How does GR handle metric transition for a spherical mass shell?
The discussion centers on the behavior of the metric transition for a static thin spherical mass shell in General Relativity (GR). Participants explore the implications of the Schwarzschild metric in the exterior region and the Minkowski metric in the interior, particularly focusing on the spatial metric components and their transitions across the shell boundary.
  • Some participants assert that the exterior spacetime for a spherical mass shell is described by the Schwarzschild metric for r >= rb, while the interior is flat Minkowski metric for r <= ra.
  • There is a consensus that the temporal component transition is well understood, with the frequency redshift scale factor Sf = V, where V = (1 - rs/r)^(1/2).
  • Participants question how the spatial metric components, specifically Sr and St, behave during the transition from the exterior to the interior region, with some suggesting that St decreases from unity to a fraction of V.
  • One participant notes a previous discussion that proposed an invariant St = 1 across all r, which contrasts with the current view that suggests a varying St in the shell wall region.
  • There is uncertainty about the physical justification for the variation of St, with some attributing it to the nonzero stress-energy tensor T in the shell wall, while others seek a more fundamental explanation based on primitives like V and its derivatives.
  • Some participants emphasize the importance of tangential pressure components of the stress-energy tensor in the matter region, noting their absence in the vacuum region.
  • Links to academic papers are shared, which discuss analytical models for shells and the relationship between extrinsic curvature and the tangent metric factor St.
Participants express multiple competing views regarding the behavior of the spatial metric components during the transition, and the discussion remains unresolved on the justification for the variation of St.
There are limitations regarding the assumptions made about the stress-energy tensor and the nature of the mass shell, particularly concerning the significance of pressure relative to density in the context of a stable shell.
  • #31
The diagram below of a "Flamm's paraboloid" may aid understanding the curvature of space (but not spacetime) outside the event horizon of a black hole. The surface represents a 2D cross-section through 4D spacetime involving the [itex]r[/itex] and [itex]\phi[/itex] coordinates only. In this diagram [itex]r[/itex] is the radius in the horizontal direction. "Ruler" distances in space (e.g. PeterDonis's method of counting small identical objects packed together) are represented by distances along the curved surface. (The vertical direction has no physical meaning at all.)
Allen McCloud, Wikimedia Commons, CC-BY-SA-3.0
The diagram goes all the way to the event horizon, where the surface becomes vertical at the bottom of the "trumpet". So, for the example being discussed in this thread, you need to slice off the bottom part of the surface. The interior of the shell could then be represented by a horizontal flat circular disk almost capping the bottom of the remaining trumpet, but there is then a gap to be bridged between the disk and the trumpet to represent the shell. I've no idea whether is possible to construct a curved surface to bridge that gap which would correctly represent the geometry within the shell. (I suspect it might not.)
The mathematics of Flamm's paraboloid is discussed on Wikipedia at Schwarzschild metric: Flamm's paraboloid.
P.S. Flamm's paraboloid does not represent the gravitational potential. The potential has a somewhat similar shape but it's a completely different formula.
  • #32
I was thinking of the "bridge" surface as being basically a section of a torus, with the "bottom" part merging into the horizontal circular disk representing the interior, and the "top" part having just the right slope to merge into the exterior paraboloid at the appropriate circular "cut" from it. If "torus" is interpreted generally enough (basically to allow an elliptical "cross section" as well as a circular one), would that be a plausible candidate?
  • #33
It certainly sounds plausible -- that's pretty much what I had in mind myself. But on the topic of embedding an arbitrary curved manifold into a higher-dimensional Euclidean space, I am a bit out of my depth. I think, in general, there's no guarantee it can be done with just one extra dimension, i.e. you usually need more. It may be just good luck that Flamm's paraboloid works in just 3 dimensions for the exterior Schwarzschild solution.
And even if you can produce a 2D curved surface in 3D space to represent the entire "shell" space[STRIKE]time[/STRIKE], I'm not sure if the "junctions" (where there's a discontinuity in the energy-momentum-stress tensor from zero to non-zero) would need to be smooth -- maybe there would a sharp "crease" in the surface at these points?
