Which Trig Function Should You Use to Solve for c in a Right Triangle?
The discussion revolves around solving for the sides of a right triangle using trigonometric functions. The original poster seeks clarification on which trigonometric function to use to find the hypotenuse, c, given one side and an angle.
  • Participants explore the choice of trigonometric functions (tan, cos) for solving for the hypotenuse, questioning why certain functions are preferred over others based on the given information.
Some participants have provided insights into the conventions of trigonometric functions in relation to triangle sides and angles. There is acknowledgment that multiple methods exist for finding the hypotenuse, and the discussion is examining the reasoning behind selecting specific functions based on the problem's parameters.
There is a mention of potential confusion arising from using calculated values from other parts of the problem, highlighting the importance of using initially given values to avoid errors.
land_of_ice
Trig right triangle solving question How do you know if you should pick tan, cot, etc for the last part?
if b = 2 , A =40 , find a,c, and B
I found all of them except for c , how do you get c
There's a part almost at the end that goes like tan40 degrees = a/2 and Cos 40 degrees = 2/c
Why do you know to pick Cos 40 , why not tan40 or cot of 40 for that last part there?
What "last part there"? You haven't included whatever you're talking about in your post.
A guess about the use of cosine: To find an unknown with a trig function, you must have an equation that has the unknown in it along with other known information. If you want to find c and cosine involves c, use cosine.
There is often more than one way to solve for an unknown. If c is the hypotenuse you can also use [tex]c^2 = a^2 + b^2[/tex] to solve for it after you find b.
Can you upload a picture that explains this?
My guess is, although Stephen Tashi is right, it's usually best to only use values given in a question if you can, just in case your values calculated in other parts of the question are wrong, which could cause confusion if you get odd answers later on.
The convention is that, in a triangle, sides labeled a, b, c are opposite angles labeled A, B, C respectively.
And, in right triangles, by convention, C is the right angle and c is the hypotenuse.
Back when you first learned about trig functions you were supposed to have learned something like:
sine= opposite side/hypotenuse,
cosine= near side/hypotenuse
tangent = opposite side/near side
Given angle A and side b, you think- a is the side opposite angle A and b is the other leg, the side "near" angle A so the appropriate formula is "tangent= opposite side/near side": tan(A)= a/b or tan(40)= a/2. Then solve for a.
To find c, given only angle a and angle b, you think, c is the hypotenuse and b is the "near" side to A so the appropriate formula is "cosine= near side over hypotenuse":
cos(A)= b/c or cos(40)= 2/c. Then solve for c.
Of course, if, at this point, you have already solved for a, you could think "sine= opposite side over hypotenuse": sin(40)= a/c. Or, as Stephen Tashi said, you could use [math]c^2= a^2+ b^2[/math]. However, I agree with sjb-2812 that it is better to use the initially given values- you will not propagate arthmetic errors.
  • · Replies 19 ·
10K
