Correctly calculating gravity classically.
  • Context: Graduate
  • Thread starter Thread starter Stupid Theory
    Gravity
The discussion revolves around the classical calculation of gravity, specifically the formula F = G*m1*m2/r^2, and its limitations. Participants explore the assumptions behind this formula, propose alternative approaches to calculating gravitational forces, and examine implications for phenomena like Mercury's precession and the Pioneer anomaly.
  • Some participants express that while the formula G*m1*m2/r^2 is a good approximation, it does not fully account for the size and mass distribution of objects, which may lead to discrepancies in real-world applications.
  • One participant proposes a new approach to gravity that considers the gravitational effect of all mass at varying distances, suggesting a formula that incorporates the distribution of mass in a system.
  • Another participant argues that the center of mass is not the only factor in gravitational interactions and emphasizes that the formula is accurate when applied correctly to point masses.
  • There is a suggestion that the discrepancies observed in phenomena like Mercury's precession could be due to the need for relativistic calculations rather than flaws in classical mechanics.
  • One participant questions why their proposed method for calculating gravity is not more widely used, given that it could provide insights into mass distribution and gravitational effects.
  • Another participant references the shell theorem and discusses the treatment of anomalous precession as errors in classical physics rather than as information about mass distribution.
Participants express differing views on the validity and applicability of the classical gravitational formula, with some supporting its accuracy under certain conditions while others propose alternative models. The discussion remains unresolved with multiple competing perspectives on the nature of gravitational interactions and the implications of mass distribution.
Participants note the limitations of the classical formula in accounting for non-point masses and the complexities involved in integrating mass distribution into gravitational calculations. There is also mention of the need for relativistic considerations in specific cases, such as Mercury's orbit.
Stupid Theory
I'm someone who's always been a person who has casually interested in math. Recently, after a long break, I've regained a bit of this interest and looked into how gravity is calculated. I'm sure most know the G*m1*m2/r^2, and while a good approximation of gravity, it is not completely correct. We see this when the real world has slight differences from what is expected by this formula and what actually happens. I gave a great deal of thought to why this formula finally falls short and came to an answer. We make an assumption by assuming that calculating by the center of mass has no effect on how gravity interacts. I tested this theory by comparing the results of multiple gravitating forces on each other, and how it differs from if just one object had been gravitating. There is no part in this formula which accounts for the size and mass distribution of objects.
So we come to part two, I thought about how gravity would need to be calculated in order to account for this difference. The answer is a rather interesting and simple idea. At any equal distance from a central point, all mass will have an equal effect of gravity, simply in different vectors. Why not instead of thinking of gravity as a force between two points, think of it as the sum of the surface of all spheres 0 to infinity from your central point. Now, we just need to figure out, what is the gravitational that each sphere's surface will have? Surpringly simple, if the Center of mass for this surface is R(x) distance from the center, and surface is at a radius of x, and the mass of this surface is M(x), the formula is:
F= G*M1*M(x)*R(x)/x^3 applied at vector of M1->R(x) So the total gravitational force on any object for any number of other objects at any distances, would be the sum 0 to infinity of said object. Substitute in points, and this gives the same answer as Newtonian physics as R(x)/x^3 will cancel to 1/x^2 if R(x) and x are equal.
And finally, part 3. Albeit exceedingly more complex, since you need to develop a formula to describe the distribution of mass in the system, why isn't a formula like this used for classical gravitation? It predicts small changes from standard classical models with a quick overview. The biggest one is that objects that get very close have their gravitational pull in a way 'dispersed' into less coherent directions. This would especially be noticeable in objects with highly eccentric orbits. Gravitation in these situations would be slightly less than expected in Newtonian, and approach but never quite reach Newtonian as objects get far. This explains mercury's precession, and explains the pioneer anomaly in classical mechanics.
I'd love to hear comments from someone more knowledgeable, as I have an entirely self taught knowledge on this subject. Please let me know if I need to give examples. Thanks for reading.
Astronomy news on Phys.org
Yes, it is- if it applied correctly. That is the formula for the gravitational force between two point masses. It becomes approximate when you approximate two masses with non-zero volume as by point masses.
We see this when the real world has slight differences from what is expected by this formula and what actually happens. I gave a great deal of thought to why this formula finally falls short and came to an answer. We make an assumption by assuming that calculating by the center of mass has no effect on how gravity interacts.[\quote]
What? On the contrary, the "error" in that approximation is in assuming that the center of mass is the ponly thing that counts!
Why do you think it isn't? It is a standard problem in any Calculus text to use integration to find the gravitational field of a non-point mass.
ST - Frankly, I do not know what you are talking about. Newtonian theory simply accommodates the behavior of one accumulated mass in the presence of another accumulated mass. It is accurate enough to explain all visible planetary motion except that of Mercury. Mercury is close enough to the sun that relativistic calculations are required.
I don't understand. You say on the contrary and seem to be agreeing. I have dyslexia, did I say something that makes no sense. Of course its not the only thing that counts, the formula has many parts, that to me seems to be the only one that was a mistake.
Interesting. I am reading up an shell theorem. Given that apparently my theory already has a name, why are anomalous precession taken as a error in classical physics, instead of information on the distribution of mass within objects?
  • · Replies 16 ·
  • · Replies 33 ·
  • · Replies 51 ·
  • · Replies 21 ·
  • · Replies 16 ·
