Simple dipstick problem
by pat666
Tags: dipstick, simple
Mentallic
Mentallic is offline
#37
Feb12-11, 11:29 PM
HW Helper
P: 3,436
Quote Quote by pat666 View Post
I think it is correct but given the amount of trouble I've had getting the solution you can see why I am unsure.
Yes it's correct. I was just showing you that you can tidy up
[tex] V_(fluid)=(\pi((h/H)*R)^2*h)/3 [/tex] probably simplify down further.
into
Quote Quote by Mentallic View Post
Sure, [tex]V=\frac{\pi h^3R}{3H^2}[/tex]
just the way the picture was drawn made me think r=h,
Oh, yeah that would be my fault, sorry
which would be true if the water was at the centre.
The blue line was meant to be where the water level was at.
I get that [tex] \theta=2cos^-^1(r-h)/r [/tex]
Yes that's right.
not sure if thats correct because you gave me some trig info that was a bit more complex.
My trig info was wrong, ignore it. I forgot about the 2 that was going to be in front of it. What I was meant to give you was
[tex]\sin\left(2\cos^{-1}\left(x\right)\right)=2x\sqrt{1-x^2}[/tex]
It may look complex, but its purpose is simple. When you plug [itex]\theta[/itex] into the area equation [tex]A=\frac{r^2}{2}\left(\theta-\sin\theta\right)[/tex] you're going to be left with
edit: [tex]\sin\left(2\cos^{-1}\left(\frac{r-h}{r}\right)\right)[/tex] which is where you can simplify this with the equality I gave above.
You already have the answer, but it's just if you wanted to simplify things a bit more.
Markers wouldn't give full marks if you left an answer as [tex]\sin\left(\sin^{-1}\left(x\right)\right)[/tex] so I doubt they would give full marks if you left it as [tex]\sin\left(\cos^{-1}\left(x\right)\right)[/tex] either.
also this will only work to the halfway point but I was thinking I would just do the reflection of the earlier dipstick points for points after the mid line.
thanks
I believe the same formula will work for the water level anywhere from 0 to 2r (the diameter of the circle) but I'll check to see.
pat666
pat666 is offline
#38
Feb12-11, 11:38 PM
P: 709
Ok thanks alot for all your help
OmCheeto
OmCheeto is offline
#39
Feb12-11, 11:39 PM
PF Gold
OmCheeto's Avatar
P: 1,370
The cylinder on it's side problem reduces to y=x - sin(x) in it's simplest form.
If you can solve for x, then you can solve the problem.
There is a reason they put this problem in computer science text books and never in mathematics text books.
Mentallic
#40
Feb12-11, 11:45 PM
HW Helper
P: 3,436
No worries
Quote Quote by OmCheeto View Post
Can you please elaborate?
I've seen questions similar to this in maths books.
pat666
pat666 is offline
#41
Feb12-11, 11:52 PM
P: 709
This question is for yr 11 math. My solution is I believe [tex] V=L*\sin\left(\cos^{-1}\left(2\cdot\frac{r-h}{r}\right)\right) [/tex].
Mentallic
#42
Feb12-11, 11:58 PM
HW Helper
P: 3,436
That's not right. The formula is [tex]A=\frac{r^2}{2}\left(\theta-\sin\theta\right)[/tex] where [tex]\theta=2\cos^{-1}\left(\frac{r-h}{r}\right)[/tex]
pat666
pat666 is offline
#43
Feb13-11, 12:14 AM
P: 709
whoops I forgot the first theta, so V=L*(r^2/2(2arccos(r-h/r)-sin(2arccos(r-h/r))) pretty messy.
OmCheeto
OmCheeto is offline
#44
Feb13-11, 12:43 AM
PF Gold
OmCheeto's Avatar
P: 1,370
Perhaps the question in the book was worded differently.
All I know is that if you have a 10 gallon tank, it is not possible to place integer gallon marks on the dipstick. Unless of course you are clever enough to solve for x.
And perhaps I should give some background regarding this particular problem before someone yells at me for playing mind games.
Register to reply
Related Discussions
What instant the force in the dipstick iz zero Introductory Physics Homework 10
Think with your dipstick, Jimmy! - Castrol EDGE Product Claims 10
Simple problem (thermodynamics): is it just too simple? Advanced Physics Homework 17
The Dipstick Problem - area of a Cyclinder Calculus 1
Dipstick problem (volume of a cylinder) Calculus & Beyond Homework 2
