will make it apparent that all three partials will contain a denominator of [tex](x^2+y^2+z^2)^2[/tex] and a continuous numerator. Thus, these partials are continuous everywhere except in [tex](0,0,0)[/tex], and it follows that [tex]f[/tex] is differentiable, and consequently, also continuous in all points [tex](x,y,z) \ne (0,0,0)[/tex].
Investigating if [tex]f[/tex] is differentiable at [tex](0,0,0)[/tex], we investigate the limit
[tex]\lim_{(h_1,h_2,h_3) \to (0,0,0)}{\frac{f(h_1,h_2,h_3) - f(0,0,0) - h_1 f_1(0,0,0) - h_2 f_2(0,0,0) - h_3 f_3(0,0,0)}{\sqrt{{h_1}^2 + {h_2}^2 + {h_3}^2}}} = \lim_{(h_1,h_2,h_3) \to (0,0,0)}{\frac{h_1 h_2 (1-\cos{h_3}) - {h_3}^3}{({h_1}^2 + {h_2}^2 + {h_3}^2)^{3/2}}}.[/tex]
Evaluating along the line [tex]x = y = z[/tex], that is, [tex]h_1 = h_2 = h_3[/tex], it is found after a bit of work and one application of l'Hôpital's rule that the limit from the right does not equal the limit from the left, and hence, [tex]f[/tex] is not differentiable in [tex](0,0,0)[/tex].
To prove continuity of [tex]f[/tex], we want to show that [tex]\lim_{(x,y,z) \to (0,0,0)}f(x,y,z) = 0[/tex]. Since I haven't found any good counter-examples to this, I've tried to prove it with the epsilon-delta definition instead, with little luck.
We see that
[tex]|f(x,y,z) - 0| = \left|\frac{xy(1-\cos{z})-z^3}{x^2 + y^2 + z^2}\right| \le \left|\frac{xy(1-\cos{z})-z^3}{z^2}\right|,[/tex]
getting me nowhere.
Trying with spherical coordinates instead, we get
[tex]|f(x,y,z)-0| = \left|\frac{{\rho}^2 {\sin^2 \phi} \cos{\theta} \sin{\theta} (1-\cos{(\rho \cos{\phi})}) - {\rho}^3 \cos^3 {\phi}}{{\rho}^2 \sin^2 {\phi} \cos^2 {\theta} + {\rho}^2 \sin^2 {\phi} \sin^2 {\theta} + {\rho}^2 \cos^2 {\phi}}\right| = \left|\sin^2 {\phi} \cos{\theta} \sin{\theta} (1-\cos{(\rho \cos{\phi})}) - \rho \cos^3 {\phi}\right|.[/tex]
I'm not sure how to proceed. Suggestions?
and
A couple of things to look at:
Notice that  [tex]f(x,y,0)=0[/tex].
Also look at  [tex]\lim_{y\to 0}\left(\lim_{x\to 0}f(x,\,y,\,z)\right)\ .[/tex]  WolframAlpha evaluates this as ‒z.
For small values of |z|,  [tex]1-\cos(z)\ \to\ \frac{z^2}{2}[/tex]
Look at the path: x=y=z=t and then eamine the limit as t tends to zero.
Look at [tex]\lim_{z\to0} f(x,\,y,\,z)[/tex].
This limit is zero.
Wouldn't it be possible for the limit to be different along some other path? (Although in this particular case, there isn't.)
This limit is zero.
Good find!
Using the [tex]\left|\sin^2 {\phi} \cos{\theta} \sin{\theta} (1-\cos{(\rho \cos{\phi})}) - \rho \cos^3 {\phi}\right|[/tex] part from my use of polar coordinates, I guess it should be pretty clear that, since (x,y,z) → (0,0,0) implies ρ → 0 for any angles θ and Φ, we get that this expression goes to 0, thus showing the limit.
So what you have found is that the limit is dependent on the path you take. What does that suggest to you?
Actually, he found that in this case, it's not dependent on the path.
So he did, my bad. I should have read what he had done in more detail
  • · Replies 40 ·
  • · Replies 34 ·