  • #34
This is leading to a thought I've been having for a while, but didn't want to distract this thread. Simply, why bother with a shell at all? In this case, you have a perfectly continuous but non-smooth manifold joining the SC geometry to Minkowski geometry inside a chosen r value. The metric can be made continuous, a single global chart can be used, you just have metric derivatives undefined on one surface. This is perfectly analogous to taking a ball and cutting it in half, and treating the resulting boundary as a 2-manifold. No one would consider that a weird or inadmissable surface from a geometric point of view. As for physics, the shell-less geometry would lead to failure of EFE on the junction surface (only). It may simplify things if Q-reeus could state his fundamental issue for this simpler case - I still don't get his confusion at all. This shell-less manifold wouldn't be strictly physical, but all physics off the shell, and almost all physics going through the shell (e.g. geodesics) would be perfectly well defined.
  • #35
Q-reeus said:
Agree with essentially all the rest above, but not the probable implication that stress in the shell can account for anything remotely significant re transition through shell wall.
Why not? Your argument regarding the relative size of the pressure and energy density is not relevant. So what logical reason could you have to disagree?
Q-reeus said:
There is a severe logical chasm imo.
Agreed. The reference that I posted derived the pressure terms directly from the Einstein field equations. So there is no logical gap there. But you, without touching the math, claim to know that the effect is too small. A logical chasm indeed.
  • #36
The paper I mentioned some posts back, which I haven't been able to find again, basically derived this case as the limit as the shell thickness goes to zero, with the shell mass remaining at a fixed positive value.
  • #37
Right, and a zillion posts ago in the black hole thread, I wrote down its metric simply from the continuity of metric requirement (using isotropic SC coords, because it was easier to state the junction that way).
  • #38
PeterDonis said:
But why would the appearance of a test sphere to someone far away make any difference, when we've already established that, to an observer right next to the test sphere, it would appear spherical, *not* distorted? To me, that local observation is a much better gauge of whether space is isotropic than the observation of someone far away, particularly when the light going to the faraway observer could be distorted by the variation in gravity in between...
There is imo an unhealthy obsession in GR circles with the tendency to look at everything from the 'local' perspective. Casting everything in terms of invariants has it's advantages, but also disadvantages in that one can lose site of the forest for the trees. Typical example - when BH sceptics bring up EH 'time freeze' and related issues, they are brow beaten with the argument that SC's are deceptive/misleading and the only 'proper' perspective is that of the invariant worldline of an infalling observer for whom 'time freeze' etc does not apply. Which to my mind brushes under the carpet serious issues evident from an external observer's perspective.
But enough of generaized criticism. To answer your specific point Peter, just consider redshift. All but the most uninformed newbe has little trouble appreciating that redshift cannot be locally observed because it is inherently a differential issue - clock-rate 'here' vs clock-rate out 'there'. We have no conceptual issue with this (well, those insisting it's exclusively a 'tired light' 'energy drain' thing might). So why should spatial measure be any different? What is the apparent fundamental divide? If effect of metric on time-rate is properly a relational, nonlocally experienced, justifiably physical thing, what allows that length measure - the spatial component of SM in particular, are *not* likewise a physically meaningful, nonlocally observed relational thing? Seems illogical to me.
Want an 'extreme' example? my 'predjudice' is that BH's are, in one important sense, propped up on the basis that, just as SC's indicate, tangent spatial components are unaffected by gravitational potential. If however *all*, spatial components at least, are subject to the J factor, we find that the physical size of a notional BH shrinks to zero before it in fact can qualify as BH - as of course referenced to a distant observer. That leaves out other matters such as whether 'gravity actually gravitates' but indicates that there are drastic consequences as to the proper, physical implications of metric on a relational, 'distant observer' basis. So it's vitally important to know just what that test sphere will, abberation free, actually be *measured* by the distant observer imo. And my assumption is SM via SC's tells us it will be an oblate spheroid with axial ratio J:1. I further think nature has a different idea - it will to first order remain spherical but shrunk. [unavoidably there will be observed second and higher order distortions simply owing to metric necessarily being a function of r in any reasonable metric theory] Hope you all get my drift here.
  • #39
DaleSpam said:
The exterior SM is a vacuum solution, so there isn't any matter contribution in the exterior SM.
