Is the inverse-square law valid for all cosmological distances?
  • Context: Graduate
  • Thread starter Thread starter StateOfTheEqn
    Cosmological Law
The discussion centers on the validity of the inverse-square law at cosmological distances, particularly in relation to different Friedmann models (k=-1, 0, +1) and its implications for the observed acceleration of the universe's expansion. Participants explore theoretical frameworks, potential modifications to gravity, and the impact of these concepts on cosmological observations.
  • Some participants argue that the inverse-square law is only valid at all distances in the k=0 Friedmann model, suggesting that its validity is contingent on the flatness of space.
  • Questions are raised about whether the current consensus model's value for k=0 assumes the validity of the inverse-square law, which could imply a circular argument.
  • There is speculation that modifications to gravity beyond General Relativity could potentially explain cosmic acceleration, although no compelling models have been presented that fit observations.
  • Some participants assert that the cosmological constant model (ΛCDM) adequately fits current cosmological data, while others express skepticism about its acceptance and propose alternative explanations for acceleration.
  • Concerns are voiced regarding the heavy reliance on the inverse-square law in cosmological methodologies, with some participants questioning its foundational assumptions and empirical verification at cosmological distances.
  • Participants discuss the possibility that the apparent acceleration in the universe's expansion could stem from incorrect assumptions about the inverse-square law's applicability to standard-candle distances.
  • There is mention of the potential for future weak lensing surveys to distinguish between modified gravity theories and dark energy models.
  • Some participants note that deviations from General Relativity have been explored but have not successfully explained observational discrepancies.
Participants express a range of views on the validity of the inverse-square law and its implications for cosmology. While some agree on the adequacy of the ΛCDM model, others challenge its assumptions and propose alternative theories. The discussion remains unresolved with multiple competing perspectives on the role of the inverse-square law in cosmological observations.
Participants highlight the complexity of assumptions embedded in cosmological equations and methodologies, particularly regarding the inverse-square law. There are unresolved questions about empirical verification of the law at cosmological distances and the implications of different values for k in the Friedmann equations.
StateOfTheEqn
Among the three Friedmann models k=-1,0,+1, the only model in which the inverse-square law is valid at all distances is that for k=0. In other words, its validity depends on the flatness of space. It is easy to show using the R-W metric with k=+1 that objects get magnified and that effect increases with distance. The magnification not only affects the apparent size but also affects the brightness of 'standard candles'.
Two questions:
(1)Is the value for k=0 in the current consensus model calculated assuming the validity of the inverse-square law? That would obviously create a circular argument.
(2)By affecting the brightness of distant standard candles, can a failure of the inverse-square law account for the apparent acceleration in the expansion of the universe by underestimating the distance of those galaxies producing red-shifts greater than that predicted by the Hubble relation?
Space news on Phys.org
Nope. The measurements we use take General Relativity fully into account. There is no reduction to a Newtonian approximation for cosmological observations.
It may potentially be the case that if we modify gravity beyond General Relativity, we might be able to explain the cosmic acceleration. Nobody has yet put forward a compelling model for doing so that also fits observation, however. Nevertheless, one of the potential benefits of future weak lensing surveys is that they may be able to distinguish between some sorts of modified gravity and some sort of dark energy.
I was under the impression that [tex]\Lambda[/tex]http://en.wikipedia.org/wiki/Lambda-CDM_model" (which is just GR with non-zero cosmological constant, [tex]\Lambda[/tex], and appropriate mass-energy boundary conditions) adequately fits the cosmological data gathered so far.
Yes. This is accurate. Some people (unreasonably, I feel) don't like the cosmological constant, and so attempt to propose ways of explaining the acceleration without it.
I have attempted to do something of a literature review on the various distance measurements used in cosmology that depend on the inverse-square law. It is often difficult when looking at an equation to see the assumptions contained within. So far, the most enlightening paper I have found is at
http://www.ssl.berkeley.edu/~mlampton/ComovingDistance.pdf
It seems the inverse-square law is deeply embedded in much of the methodology of current cosmology. To me, that seems to be hanging a very heavy weight on a very weak hook.
Why? General Relativity is exceedingly well-tested, and in cosmological studies, many sorts of deviations from General Relativity have been investigated. They simply don't explain any of the apparent observational discrepancies, so as yet there is no reason whatsoever to believe that they are valid.
The question I was trying to address is this: Could the apparent acceleration in the expansion result from the failure of the inverse-square law to give correct standard-candle distances? In other words, is the acceleration real or the product of false assumption(s) about the validity of the inverse-square law?
The cosmological equations derived from GR cover three cases:k=-1,0,+1. The only one consistent with the inverse-square law at all distances is k=0.
To question the validity of the inverse-square law is not the same as challenging the validity of GR.
Well, yes, many modifications of gravity to explain the apparent acceleration have been attempted. The ones that are most strongly theoretically-motivated (and they're still pretty speculative even then) don't fit the data.
Our best bet at really examining this in detail is by examining the growth of structure in the universe by use of weak gravitational lensing surveys. If reality is described by General Relativity + dark energy (either cosmological constant or something else), then there are certain relationships that the growth of structure must necessarily follow. Violation of these relationships will be evidence for some sort of deviation from General Relativity.
In general, however, the theoretical bias is strongly against this sort of deviation from General Relativity. We generically expect that General Relativity should be modified at high energies, not low energies: it is extraordinarily difficult to produce a theory of gravity that is modified at low energies (long length scales) without violating solar system tests of gravity.
