Nested Classes in C++: Protected Access Error
  • Context: C/C++
  • Thread starter Thread starter dodo
    C++ Classes
The discussion revolves around issues related to accessing protected members of nested classes in C++. Participants are exploring the specific error encountered when implementing a function within a nested structure, particularly in the context of using Microsoft Visual C++ 6.0.
  • One participant describes a scenario where a nested structure (PartTwo) cannot access another nested structure (PartOne) due to access restrictions, despite attempts to declare it as a friend.
  • Another participant suggests that the issue may be related to known problems with the Microsoft compiler, recommending an upgrade or a switch to GCC.
  • A later reply confirms that the same access error occurs in a provided example code, reinforcing the idea that the compiler may be at fault.
  • Some participants express frustration with the limitations of the Microsoft compiler, suggesting it is not ideal for such tasks.
  • One participant indicates that they are constrained to use the VC++ 6.0 compiler due to corporate decisions, despite recognizing its flaws.
Participants generally agree that the issue is likely related to the Microsoft compiler's handling of nested classes, but there is no consensus on a definitive solution, as some suggest workarounds while others express frustration with the compiler itself.
Limitations include the specific behavior of the Microsoft VC++ 6.0 compiler, which may not align with standard C++ behavior regarding access to protected members in nested classes.
dodo
Hopefully this sort of questions will soon be answered in the tutorial (good effort, Dduardo!), but for the time being, this one is not.
I have the following scheme:
class Foo {
protected:
struct PartOne {
struct PartTwo {
PartOne* someFunction ();
And I get a complaint of PartTwo's being unable to access a protected symbol (PartOne) from Foo.
A "friend struct PartTwo;" right after the "protected:" indication doesn't seem to solve the problem, as I expected. (I'd prefer not to take the two Parts out of Foo, as independent structures.) Where am I thinking wrong?
Thanks very much in advance.
Edit: If this helps... actually I'm not getting the error in the declaration (like the above), but when later writing the implementation of 'someFunction', which spells like:
Foo::PartOne* Foo::PartTwo::someFunction () &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;// <--- offending line
The MS VC++ 6.0 compiler says,
'PartOne' : cannot access protected struct declared in class 'Foo'
Technology news on Phys.org
You might be running into the infamous nested problems with the Microsoft compiler. You'll need to either upgrade to version VC++ 7.0 or use GCC.
Here is some example code that works under GCC:
Code:
#include <iostream>
using namespace std;
class foo {
protected:
        struct foo1 {
                int x;
        struct foo2 {
                foo1 myfunction(void) ;
public:
        void myfunction2(void) ;
void foo::myfunction2(void) {
foo2 test ;
test.myfunction();
foo::foo1 foo::foo2::myfunction(void) {
cout << "hello\n";
int main (void) {
foo testme;
testme.myfunction2();
I should've suspected when the compiler issued the error message TWICE for the same line. :)
Thank you; I'll try to workaround it.
Edit:
Confirmed - I get the same error (thrice :)
error C2248: 'foo1' : cannot access protected struct declared in class 'foo'
on line 27 of your program,
Thanks for crosschecking.
Microsoft makes great mice and keyboards, but stay away from their compiler like the plague.
Is there some reason you have to use the VC++ 6.0 compiler? It pains me to see someone work around a compiler flaw; particularly for such a horrible compiler.
It's the one at hand, and my workplace's choice. Nothing I can't do. (Corporate decisions here.) Thanks for caring.
Edit: typo.
16K
21K
10K
9K