Have you taken a course in "how to be an effective agent provocateur", by any chance? I consider your comments disingenuous. You surely must have read, prior to your above comments in #30 (entry timestamp: 03:30 PM), my own clear statement in #28 (entry timestamp: 12:54 PM)
"I entirely meant shell matter's contribution to the exterior, SM region, and said so explicitly in #25."
You are capable of discerning the fundamental significance of replacing 'in' with 'to' in your above distortion of what I was on about in #25, right?
That transition requires non-zero spatial components of the stress-energy tensor, i.e. stress and pressure. The large contribution of the energy density is in the wrong place to matter for the spatial components of the curvature.
Will have more to say on that claim in responding to your #35
  • #40
DaleSpam said:
Originally Posted by Q-reeus:
"Agree with essentially all the rest above, but not the probable implication that stress in the shell can account for anything remotely significant re transition through shell wall."
Because it's entirely relevant.
Yes, and it's you, and the formal system you trust is right, that has the logical chasm problem. You keep implying I'm some kind of ill-informed dumbo, but do so on the basis of distorting what I have actually argued. OK , gloves are off. Should you not duck the challenge, think I'm about to make you look stupid, and happy to do so. Sure, I'm not up with the tensor math and you are. Good for you. But I will claim a certain insight on this issue that either you entirely lack, or are unwilling to acknowledge for whatever reason. So stress in the shell wall solves it all? OK, here's the task for you - who knows the math. In #8 values were given for a monster, 8 ton 'toy globe' subject to ~ atmospheric pressure. Go ahead and work out the self-gravity value instead (floating in space, fully evacuated interior). My 'lazy' estimate - ca 10-30 times the mass contribution to T00 as source of g00, which is all here that determines exterior SM, and the depressed interior MM values (give or take half a dozen orders of magnitude, as if it matters really). The incredibly tiny shell stresses, virtually pure biaxial compressive, somehow can effect a reduction in the tangent metric components going from rb to ra? Convince me please.
Oh, here's a possible fly in the ointment. Add the tiniest puff of fresh, pure mountain air inside the shell. Just a touch. Just enough to reverse the sign of shell hoop stresses and blow the amplitude up by, say, a mere factor of one million. And this is still looking anything but Alice-in -Wonderland nonsense?! Good luck, genius!
  • #41
The difference is simply that there is no agreed upon standard for comparing distant lengths as there is for comparing distant times. Because there is no standard you simply have to clearly define the experiment you want to perform in order to determine the length as measured by a distant observer. Depending on the complexity of the experiment it may be difficult to calculate, but in principle you should be able to determine the result of that experiment which you would call the length as measured by the distant observer.
  • #42
Your insight is simply wrong. It is not based on logic, but comes from ignorance and a prejudice against GR. You dismiss it as illogical and non-self-consistent without bothering with the effort of learning the math which ensures its self-consistency.
I will do that. It will take a few days.
Sure, that is not in doubt. The issue is the relative contribution of the stresses and the mass to g11, g22, and g33. The relative contribution is infinite since the mass does not contribute at all.
Yes, but I doubt that you will be convinced.
  • #43
My angle on this - either SC's have readily testable, remotely determinable, physical consequences for *all* components, or not. If not, we are giving heed to a fantasy.
  • #44
I will accord that this tirade is genuinely motivated. I'll even commend you for doggedly pursuing the topic. But we shall see.
My 'challenge' was partly rhetorical. You did stop and think a bit about the 'fly in the oinment'? If you do labour on for a few days and somehow manage to stitch a credible answer (boundary fitting magic), I will immediately point you to the 'puff of air' dilemma. This is the difference between knowing the math of received wisdom, and having some insight that looks outside the square. Please, concede on this one. The task of getting a consistent physics here is impossible.
  • #45
First of all, as DaleSpam noted, there is an agreed standard for comparing times at distant locations; in fact, the redshift basically *is* that standard. There is no agreed standard for comparing distant lengths.
Second, the redshift is coordinate independent. The "spatial measure" as you are using the term is not, which is why I was so careful in previous posts to describe everything in terms of areas and the "non-Euclideanness" of space, without saying anything definite about "distance measure". See below.
