Calculating Terminal Voltage of Batteries with Opposing Currents
  • Thread starter Thread starter pb23me
    Battery Emf
The discussion revolves around calculating the terminal voltage of two batteries with opposing currents. The problem involves given electromotive forces (EMFs) and internal resistances of the batteries, as well as an external resistance in the circuit.
  • The original poster attempts to apply Kirchhoff's rules to determine the current and subsequently the terminal voltage using the formula Vab=emf-Ir. However, they express uncertainty about their results.
  • Some participants question the direction of the current and the resulting polarity of the voltage drops across the internal resistors, suggesting that this could affect the terminal voltage calculations.
  • There is a request for clarification on the appropriate equations to use in this scenario.
The discussion is ongoing, with participants exploring different interpretations of the problem and the implications of current direction on terminal voltage. Some guidance has been provided regarding the importance of considering current direction and polarity, but no consensus has been reached on the correct approach.
The original poster indicates a time constraint due to an upcoming test, which may influence the urgency of resolving the problem. There is also an acknowledgment of the complexity introduced by opposing currents in the circuit.
pb23me
determine the terminal voltage in each battery.
Emf1=18V
r1=1 ohm
EMF2=12V
r2=2 ohm
R=6.6 ohms
also the batterys currents are opposing each other.
Vab=emf-Ir
i used kirchnoffs rule to find the current I , 18-I6.6-12-I2-I=0 and got I= .625 then i thought i would just use Vab=emf-Ir to find the terminal voltage of each battery however I am not getting the correct answer... could someone please explain this to me i have a test tomorrow morning and i really need to figure this out! the answers i got were 17.375 for the 18V batt and 10.75 for the 12V batt
Watch out for the current direction and the thus the polarity of the voltage drop it creates on the internal resistors. If current is being forced into a battery's positive terminal it's possible for it to have a higher terminal voltage than its internal EMF.
so on the larger voltage batt would i use equation Vab=Emf-Ir = 18-(.625*1) and on the batt with voltage being forced across it use Vab=Emf+... idk
what are the equations you would use in this situation?
Yes. It can be helpful to sketch in your current and the polarities of the voltage drops across the resistors. You did fine writing the KVL loop equation.
13K
15K
