Bathtub Water Drainage: Northern vs Southern Hemispheres
  • Context: High School
  • Thread starter Thread starter Himal kharel
    Water
The discussion revolves around the claim that water drains in different directions in bathtubs depending on whether they are located in the northern or southern hemisphere, attributed to the Coriolis effect. Participants explore the validity of this claim, its implications, and related anecdotes, with references to educational experiences and myths surrounding the topic.
  • Meta-discussion
  • Some participants assert that the idea of water draining in different directions based on hemisphere is a myth, citing sources like Snopes to support their claims.
  • Others reference historical experiments that suggest the Coriolis effect can influence water drainage under specific controlled conditions, though they emphasize that practical observations in everyday scenarios are negligible.
  • A participant humorously suggests that the Coriolis effect could be countered by training the direction of waste, highlighting the absurdity of the myth.
  • Several participants share personal anecdotes about being taught the Coriolis effect in school, questioning the accuracy of such education and the qualifications of teachers in science subjects.
  • There are humorous remarks about unrelated myths, such as the supposed influence of the Coriolis effect on the direction a cat wraps its tail, further illustrating the playful nature of the discussion.
Participants generally disagree on the validity of the Coriolis effect influencing water drainage in bathtubs, with some firmly rejecting the idea as a myth while others acknowledge the effect under specific conditions. The discussion remains unresolved regarding the educational implications and the persistence of the myth.
Participants note that the Coriolis effect is often overshadowed by larger forces in practical situations, and the conditions necessary to observe it are not typically met in everyday scenarios. There is also mention of the variability in teacher qualifications and subject assignments in education.
Himal kharel
Is it true that bathtubs in northern hemisphere the water drains out in clockwise rotation and those in southern hemisphere in anticlockwise direction?
If so then why?
And in equator?
False. A big honkin' stinky myth that just will not die.
Snopes has a good description of this silliness.
http://www.snopes.com/science/coriolis.asp
Frankly, I think even they are too generous. They talk about it as a "miniscule" force that is "easily overwhelmed" by larger forces.
Unfortunately, this getting-a-foot-in-the-door caution leads people to "...OK but a perfectly symmetrical bowl filled with reeeeeally still water would - in theory - still exhibit blah blah blah..."
Do this thought experiment.
Pick up a bucket of water. Hold it still.
Over the course of ten minutes, rotate it 2.5 degrees - a turn of about two centimeters.
That's less than 2cm over ten minutes. That's how much torque is applied to the water by the Earth turning. Now, the 10 seconds it takes for a toilet to drain is 1/60 of that - 300 micrometers - on the order of the width of a human hair.
Wikipedia details the lengths necessary to observe the Coriolis effect in draining water:
In 1908, the Austrian physicist Otto Tumlirz described careful and effective experiments which demonstrated the effect of the rotation of the Earth on the outflow of water through a central aperture.[28] The subject was later popularized in a famous article in the journal Nature, which described an experiment in which all other forces to the system were removed by filling a 6-foot (1.8 m) tank with 300 US gallons (1,100 l) of water and allowing it to settle for 24 hours (to allow any movement due to filling the tank to die away), in a room where the temperature had stabilized. The drain plug was then very slowly removed, and tiny pieces of floating wood were used to observe rotation. During the first 12 to 15 minutes, no rotation was observed. Then, a vortex appeared and consistently began to rotate in a counter-clockwise direction (the experiment was performed in Boston, Massachusetts, in the Northern hemisphere). This was repeated and the results averaged to make sure the effect was real. The report noted that the vortex rotated, "about 30,000 times faster than the effective rotation of the Earth in 42° North (the experiment's location)". This shows that the small initial rotation due to the Earth is amplified by gravitational draining and conservation of angular momentum to become a rapid vortex and may be observed under carefully controlled laboratory conditions.
http://en.wikipedia.org/wiki/Coriolis_effect#Draining_in_bathtubs_and_toilets
If I ever had a toilet that took more than 15 minutes to flush, I would have to install at least 2 more bathrooms in my house. In any practical situation, the hemispheric influence is unmeasurable.
You could also counteract any such Coriolis effect by training your turds to curl in the opposite direction and thus redirect the fluid flow.
Himal kharel said:
And in equator?
At the equator, the water just hovers over the drain because it can't make up its mind.
Danger said:
...training your turds to curl in the opposite direction...
And I now have my weekend project!:-p
Keep it fair too, Dude. You're not allowed to swallow a Bratwurst whole.
My Earth science teacher in high school specifically taught us that the toilet water spins due to the coriolis effect. When they teach it in school, I'm not surprised the myth keeps going.
Yeah... I couldn't figure out why my Grade 12 chemistry teacher was such an idiot until about 10 years later when I found out that once you have your degree in Education they assign you to what you will teach, whether or not you know anything about it.
Most states (in the United States, specific requirements for teaching are set by the state and so vary from state to state), a secondary school teacher must have an undergraduate degree in the subject, with a minor in education. Of course, once they are teaching, they may be assigned by the principal to teacher a course in different area. Too much of that can cause trouble with the school's accreditation.
In the elementary grades, teacher's typically have degrees in education.
Never mind that vortex. The best myth I heard in that area was that this same force determines... the direction your cat wraps its tail around when sitting! I always knew cats are neat and picky but THAT picky? Hmm.
That is true, and very irritating. Normal cats are ambidextrous, so they don't care. Mine is dyslexic, so she just stands there whipping it around until she get too tired and falls over.
