Two current carrying wires. Confusion
The discussion revolves around the interaction between two current-carrying wires and the magnetic fields they produce. The original poster expresses confusion regarding the behavior of the magnetic field in the region between the wires, particularly questioning how the magnetic field can be zero at a midpoint while still exhibiting non-zero values elsewhere.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the nature of the magnetic field produced by each wire and question the implications of the right-hand rule. There are attempts to visualize the magnetic field lines and clarify the conditions under which the field is zero.
The conversation is ongoing, with participants providing insights and clarifications about the magnetic field's behavior. Some guidance has been offered regarding the specific locations where the magnetic field is zero, but multiple interpretations and questions remain active.
Participants are navigating through various assumptions about the magnetic field's behavior and the application of the right-hand rule. There is mention of potential confusion arising from different interpretations of the rules governing magnetic fields around current-carrying wires.
flyingpig
Let there be two current carrying wires with current flowing in the same direction. According to my book, they attract by the right hand rule. Now here is my question, since the B-field is popping inwards for one of the wires and the other one is popping outwards in the middle between the two wires, wouldn't that mean the B-field is 0? If it is then how can the B-field come back outwards and inwards again?
I can't understand what you are asking
Yes it is
Then how can the Field come back in and out on the far right and left?
Why then can't? they are two independent fields ...
like for electric field ... if you place a conductor in its path ... it is zero inside it but again gains its strength outside it
But is the B-field only 0 at the mid point? Or is it everywhere between the two wires
Think about this in three dimensions.
The ONLY place the B field is zero is right along the line that's midway between the wires.
only at the mid point because only at that point their strengths become equal and opposite
Edit:
Mag field due to long wire,
[tex]\vec{B}= \frac{\mu_{o}}{2\pi}\frac{i}{d}[/tex]
Just one other question, I noticed the "finger" cross product rule is different from the wrap around right hand rule (not the curl one, like most calculus textbook teaches one) and this observation uses the wrap around the current rule
Be more specific.
Are you referring to the rule which gives the direction of the B field around a current carrying wire, as "the wrap around right hand rule" ?
Yes that one.
Another question
If I want to find the B-field created by the wire on the left, why would I use the distance between the wires? Let d be the distance between the wires, so shouldn't I use d + x where x is a positive quantity.
flyingpig said:
Yes that one.
That's NOT a cross product at all. (Referring to the wrap around rule)
One question at a time, please! Your threads tend to get convoluted when you have multiple questions and/or topics in one post.
Another question
[STRIKE]If I want to find the B-field created by the wire on the left, why would I use the distance between the wires? Let d be the distance between the wires, so shouldn't I use d + x where x is a positive quantity.[/STRIKE]
OKay I will make a new thread and ask it there
No, it's OK now. Just didn't want to discuss two things in that one post -- plus it was a chance to give you a hard time. LOL
Why would you want to use d+x?
You need the B field (produced by the left wire) at the location of the wire on the right. The distance from on to the other is d.
Let x = 0 if you like.
The thumb rule can be used to find the direction of cross product (if I'm getting correctly which rule is flyingpig talking about)
Cupid.C,
Look at posts 12, 13, and 14.
  • · Replies 0 ·
