| New Reply |
verify derivative of a dot product. |
Share Thread | Thread Tools |
| May11-11, 12:44 PM | #1 |
Let [tex] \vec w(t) \;,\; \vec v (t) [/tex] be 3 space vectors that is a function of time t. I want to verify that:
[tex] \frac {d(\vec w \cdot \vec v)}{dt} = \vec v \cdot \frac { d\vec w}{dt} \;+\; \vec w \cdot \frac { d\vec v}{dt} [/tex] I work through the verification by splitting w and v into x, y, z components, do the dot product and take the derivative to verify already. Just want to run this by the expert to confirm. Thanks Alan |
| May11-11, 01:58 PM | #2 |
That will work.
Note, however, that by definition, the dot product has the distributive property of multiplication: [tex](u+du)\cdot(v+dv)=u\cdot{v}+u\cdot{dv}+v\cdot{du}+du\cdot{dv}[/tex] For all vectors u,du,v and dv. Thus, the result for the derivative ought to be apparent.. |
| May11-11, 02:39 PM | #3 |
But I don't see how [tex](u+du)\cdot(v+dv)=u\cdot{v}+u\cdot{dv}+v\cdot{du}+du\cdot{dv}[/tex] relate to my original question. Please explain. Thanks Alan |
| May11-11, 03:05 PM | #4 |
It shows that a dot product works "just like" a normal product, and thus, the differentiation rule "ought" to be the same (i.e, your result).
However, for rigorous verification, you should do as you've done. |
| May11-11, 03:15 PM | #5 |
Thanks
| New Reply |
| Thread Tools | |
Similar Threads for: verify derivative of a dot product.
| Thread | Forum | Replies | ||
| Dot Product of a Vector with its Derivative | Calculus | 2 | ||
| Taking the derivative of a dot product | Calculus & Beyond Homework | 0 | ||
| derivative of the cross and dot product | Advanced Physics Homework | 3 | ||
| cross product derivative | Calculus & Beyond Homework | 3 | ||
| derivative of a dot product | Calculus | 4 | ||
