Confirm the characteristic of Position Vector.
The discussion centers around the characteristics of position vectors, particularly in the context of their mathematical properties, representation in spherical coordinates, and the implications for vector calculus operations such as curl and divergence. Participants explore the definitions and behaviors of position vectors in various coordinate systems.
  • Some participants assert that position vectors are radial vectors originating from the origin to a point in space.
  • There is a claim that the curl of a position vector is zero, but this is qualified by the condition that the radial component must be independent of angular coordinates.
  • Others propose that in spherical coordinates, a position vector can be expressed solely in terms of the radial component, with the form \vec A_{(x,y,z)} = \hat R A_R , where A_R = |\vec A| .
  • Some participants discuss the implications of the components of a position vector being constant with respect to coordinates but potentially varying with time, allowing the vector to trace a curve.
  • There is mention of how vector fields are defined by local bases of unit vectors, with specific references to the behavior of components in polar coordinates.
  • One participant notes that certain simple vector fields can have zero curl and non-zero divergence, indicating a nuanced understanding of vector calculus.
Participants generally agree on the basic definition of position vectors but express differing views on the conditions under which the curl is zero. The discussion remains unresolved regarding the specific conditions and implications of these mathematical properties.
Participants highlight that the behavior of the curl and divergence of position vectors may depend on specific conditions related to the components of the vector in different coordinate systems.
yungman
I want to confirm this, for any position vector.
1) They are radial vector that start from the origin to a point in space.
2) If A is a position vector:
[tex]\nabla X \vec A \;=\; 0 \;\hbox { and }\; \nabla \cdot \vec A \;\hbox { not equal to zero. }[/tex]
3) Any position vector in spherical coordinates contain only [itex]\hat R[/itex] term:
[tex]\vec A _{(x,y,z)} = \vec A_{(R,\theta,\phi)} = \hat R A_R \;\hbox { with }\; A_R=|\vec A|[/tex]
Am I correct?
Am I correct?
All true except for the curl.
The curl is only 0 if A_r is independent of theta and independent of phi.
You can see how this works on http://en.wikipedia.org/wiki/Del_in_cylindrical_and_spherical_coordinates
[EDIT]Hold on, a little more specific is that the curl is 0 for a position vector.
But for a position vector A_r is equal to r.[/EDIT]
But [itex]\vec A_R[/itex] by definition is a vector field defining A by a radius vector ( position vector) r. Position vector is originated at the origin and the arrow head at some (x,y,z).
So in this sense, curl of a position vector has to be zero.
Am I correct?
Thanks
BTW, I am reading up in the calculus book too, the components of a position vector are constant respect to the coordinates but can be a function of time t so the vector can trace out a curve with time.
Am I correct?
Thanks
A vector field is usually defined by a local base of unit vectors.
For instance, in polar coordinates the following holds:
A_r is the magnitude in the direction of the position vector.
Furthermore we have A_phi and A_theta that are magnitudes perpendicular to the direction vector (in the directions that phi resp. theta would go).
A_r, A_phi, and A_theta are functions of r, theta, and phi.
Note that this local base of unit vectors changes direction when moving to another position vector.
One of the simplest vector fields is the one where A_r=r and A_theta=A_phi=0
Another one is A_r=1 and A_theta=A_phi=0.
These vector fields have curl A=0 and div A!=0
Sorry, I mis-read. I thought you meant
[tex]\vec A _{(\vec r)}[/tex]
I read back, you meant the R component of A in spherical coordinate. By definition of position vector, the A_r has to be constant because it start at origin and end at the point. So the curl has to be zero.