I think you mean "K factor" since that's the one I defined relative to the spatial components; the J factor affects the time component. The point is that which spatial components are affected by the K factor is coordinate dependent. So the "spatial measure" as you are using the term is not a good way to judge the actual physics.
It's worth walking through this in some more detail. Go back to the picture I gave in terms of 2-spheres with gradually decreasing areas. The areas of these 2-spheres, and the volume in between neighboring 2-spheres, are physical observables; we can measure them by covering the area or packing the volume with little identical objects and counting them. So the factor K, that I defined, is a coordinate-independent quantity and represents actual physics.
However, there are different ways in which this actual physics can be represented in a coordinate system. The different radial coordinate definitions that I described are different ways of *labeling* the 2-spheres, and different labelings lead to different conclusions about which "spatial components" are affected by the K factor. If we use the Schwarzschild r coordinate, we label each 2-sphere with a coordinate r equal to the square root of its physical area divided by 4 pi. With this labeling, only the radial component of the metric is affected by the K factor; the tangential components are not. However, if we use the isotropic R coordinate, meaning that a 2-sphere gets labeled with a "radius" R that does *not* equal the square root of its physical area divided by 4 pi (in the case we're discussing, R will be smaller than that), then all three spatial components *are* affected by the K factor.
It's worth discussing this in a little more detail too. First of all, as I showed above, whether or not all spatial components are affected by the K factor is coordinate dependent, so your logic here is not correct as it stands since coordinate dependent quantities can't describe the actual physics. However, there is a legitimate physical question to be asked: what *is* the K factor, as I defined it physically (the "non-Euclideanness" of space, in terms of the volume between two adjacent 2-spheres compared to their areas), at the EH of a black hole?
The answer is that the question is not valid, because the physical definition of the K factor requires that the 2-spheres in question are spacelike surfaces. But the 2-sphere at the EH, where r = 2M in Schwarzschild coordinates, is not spacelike; it's null. So it is physically impossible to perform the comparison I described using a 2-sphere at the EH, and there is therefore no way to physically define the K factor (or the J factor, for that matter) at the EH.
  • #46
Prove it.
  • #47
On re-reading, I should re-state this. The 2-sphere at the EH can still be said to have a physical "area", which is 4M^2 in geometric units. So it may not be technically correct to say the 2-sphere itself is null. (When I compute the norms of the tangential unit vectors, I don't get zero at r = 2M; the norms are still positive, so the unit vectors are still spacelike, assuming I'm doing the computation right).
However, there can't be a static 2-sphere "hovering" at the EH, because the EH, as a surface in spacetime, is a null surface, and therefore there can't be a surface of "constant time" that is orthogonal to the EH, in which the 2-sphere could be said to lie, and in which the area of the 2-sphere could be compared with the volume between it and a neighboring 2-sphere. So the main point in what I said above still holds: it's impossible to do the physical measurement at the EH that I was using to define the K factor.
I should also note that the above does not entirely apply to the J factor; since there are still timelike worldlines passing through the EH, it is still possible to define a "gravitational redshift" factor there, for an infalling observer. However, this factor cannot apply to a static, "hovering" observer at the EH, since as we've seen there can't be one. So what I said does apply to the J factor for static observers.
  • #48
DaleSpam said:
Originally Posted by Q-reeus: "Please, concede on this one. The task of getting a consistent physics here is impossible."
Prove it.
Was meant as good advice, based on what I wrote in #40
"Oh, here's a possible fly in the ointment. Add the tiniest puff of fresh, pure mountain air inside the shell. Just a touch. Just enough to reverse the sign of shell hoop stresses and blow the amplitude up by, say, a mere factor of one million."
If you choose to reject the basic logic of that bit, then recall - you have committed to proving me wrong by calculations I consider doomed to failure - but go ahead and show that I'm the mistaken one.
  • #49
Took them to be identical in vacuum SM region, but upon looking back in your #9 I see that the defined relation is J = K-1 there. Had assumed the redshift factor J was in terms of frequency, since it declines with descent into lower potential. That is my expectation of how 'coordinate' measure of lengths will go, hence did mean J, but formally should have used K-1.
