| New Reply |
Tricky complex square matrix problem |
Share Thread | Thread Tools |
| Oct26-11, 06:46 AM | #1 |
I have a complex square matrix, [itex]\textbf{C}[/itex], which satisfies:
[itex]\textbf{C}\textbf{C} = (\textbf{I} \odot \textbf{C})[/itex] where [itex]\textbf{I}[/itex] is the identity matrix and [itex]\odot[/itex] denotes the Hadamard (element-by-element) product. In other words, [itex]\textbf{C}\textbf{C}[/itex] is a diagonal matrix whose diagonal entries are the same as the diagonal entries of [itex]\textbf{C}[/itex], which is not necessarily diagonal itself. Furthermore, [itex]\textbf{C}[/itex] is Hermitian: [itex]\textbf{C}^{H}=\textbf{C}[/itex] and [itex]\textbf{C}[/itex] must be full rank (because actually, in my problem, [itex]\textbf{C} \triangleq (\textbf{A}^{H}\textbf{A})^{-1}[/itex], where [itex]\textbf{A}[/itex] is complex square invertible). I want to determine whether [itex]\textbf{C} = \textbf{I}[/itex] is the only solution (because this would imply that [itex]\textbf{A}[/itex] is unitary). (This is equivalent to proving that [itex]\textbf{C}[/itex] is diagonal). By expanding out terms, I've shown that [itex]\textbf{C} = \textbf{I}[/itex] is the only invertible solution for [itex](3 \times 3)[/itex] matrices, but I can't seem to obtain a general proof. Any help or insight would be very much appreciated - I'm completely stumped! |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Oct27-11, 08:42 AM | #2 |
you can take the square root of your equation
since C is positive definite ([itex]C=(A^\dagger A)^{-1}[/itex]) on the left you have C and you obtain (in components): [tex]C_{ij}=\sqrt{C_{ij}}\delta_{ij}[/tex] from which you can conclude that C is the identity matrix |
| Oct27-11, 01:22 PM | #3 |
| Oct27-11, 07:42 PM | #4 |
Recognitions:
You can show this from "first principles". Let the matrix be
[tex]\left(\begin{array}{cc} a & b \\ b* & c \end{array}\right)[/tex] where a and c are real. Mlutiplying the matrices out gives 3 equations a^2 + bb* = a c^2 + bb" = c ab + bc = 0 Subtracting the first two equations, either a = c, or a+c = 1 From the third equation, either b = 0, or a+c = 0 So either b = 0, or a = c = 0 But from the first two equations, if a = c = 0 then b = 0 also. So, the first two equations reduce to a^2 = a and c^2 = c, and the only solution which gives a matrix of full rank is C = I. |
| Oct28-11, 02:40 AM | #5 |
Thanks AlephZero. That is the approach I took in order to obtain a proof for [itex](2 \times 2)[/itex] and [itex](3 \times 3)[/itex] matrices. (If I understand correctly, your [itex]a[/itex], [itex]b[/itex] and [itex]c[/itex] are scalars.) However, aesir's solution is valid for the general [itex](n \times n)[/itex] case, which is especially important for me.
A final question on positive definiteness: If [itex]\textbf{A}[/itex] is not square, but instead is tall (with linearly independent columns) then is it correct to say that [itex](\textbf{A}^{H}\textbf{A})^{-1}[/itex] is now positive semi-definite? My reasoning is that [itex]\textbf{z}^H\textbf{A}^H\textbf{A}\textbf{z} = \left\Vert{\textbf{Az}}\right\Vert^2 \geq 0[/itex] for any [itex]\textbf{z}[/itex] (with equality when [itex]\textbf{z}[/itex] lies in the null space of [itex]\textbf{A}[/itex]). (Therefore aesir's square root still exists in this case). |
| Oct28-11, 03:20 AM | #6 |
It is true that if [itex]\textbf{z}[/itex] is in the null space of [itex]\textbf{A}[/itex] then [itex]\textbf{z}^H\textbf{A}^H\textbf{A}\textbf{z} = \left\Vert{\textbf{Az}}\right\Vert^2 = 0[/itex], but this means that [itex](\textbf{A}^{H}\textbf{A})[/itex] is semi-positive definite, not its inverse (which does not exists if the null space is non-trivial). BTW if [itex]\textbf{A}[/itex] has linearly independent columns its null space is [itex]\{0\}[/itex] |
| Oct28-11, 05:08 AM | #7 |
So are the following two statements correct? (1) [itex] (\textbf{A}^H\textbf{A}) [/itex] is positive definite when the columns of [itex]\textbf{A}[/itex] are independent (which requires that [itex]\textbf{A}[/itex] is tall or square). Therefore [itex] (\textbf{A}^H\textbf{A})^{-1} [/itex] is also positive definite. (2) When the rank of [itex]\textbf{A}[/itex] is less than its number of columns (which includes all fat matrices), [itex](\textbf{A}^H\textbf{A})[/itex] is positive semidefinite. In this case, [itex](\textbf{A}^H\textbf{A})^{-1}[/itex] does not exist. |
| Oct28-11, 07:10 AM | #8 |
In case (2) you can say a little more. If you split the vector space in null{A} and its orthogonal complement [itex]V_1[/itex] you have [tex]A^H A = \left(\begin{array}{cc} B^HB & 0 \\ 0 & 0 \end{array} \right)[/tex] that has a positive definite inverse if restricted from [itex]V_1[/itex] to [itex]V_1[/itex] |
| New Reply |
| Tags |
| complex matrix, hermitian matrix, involutory matrix, matrix inverse, unitary matrix |
| Thread Tools | |
Similar Threads for: Tricky complex square matrix problem
| Thread | Forum | Replies | ||
| building a least square problem design matrix | Calculus & Beyond Homework | 4 | ||
| Complex analysis, deceptively tricky problem. | Calculus & Beyond Homework | 1 | ||
| Least square problem matrix | Calculus & Beyond Homework | 3 | ||
| Obtaining an invertible square matrix from a non-square matrix of full rank | Linear & Abstract Algebra | 0 | ||
| Tricky complex numbers problem | Precalculus Mathematics Homework | 5 | ||
