Prove this is greater than or equal to 8
  • Thread starter Thread starter Chinnu
The problem involves proving that for positive values of a, b, and c that sum to 1, the expression \((\frac{1}{a}-1)(\frac{1}{b}-1)(\frac{1}{c}-1)\) is greater than or equal to 8. The context is rooted in inequalities and potentially involves multivariable calculus or algebraic manipulation.
  • Mixed
  • Participants discuss expanding the expression and substituting variables based on the constraint \(a + b + c = 1\). Some suggest using calculus to find a minimum value, while others explore algebraic inequalities.
There are various approaches being explored, including algebraic manipulation and calculus methods. Some participants have proposed using substitution to simplify the problem, while others are considering the implications of symmetry in the variables. No consensus has been reached yet, but several productive lines of reasoning are being developed.
Participants note that \(a, b, c\) are constrained to be positive and less than 1, which influences the behavior of the expressions involved. There is also mention of the potential for using Lagrange multipliers or geometric interpretations based on the symmetry of the problem.
Chinnu
Show that, if a, b, c >0 and a+b+c = 1, then,
([itex]\frac{1}{a}[/itex]-1)([itex]\frac{1}{b}[/itex]-1)([itex]\frac{1}{c}[/itex]-1) [itex]\geq[/itex] 8
The usual math is ok
I multiplied them out to get:
([itex]\frac{1}{abc}-\frac{1}{ac}-\frac{1}{bc}+\frac{1}{c}-\frac{1}{ab}+\frac{1}{a}+\frac{1}{b}[/itex]-1)
= ([itex]\frac{1}{abc}-\frac{b}{abc}-\frac{a}{abc}+\frac{ab}{abc}-\frac{c}{abc}+\frac{bc}{abc}+\frac{ac}{abc}[/itex]-1)
= ([itex]\frac{1-b-a+ab-c+bc+ac-abc}{abc}[/itex])
= ([itex]\frac{ab+bc+ac}{abc}[/itex]) = ([itex]\frac{1}{a}+\frac{1}{b}+\frac{1}{c}[/itex]), ...as 1-(a+b+c) = 0
abc is a small number as a,b,c are all less than 1, and it is and order smaller than
anything in the numerator. OR, since a, b, c < 1,
([itex]\frac{1}{a}+\frac{1}{b}+\frac{1}{c}[/itex]) > 3
Now I don't know what to do. I'm not even sure I'm on the right track...
There may be some other logic I should be using to make this easier, but I don't see it.
According to what you wrote, a + b + c = 1. You haven't used this fact. If you do, you can get an expression that doesn't involve c.
so, use c = 1 - a - b, substitute that into the first equation, and see what happens?
That's what I had in mind, yes.
I tried that, and was able to factor things a lot, but I wasn't able to show that the expression on the left is >= 8.
Where you might go next is to consider w = f(x, y) = (1/x - 1)(1/y - 1)( (x + y)/(1 -x - y)). Use calculus to show that there is a global minimum, and that the minimum value is 8.
I will try this. Also, would it be possible to see if:
[itex](\frac{1}{a}-1)[/itex] [itex]\geq[/itex] 2,
as, if this is done, without loss of generality, it would apply to each, and 2x2x2 [itex]\geq[/itex] 8
The inequality above is true for 0 < x <= 1/3.
I can't judge from your title or first post what level of analysis you have had already. So I'll propose a couple of things:
-- the straightforward one if you've had multivariate calculus is to use Lagrange multipliers, since you have a function and a constraint equation in three variables; you will be able to show easily that the critical point occurs where a = b = c ; you would then reduce the function to one with two variables and use the Second Partial Derivative Test to show that the value 8 is a minimum [the Test with three variable is messier]; this is, I believe, essentially what Mark44 is suggesting
-- a non-calculus approach would be to consider that a + b + c = 1 in the first octant is an equilateral triangular region, the portion of the plane bounded by the coordinate planes; the product in question is plainly infinite at the edges of the triangle, so the interior must contain a minimum for the product; the three-fold symmetry of the region suggests that the "special point" lies where a = b = c = 1/3 ; that gives the "right number" for the product, but what is the behavior of the function?; fix one variable and shift one of the others by a small amount, which automatically shifts the remaining variable; show that any deviation from the special point must give a larger product
11K
  • · Replies 105 ·
13K
  • · Replies 47 ·