Originally Posted by Q-reeus: "we find that the physical size of a notional BH shrinks to zero before it in fact can qualify as BH"
Allright, probably should have just said the area of a collapsing 'almost, approaching notional 'BH'' body by this reckoning shrinks indefinitely since tangent metric components would actually shrink by the factor J = K-1, that relation holding everywhere, not just in vacuum. Hence area follows as K-2. By contrast with standard BH there is infinite redshift at EH but finite area. [I believe actual collapsing body would never shrink to a point, but stabilize by matter/radiation ejection and spin at a perfectly finite size where J > 0. Gravity as source term in T would imo have to figure in that.]
So what follows in your comments here are I think perfectly OK only if one already accepts spatial metric permitting finite EH area. Catch 22, seems to me. thanks for your clarification in #47, but same deal.
As in my first passage in #19, still see this thing of defining distance in terms of area as another Catch 22. How do you define area divorced from linear length measure? Those 'packing objects' are LxLxL entities, and one must have a clear definition of L, and same goes with the area thing - area A is an LxL object! If A is the primitive, how do you determine it apart from L measure! Could this be a conundrum forced by need to accommodate difficulties with the BH EH issue? Maybe not, but it's my hypothesis.
Much later. :zzz:
  • #50
I'm not sure I understand you here. Two comments:
(1) Did you read that previous post where I defined J and K carefully? You'll note that I specified there that the relation J = K-1 does *not* hold in the non-vacuum region. I was talking about the "shell" scenario there, but the same would apply for the interior of a collapsing body such as a star.
(2) The factor J does not apply to the tangential metric components; it applies to the time component, since it's the "redshift factor". So I'm not sure how you're concluding that the tangential metric components would "shrink" by the factor J.
This is not a contrast with a standard BH. A standard BH does have infinite redshift but finite area at the EH. (More precisely, it has "infinite redshift" for "static" observers at the EH--more precisely still, the limit of the redshift for static observers as r goes to 2M is infinity; there are no static observers exactly at the EH so there is no "redshift" for them at that exact point).
Perfect spherical non-rotating collapse is certainly an idealization. But there have been many numerical calculations done of non-idealized collapses, and they still show an EH forming and the body collapsing inside it.
The little identical objects used for packing have to have some linear dimension, yes. But that doesn't commit you to very much since it's for very small objects, so the effects of spacetime curvature can be ignored. As soon as you start trying to deal with size measures over a significant distance, where spacetime curvature comes into play, you have to be a lot more careful. The reason for using those little objects to define area first is that the spacetime has spherical symmetry, so the areas of 2-spheres centered on the origin can be defined without worrying about the curvature of the spacetime. That is not true for radial distance measures, as I have shown.
  • #51
"Allright, probably should have just said the area of a collapsing 'almost, approaching notional 'BH'' body by this reckoning shrinks indefinitely since tangent metric components would actually shrink by the factor J = K-1, that relation holding everywhere, not just in vacuum."
I understand your comments, but they are referencing to the standard GR view of things. I was addressing things assuming my notion of isometric metric applies, for which the product JK is invariant - same in exterior vacuum as shell wall matter region. Which gets back to finding a self-consistent answer to the shell metric transition problem. With no hope of a resolution via shell stresses, there is what to fall back on?
Originally Posted by Q-reeus: "By contrast with standard BH there is infinite redshift at EH but finite area."
Ha ha. Blame myself for not having added a comma after the word 'contrast'. Hope you get the unambiguous meaning now. So as per last passage, you are referring to standard picture, I was contrasting my idea of 'how it ought to be' with the standard, BH's are real, picture.
"As in my first passage in #19, still see this thing of defining distance in terms of area as another Catch 22. How do you define area divorced from linear length measure? Those 'packing objects' are LxLxL entities, and one must have a clear definition of L, and same goes with the area thing - area A is an LxL object! If A is the primitive, how do you determine it apart from L measure! ..."
