Solving Mutually Perpendicular Vector Components
  • Thread starter Thread starter CinderBlockFist
    Component Vector
The discussion revolves around solving for the components of three mutually perpendicular vectors U, V, and W using the dot product. The original poster is attempting to find the values of Ux, Vy, and Wz, given their relationships through the dot product equations, but is encountering difficulties in isolating the variables.
  • Participants discuss the use of the dot product to establish equations based on the condition of perpendicularity. There are attempts to isolate variables and solve a system of equations, with some participants expressing confusion about the steps and methods suggested by others.
There is an ongoing exploration of different methods to solve the system of equations derived from the dot product conditions. Some participants are questioning the validity of the equations presented and the assumptions made, while others are offering insights into potential techniques for solving the equations.
Participants note the challenge of working with variables that are not explicitly defined, leading to confusion in calculating magnitudes and setting up equations. The original poster has access to answers from a textbook, which adds pressure to understand the problem correctly.
CinderBlockFist
Guys, I am stuck on this problem. I have the answer from the back of the book, but I don't know how to solve it. I tried to solve it by isolating Ux, Vy, and trying to solve it by simultaneous equations, but I always end up getting something like Vy = Vy , or something like Vy - Vy = 0. It keeps going in circles, maybe this isn't the way to go. But anyways, this is the problem:
(note: the x, y , and z are written as small sub next to the U, V, and W, I just can't type it like it is in the book)
The three vectors
U = Uxi + 3j + 2k
V = -3i + Vyj + 3k
W = -2i + 4j + Wzk
are mutually perpendicular. Use the dot product to determine the compnents of Ux, Vy, and Wz.
The answers in the back of the book are Ux = 2.857, Vy = 0.857, Wz = -3.143.
I am using the dot product definition: U dot V = UxVx+UyVy+UzVz
so I get (Ux)(-3)+(3)(Vy)+(2)(3) = 0
I set it all to zero because they are perpendicular to each other.
So simplifying for Ux, i get Ux = Vy + 2. THen I plug Vy +2 for Ux, but then I go in circles from there.
Using the dot product definition: U dot V = UxVx+UyVy+UzVz = |U||V|cos(a)
you have a system of 3 equation:
-3U + 3V + 6 = 0
6 + 4V +3W = 0
-2U + 12 + 2W = 0
You can solve it by Cramer or by substitution
The solution are: U =20/7 V=6/7 W=-22/7
what is cramer, what do i substitute?
What do I put for the |U||V|, since those are the magnitudes, I don't know how to find them because we are given only the components, and some are (Ux,Vy,Wz) are not actuallly given, so I can't compute it in the radical to get a value.
Cinder are you familiar with System fo equations?, because i see no problem with Final's answer...
how did u get the -3, 4, and the 12, they are not given in the problem? They are only variables Ux, Vy, and Wz
In Final's post U is Ux, V is Vy, and W is Wz.
Yes, but in his 3 equations, he has -3U in the first one, and 6, in the second, and , man sorry i just don't see it
can someone show me the steps to get those values, cause when i tried to isolate Ux, or Vy, or Wz, in a system, then i would get like Vy - Vy =0 or something useless.
The first equation is U dot V
The second equation is V dot W
The third equation is U dot W
There are 3 unknowns and 3 equations, this is a solvable system, check what you are doing.
No offense intended, CinderBlockFist, but this a lot like a guy asking a question about calculus and not being able to do arithmetic. If you are studying linear algebra, you certainly would be expect to be able to solve 3 linear equations in 3 unknowns. You may have had that so long ago you have forgotten.
The three vectors are
U = Uxi + 3j + 2k
V = -3i + Vyj + 3k
W = -2i + 4j + Wzk
U.V= -3Ux+ 3Vy+ 6= 0
U.W= -2Ux+ 12+ 2Wz= 0
W.V= 6+ 4Vy+ 3Wz= 0. Three linear equations in 3 unknowns.
There are many different ways to solve these but the simplest is probably:
Multiply the first equation by 2 to get -6Ux+ 6Vy+ 12= 0
Multiply the second equation by 3 to get -6Ux+ 36 +6Wz=0
Of course, the purpose of the multiplications was to get Ux with the same coefficient, -6, in both. If we subtract the second of those equations from the first the two "-6Ux" terms cancel and we get 6Vy+ 12- 36- 6Wz= 0 or 6Vy- 6Wz- 24= 0.
The last equation did not have Ux in it to begin with so now I have two equations in 2 unknowns: 6Vy- 6Wz- 24= 0 and 6+ 4Vy+ 3Wz= 0. If we divide the first of those by 2 we get 3Vy- 3Wz- 12=0 and adding that two the second will cause the "3Wz" terms to cancel: 3Vy- 3Wz- 12+ 6+ 4Vy+ 3Wz= 7Vy- 6= 0. That one equation in one unknown we can solve to get Vy= 6/7.
Putting that back into the original equation 6+ 4Vy+ 3Wz= 0, we get 6+ 24/7+ 3Wz= 0 so 3Wz= -6- 24/7= -66/7 so Wz= -22/7. Finally, we can put Vy= 6/7 into the original equation -3Ux+ 3Vy+ 6= 0 which is the same as Ux= Vy+ 2= 6/7+ 2= 20/7.
Putting all of those together, Ux= 20/7, Vy= 6/7, and Wz= -22/7 just as Final said originally.
U = Uxi + 3j + 2k
V = -3i + Vyj + 3k
W = -2i + 4j + Wzk
Ivy, THank you for the great response, yes I get it! I forgot, I was trying to solve using only 2 of the equations, no wonder i got no where. And I forgot about that technique to match of the coeff. Thanks again =)
Ah, yes! The ever-popular "fight with one hand tied behind my back method"!
  • · Replies 21 ·