This has worried me too. The different values for k in the Friedman equations would certainly affect light luminosity at distance, but it seems that there are many other possible factors that could affect light over such long distances, quite outside GR. If there have been any empirical verifications of the inverse-square law at cosmological distances, I would like to know about it.
For that matter, isn't it also possible that red shifting of light could be affected by great distance?
Regarding the need to revise the standard cosmological models; what about the introduction the expansion phase, or the need to introduce dark matter and dark energy. These all smell like fudge factors to me.
Please enlighten me, if you think it possible.
Assuming the laws of physics are time invariant, how would redshift be affected by distance? That appears to invoke a 'special' reference frame.
So this may be a stupid question... but what is the inverse-square law everyone talks about?
Gravity, as described by Newton, reduces in strength proportional to the inverse square of the distance between objects. General Relativity, the theory of gravity first produced by Einstein, doesn't quite follow this rule for very small or very large distances.
Whovian said:
I don't completely understand. At small distances, it's a good enough approximation in any case, but we have no evidence to suggest that it holds (or doesn't hold) at large distances. So why would challenging the validity of it be so "blasphemous?"
It's not blasphemous. It's just against the evidence. GR describes remarkably well the large-scale evolution of the universe, and modifications of GR that change how GR behaves on large scales tend to fail to do so.
But GR, as stated already, doesn't actually exhibit the inverse square law for a "nonflat" Universe. So my point was, why would questioning the inverse square law be ... oh ... I absolutely failed, missing the word "not" in the post I quoted. Editing. So I was arguing against my own opinion (for lack of a better word, there are reasons opinion is completely unsuitable here.)
I'm going to assume that your first sentence here still stands :)
The thing to bear in mind is that for most scales of interest here, the inverse square law holds in General Relativity because the spatial curvature and dark energy contributions are small. It is only at very large scales that there is a noticeable departure. On the scales of galaxies and galaxy clusters, the inverse square law holds exceedingly well.
So I think they are talking about light intensity decreasing as the inverse of r squared, but I'm not completely sure what the point is there. I think the point missed by original poster is that in GR, there is no well-defined universal length measure. The inverse-square law holds for a certain distance measure, defined precisely to be such that it holds.
I thought this thread started talking about the inverse-square law of LIGHT intensity, not gravitational intensity. Are these not distinct?
Sorry, yes, they are quite distinct.
The inverse square law for light intensity simply does not hold in an expanding universe, as the light is redshifted, which causes it to lose energy in proportion to (1+z). This means that the effective inverse square law for light in an expanding universe becomes:
[tex]L(z) = {L_0 \over (1+z)r^2}[/tex]
Here [itex]L(z)[/itex] is the observed luminosity, while [itex]L_0[/itex] is what the luminosity would be at r=1, z=0.
Yes, but I guess the relevant bit is that it does hold for the number density of photons, if you define your distance appropriately. There exists a way of measuring distance called "luminosity distance", with the property that the number density of photons decreases as r^-2. This can be nicely defined through some elementary geometry to be
[tex]d_L = \sqrt{\frac{A_O}{\Omega_S}}[/tex]
where [itex]A_O[/itex] is the area of a bundle of light rays at the observer, and [itex]\Omega_S[/itex] is the angle the light rays leave the source.
Then one can additionally correct for the redshift of the photons, and define
[tex]\tilde{d}_L = (1+z) d_L[/tex]
arriving at the "usual" definition.
Yes, but few people find this sort of distance measure understandable, because it is only defined in this way: so that it has the expected falloff with distance.
You've made me realize, however, that I forgot a factor of (1+z). It should be:
[tex]L(z) = {L_0 \over (1+z)^2 r^2}[/tex]
I forget what the physical explanation is for the second factor of (1+z) is, unfortunately. But the distance [itex]r[/itex] here, properly [itex]D_M[/itex], is quite easy to understand: it's the distance you would obtain if you froze the expansion, bounced some light rays around, and measured the travel time of said light rays.
I think this is true only in a homogeneous and isotropic universe - not in general.
I was speaking in the context of a homogeneous, isotropic expanding universe, yes. Things obviously get more complicated if you try to consider more complicated space-times. But the reality is that this is the universe we live in.
To be fair, having one factor of 1+z less doesn't really make it that much more complicated, now does it?
I don't understand what you mean. In what situation is there only one factor of (1+z)?
If you define the formula you gave in terms of luminosity distance instead of DM, it holds for all spacetimes. Using that, you'd have simply [itex]L(z) = L(0)/D_L^2[/itex]
Your statement here has nothing to do with my question.
I can show one situation involving Special Relativity where the inverse square law does not hold, which would as you suggest impinge on the assumed relationship between the brightness of a standard candle and its distance. Let has say we had a hypothetical flat universe and completely ignore gravity. In such a universe and assuming some sort of initial explosion, there would still be a Hubble relationship between the recession velocities of distant galaxies and their distances, with more distant galaxies receding faster. The main difference is that the velocity of the receding galaxies would be a function of the relativistic Doppler Shift rather than the classic Newtonian Doppler shift that is currently assumed. In this flat space model the brightness of distant galaxies would be subject to relativistic aberration or beaming sometimes known as the headlight effect. The observable effect is that the brightness of a receding object with a high relativistic velocity would be much less than a simple application of the inverse square law would imply. In turn distant dim objects would appear to be much further away than the inverse square law suggests. The effect is almost insignificant for objects with low recession velocities and ramps up exponentially for recession velocities that are a significant fraction of the speed of light. Any distant galaxy that is currently assumed to be receding at superluminal speed would always be receding at less than the speed of light in the simplistic relativistic flat space model.
Why do you think that Newtonian Doppler shift is currently assumed?
  • · Replies 23 ·