Your efforts to educate me haven't been entirely wasted. Finally appreciate, I think, that this definition allows the only unambiguous locally observable measure of curvature effects - as you say, packing ratios vary with 'radius'. But the persistent opinion one cannot decently relate length measure 'down there' to 'out here' is not true if what I have just realized makes sense. Simply apply the well known radial vs tangent c values cr, ct, which in terms of J factor, are cr = J, ct = J1/2 (e.g. http://www.mathpages.com/rr/s6-01/6-01.htm Last page or so). These are naturally the coordinate values. Now as locally to first order in metric everything is observed isotropic, we must have that spatial metric components scale identically to their cr, ct counterparts according to cdt = dx. Settles the matter for me. So with I think a proper handle on how SM predicts metric scale in coordinate measure, will try to test their consistency.
Interestingly, while SC's were telling me tangent component was invariant, from this directionally dependent c perspective, there is in fact tangent shrinkage of a collapsing objects perimeter by factor J1/2. Still not isotropic, but not as 'bad' as I thought before.
  • #52
Have you checked to see that this notion of yours can even be satisfied at all consistent with the Einstein Field Equation? All the things DaleSpam and I have been saying about how the J and K factors change in the non-vacuum shell region are based on the EFE, relating the stress-energy tensor to the curvature. If you're going to just throw out notions without caring if they're consistent with the EFE, then there's no point in discussion, since you're not going to convince anyone else here that the EFE might not be valid under these conditions.
DaleSpam and I have both given self-consistent answers that resolve it via shell stresses. The fact that you don't accept them doesn't make them wrong.
We are not saying there is *no* way to relate local length measures to distant length measures. We are saying there is not a *unique* way to do it, so you have to specify how; and you can't just hand-wave it, you have to actually do some calculating to see how it works out. For example, if you want to do it based on what the distant observer actually sees, you have to work out the paths of light rays.
Only in Schwarzschild coordinates, as the page you link to makes clear. In other coordinates the c values work out differently. You can't make any valid claims about the actual physics using things that are only true in a specific coordinate system.
  • #53
No, because the shell problem was thrown up to indicate, imo, that EFE's, or at least the SM, has problems, so it seems kind of circular to then use EFE's as the yardstick. I threw the problem to the pros for consideration, and have appreciated some useful feedback, but see nothing to this point satisfactorally answering it.
You've thrown me there completely. I recall you suggesting there is room for one via stresses, but can't recollect any actual detailed argument. Could you point to where I may have missed it? As you know, DaleSpam says he will have such an answer, but that's still future. You are aware of my reasons for total scepticism on that. Perhaps you wouldn't mind telling me why the 'puff of air' bit I brought up with DaleSpam in #40 is wide of the mark. To me it seems devastating, but sure I may not understand something basic here.
Have been looking at some kind of thought experiments along those lines, but re below that is in limbo for the moment.
Thinking about that again, I was too hasty and will probably have to withdraw my claim - there is possible ambiguity about splitting the spatial and temporal contributions to cr, ct not fully thought through. I detect stormy weather here.
  • #54
Ok, that makes it clearer where you're coming from. If you doubt the EFE, then the whole discussion in this thread is pretty much useless, because everything everybody else has been saying assumes the EFE is valid.
The puff of air makes the interior region not vacuum; it has a non-zero stress-energy tensor. If the pressure of the air is enough to change the stresses in the shell, then its stress-energy tensor certainly can't be neglected; and a non-vacuum interior region changes the entire problem, because the spacetime in the interior region is no longer flat. Now you're talking about something more like a static model of a planet or a star, just with a weird density profile. (Though again, the density profile can't be that weird, because if the puff of air has enough pressure to significantly affect stresses in the shell, and the air is non-relativistic, then its pressure has to be much less than its energy density, so the energy density of the "air" would be pretty large.) We'll see more specifics when DaleSpam runs the numbers, but these considerations strongly suggest to me that what you have proposed does not have any significant bearing on the original shell problem, where the interior region is vacuum and spacetime there is flat.
  • #55
Seriously, you didn't get that till now? How about entry #1! Or my posts over there in the black hole thread which lead to this one. Now come on.
Last bit obviously true but at the same time everyone here has understood my sceptical stance. The challenge, and my opinions were clearly set out to all you GR buffs from the start. If you feel an explicit and definitive resolution has been given, I'd love a recap because must have missed it.
