New Reply
[Dynamics] Vibration response problem.
Share Thread Thread Tools
May25-11, 09:11 PM   #1
1. The problem statement
I have this vibration question, in which i have approach to solve and I came very close to the actual answer but not accuracy correct solution.
My work-out solution is 0< k < 28.7 N/m
And the correct answer is 0 < k < 27.4 N/m
I have tried everythink checking the number or around ups etc. But I can not seem to get 27.4 N/m.
I appreciate people proof-read, and If they could indentity small error in my working-out
Thanks.....................
2. Question & my attempt
the elements of a displacement meter used to study the motion
yB = bsinωt of the base. The motion of the mass relative to the frame is recorded on the rotating drum. If L1= 360 mm, L2= 480 mm, L3= 600 mm, m = 0.9 kg, c = 1.4 Ns/m and ω = 10 rad/s, Determine the range of the spring constant k over which the magnitude of the recorded relative displacement is less than 1.5b. It is assumed that the ratio ω/ωn must remain greater than unity.
My approach: See the attach file, since is headache to copy in this forum.
Appreciate any input, cheers
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
New Reply
Thread Tools
Similar Threads for: [Dynamics] Vibration response problem.
Thread Forum Replies
[Dynamics] Vibration problem. Engineering, Comp Sci, & Technology Homework 0
vibration problem!!!!! Introductory Physics Homework 5
vibration problem Engineering, Comp Sci, & Technology Homework 0
Vibration problem Introductory Physics Homework 1
