| New Reply |
3 or more transistor darlington |
Share Thread | Thread Tools |
| Mar30-11, 10:36 AM | #1 |
Hello Experts,
My darlington pair cannot amplify the signal to the desired level. To further amplify, is it as simple as adding another transistor (all NPN) where the Emitter of the second transistor is fed into the base of the 3rd transistor and this 3rd transistor collector is shorted to the collectors of the 1st and 2nd transistor? And does it mean signals can be amplified like this infinitely? regards Ramone |
| Apr1-11, 12:01 PM | #2 |
Hi experts, please could you confirm if it is correct that i can amplify output from a darlington pair with a 3rd amplifer connected as described?
regards Ramone |
| Apr1-11, 12:07 PM | #3 |
Lets start with a schematic.
| Apr1-11, 12:32 PM | #4 |
Yes you can add further transistors to the amplifying chain so long as you can overcome the problems.
1) Each transistor adds to the pedestal voltage. 2) The thermal and noise effects are multiplied by each added transistor. 3) You can arrange for the collector and base currents to match at each stage interface. 4) You can overcome the degradation of frequency response due to the capacitance of each additional stage. Having said all that, several famous manufacturers have successfully employed darlington triples in high power audio amplifiers. go well |
| Apr1-11, 12:54 PM | #5 |
Recognitions:
What AverageSupernova said.
The gain of the complete circuit, and the gain of the transistor, are two different things, and only they are often intentionally orders of magnitude different from each other. |
| Apr1-11, 01:15 PM | #6 |
Also the change in bias and gain with temperature may be too much to be useful in the circuit. Out of curiosity I once designed in SPICE but never actually built a "darlington" using a FET and a BJT that seemed to work quite well.
| Apr1-11, 01:24 PM | #7 |
Recognitions:
| New Reply |
| Tags |
| darlington |
| Thread Tools | |
Similar Threads for: 3 or more transistor darlington
| Thread | Forum | Replies | ||
| Moisture detector with darlington | Engineering, Comp Sci, & Technology Homework | 6 | ||
| Estimating Vc of transistor (darlington) | Engineering, Comp Sci, & Technology Homework | 4 | ||
| Darlington Pair | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Darlington pair question | Electrical Engineering | 2 | ||
| Transistor darlington pair question | Electrical Engineering | 6 | ||