The puff of air makes the interior region not vacuum; it has a non-zero stress-energy tensor. If the pressure of the air is enough to change the stresses in the shell, then its stress-energy tensor certainly can't be neglected; and a non-vacuum interior region changes the entire problem, because the spacetime in the interior region is no longer flat. Now you're talking about something more like a static model of a planet or a star, just with a weird density profile. (Though again, the density profile can't be that weird, because if the puff of air has enough pressure to significantly affect stresses in the shell, and the air is non-relativistic, then its pressure has to be much less than its energy density, so the energy density of the "air" would be pretty large.) We'll see more specifics when DaleSpam runs the numbers, but these considerations strongly suggest to me that what you have proposed does not have any significant bearing on the original shell problem, where the interior region is vacuum and spacetime there is flat.)
It was evidently all about contrasting vanishingly small self-gravity contribution to shell stress, with what a tiny mass of air would greatly overwhelm - a mass in turn many orders of magnitude less than that of the 8 ton shell. True I didn't run specific figures because seemed quite evident there was no need given the scenario. One gets a pretty good feel for orders of magnitude with that kind of thing (but perfectly happy to put figures to it if challenged to do so). And that bit of air would matter one hoot re non-flat interior spacetime? But it's ok I think I get what's going on and why. Kind of sad but guess this is the end of your participation. So be it - but thanks anyway.
One last thing though. I think it important to know the nature of contribution to metric that in particular uniaxial stress (being the extreme of stress anisotropy), or biaxial if you like, in some element of stressed matter makes. For instance, element having uniaxial stress axis along polar axis - how different are the radial and tangent SC's generated compared to equivalent element of unstressed mass. Would be fascinating to know that, given it's ability to solve the shell issue. You may not wish to bother with a personal contribution, but pointing to a good resource explaining it in a way a layman can grasp would be appreciated. Cheers.
  • #56
But as we keep on saying, it's not the *mass* (or energy density) of the air or the shell that matters, but the spatial stress components, and you specified the scenario in such a way that those can't be negligible: you specifically said that the puff of air had enough pressure to significantly change the stress components inside the shell. That all by itself is enough to ensure that the stress-energy tensor of the puff of air is enough to make spacetime inside the shell non-flat, to the level of accuracy you are assuming. (Obviously the puff of air doesn't affect the flatness of spacetime in a way our normal senses or even fairly accurate instruments can perceive, but then again our normal senses and even fairly accurate instruments can't perceive the self-gravity of a steel ball either. So the whole scenario obviously assumes a much higher level of accuracy than we can currently achieve.)
If I can find a good resource on this specific topic I'll post it. You might try Greg Egan's science pages for some good notes that are at least somewhat related:
http://gregegan.customer.netspace.net.au/SCIENCE/Science.html#CONTENTS
Try in particular the pages on "Rotating Elastic Rings, Disks, and Hoops", since he specifically discusses stress-energy tensors there. All these examples are in flat spacetime, but they might still be at least somewhat relevant to your example.
  • #57
After digging around in Chapter 23 of MTW, which discusses stellar structure, I found enough info to write down a metric for a static, spherically symmetric object with uniform density. This is not quite the same as the "shell" scenario, but it's close, and may even be close enough to use. (The specific case of a uniform density star is in Box 23.2 of MTW; I'm taking the g_tt and g_rr metric coefficient expressions from equations (6) and (3), respectively, in that box.)
The metric inside the static spherical object is:
[tex]ds^{2} = - \left( \frac{3}{2} \sqrt{1 - \frac{2 M}{R}} - \frac{1}{2} \sqrt{1 - \frac{2 M r^{2}}{R^{3}}} \right)^{2} dt^{2} + \frac{1}{1 - \frac{2 m(r)}{r}} dr^{2} + r^{2} d\Omega^{2}[/tex]
Here R is the radius of the object (i.e., its surface radius, which is constant); r is the Schwarzschild r coordinate (i.e., a 2-sphere at r has physical area 4 pi r^2); M is the total mass of the object; and m(r) is the mass inside radial coordinate r. I have not written out the angular part of the metric in detail since it's the standard spherical form.
