Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Fermi-level Share It Thread Tools Search this Thread image
Old Oct28-04, 04:13 AM                  #1
Mk
Mk is Offline:
Fermi-level
Hey, guys, what's a fermi level?
Old Oct28-04, 04:43 AM                  #2
Kaspah_2k
Kaspah_2k is Offline:
its a level which is relative to the fermi ;)
Old Oct28-04, 05:39 AM                  #3
Galileo
Galileo's Avatar
Galileo is Offline:
Recognitions:
Homework Helper Homework Helper
It's the lowest energy level for a system of fermions.
or... that would be the fermi energy...
Old Oct28-04, 07:12 AM                  #4
Mk
Mk is Offline:
Maybe the level away from fermi-energy? If zero-point energy is the lowest energy, why do fermions have a higher fermi energy?
Old Oct28-04, 07:27 AM                  #5
OldTee
OldTee is Offline:
Think it's the energy level where the probability of finding a fermion for a system of fermions is 50%...
Old Oct28-04, 08:08 AM                  #6
da_willem
da_willem is Offline:
The Fermi level is the temperature dependent 'chemical potential' of a fermionic substance. It is also the energy at wich an obital is exactly half filled. This can be seen from the Fermi-Dirac distribution:
LaTeX Code: f(\\epsilon)=\\frac{1}{e^{(\\epsilon-\\mu(\\tau))/\\tau}-1}
Where LaTeX Code: \\tau is the fundamental temperature LaTeX Code: k_BT , LaTeX Code: \\epsilon the energy of the orbital and LaTeX Code: \\mu the chemical potential or fermi level. This gives the probabality of finding a particle in an orbital with energy epsilon, it is also the expectation value of fermions in that orbital because there can be only 1 or 0 fermions in an orbital because of the Pauli exclusion principle. If you fill in LaTeX Code: \\epsilon=\\mu this yields 1/2.
So for energies below the fermi level orbitals are more than half filled and above they are less than half filled. The Fermi energy is the fermi level at absolute zero temperature.
LaTeX Code: \\epsilon_{F}=\\mu(0)
Old Oct28-04, 08:25 AM                  #7
ZapperZ
PF Mentor
ZapperZ's Avatar
ZapperZ is Offline:
Er.... I think what you are describing is more appropriate for a semiconductor system.
A "fermi level" is the highest energy of the valence electronic band at T=0 K.
For a conductor, the fermi level is the highest energy of the conduction electron in the conduction band. For an intrinsic semiconductor, at T=0 K, it is technically the top of the filled valence band, since the conduction band is completely empty. However, there are many books and people who mix and match the chemical potential that is in the middle of the band gap with the Fermi level. This is where it can create confusion as to what a "fermi level" actually means.
http://edu.ioffe.ru/register/?doc=galperin/l4pdf2.tex
Zz.
Old Oct29-04, 07:57 AM                  #8
da_willem
Zz.
Im now studying for my thermal physics test on monday and what I wrote in my previous post can be found in "Thermal physics" by Kittel and Kroemer. They say the definition I gave of the Fermi level is "often used in the field of solid state physics". So I guess wou're right when you say the meaning of the Fermi-level depends on the field and the book you're reading...
Old Oct29-04, 08:33 AM                  #9
ZapperZ
PF Mentor
ZapperZ's Avatar
ZapperZ is Offline:
And in case you don't know, Kittel also wrote a solid state physics text. :)
Zz.
image image
Reply
Thread Tools
Similar Threads for: Fermi-level
Thread Thread Starter Forum Replies Last Post
Calculating Fermi Level andarr Engineering, Comp Sci, & Technology 1 Apr24-08 06:18 PM
fermi level?? physicist888 Atomic, Solid State, Comp. Physics 1 Jan27-08 08:21 AM
Fermi Level Statistics dink Electrical Engineering 12 Oct16-05 11:42 PM
quasi fermi-level marlon Electrical Engineering 3 Jul26-04 12:07 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