At the surface of the object, where r = R, the above expression is identical to the exterior Schwarzschild metric at r = R; so the above is completely consistent with the metric being Schwarzschild in the exterior vacuum region.
The key point, though, is that for r < R, the g_tt term continues to get more negative (note that M, the total mass, appears in g_tt, not m(r)), meaning the "potential" continues to decrease; while the g_rr term gets less positive, closer to 1, finally becoming equal to 1 at the center of the object, r = 0. (Strictly speaking, we have to take the limit as r -> 0 since 1/r appears in the expression; but for uniform density, m(r) goes like r^3, so the expression as a whole goes to zero like r^2.) Since this is the same sort of thing we expected to happen in the "shell" case, it looks to me like the above is basically a degenerate case of the "shell" scenario, where the flat "interior" vacuum region shrinks to zero size (the single point r = 0--note that the spatial metric at r = 0 is flat and the "distortion" is zero).
Note that arriving at this result, as the details in MTW show, requires taking the pressure inside the object into account as well as the density. Equation (7) in Box 23.2 gives the central pressure (at r = 0) as a function of the density:
[tex]p(0) = \rho \left( \frac{1 - \sqrt{1 - \frac{2M}{R}}}{3 \sqrt{1 - \frac{2M}{R}} - 1} \right)[/tex]
For the extreme non-relativistic case, M << R, this approximates to:
[tex]p(0) = \frac{1}{2} \rho \frac{M}{R}[/tex]
So the ratio of pressure to energy density is indeed similar to the ratio of mass to radius (in geometric units); but that's still enough to have an effect on the metric.
In view of the all this, it looks to me like the metric for the "shell" scenario with an interior vacuum region, in the non-vacuum region, ought to look similar to the above; the major changes would be that m(r) would go to zero at some r_i > 0 instead of at r = 0 (so g_rr = 1 at that radius), and that the potential would stop changing at r = r_i, so the g_tt expression might have to change some (maybe replace the r^2 with something that equals R^2 at r = R but goes to zero at r_i). The only thing I'm not sure of is how the different pressure profile required (which has been discussed before) would affect things.
Of course, for the "puff of air inside the shell" scenario, the metric would be very similar to the above; the only difference would be having two uniform-density regions with differing densities (steel, then air), but matching the pressure at the boundary between them. That would mean that g_rr would be very close to 1 at the boundary between steel and air, because m(r) would be close to zero there (most of the mass is in the steel, not the air). It would also mean, I think, that the r^2 in the expression for g_tt would need to be replaced by something that decreased faster in the steel region and slower in the air region, still going to zero at r = 0 (and of course still being equal to R^2 at r = R).
  • #58
Q-reeus: Can you try to succinctly state your issue(s) in the context of SC geometry fitted to interior Minkowsdie geometry, with no matter shell at all. Despite the disconinuty in metric derivatives (but continuity of metric itself) all physical observables even ai femtometer away from the 0 thickness shell are well defined. This situation is no different from the junction of ideal inclined plane with a plane. Continuity combined with discontinuity of derivative. Yet this is routinely considered a plausible idealization. So please phrase some specific objection you have to GR physics of the zero width shell.
  • #59
There's a section in MTW about "boundary" or "junction" conditions in MTW, which shows how to handle spherical shells.
In my copy it's pg 551,the section title is $21.13, look for "Junction conditions" in the index
MTW said:
The intrinsic and extrinsic curvatures of a hypersurface, which played such fundamental roles in the initial-value formalism, are also powerful tools in the analysis of "junction conditions."
Recall the junction conditions of electrodynamics: across any surface (e.g., a Junction conditions for capacitor plate), the tangential part of the electric field, En, and the normal part electrodynamics of the magnetic field, B±, must be continuous
Similar junction conditions, derivable in a similar manner, apply to the gravitational field (spacetime curvature), and to the stress-energy that generates it.
  • #60
Meaning that you cannot prove it.
By the way, the burden of proof is always on the person challenging mainstream established science. However, I will go ahead and calculate the metric for the sphere and the sphere with gas, mostly for my own practice since I don't believe that it will make a difference to you.
