Need help with a 12 watt Audio amplifier
The forum discussion centers on troubleshooting a 12 watt audio amplifier designed by G. Randy Sloan. Key issues include improper output from the amplifier, potential miswiring of the power supply, and the need for decoupling capacitors to stabilize the circuit. Participants recommend checking the voltage across the output transistors, ensuring correct transistor placement, and implementing decoupling to mitigate feedback effects. The successful resolution involved using a 4700uF capacitor to improve performance.
  • Understanding of basic electronics principles
  • Familiarity with transistor types, specifically PNP and NPN
  • Knowledge of power supply design, particularly full-wave rectification
  • Experience with multimeters for voltage and resistance measurements
  • Research "decoupling capacitors in amplifier circuits"
  • Learn about "full-wave center tap rectifier configurations"
  • Explore "testing techniques for audio amplifiers using multimeters"
  • Investigate "common issues in audio amplifier design and troubleshooting"
Electronics enthusiasts, audio engineers, and hobbyists building or troubleshooting audio amplifiers, particularly those using designs based on G. Randy Sloan's specifications.
LokiMundane
I have recently built a 12 watt amplifier spec'd by G. Randy Sloan.
The problem I am having is many fold.
1.) I am not an EE and learning as I am going
2.) The amp WILL carry a signal but so far I have only been able to use it as a passive circuit.
3.)The output leads don't provide an output but if I banana clip my speaker leads to the transistor heat sinks then it carries a signal??
4.) The power supply I have built for it may be built incorrectly. It is a 24 volt 2 amp transformer going to a 2 amp bridge rectifier which then goes to a 1000uF electrolytic capacitor. It is meant to be a mono power supply applying approx 38 volts to the amp.
The transformer has two leands on one side which is going to the ac outlet and three on the other, The far left and far right are then attached directly to the ac leads on the recifier. What do I do with the center tap? Is this a ground?
4.) I am not 100% sure how to test the amplifier circuit but I have checked all the resistances with an ohm meter and it seems to work out.
Below are two pics, on rather crappy one of the schematic and one of the actual amp.
Thank you in advance for any help
http://i155.photobucket.com/albums/s304/loki_mundane/12wattampschematics.jpg
It could be a nightmare troubleshooting this over the forums, so many things could go wrong. You would have to systematically check every part of the circuit to be sure, but maybe we can narrow the search down.
I'd suggest checking the voltage across the base-emitter of the two output transistors, just to see if there is a 0.7 voltage drop or not. It's also possible the leads on the transistors are mixed up.
It's hard to tell from the schematics, there looks to be a PNP and NPN for the output transistors
The transformer is fine. The center tap is used with a full-wave center tap rectifier. With your voltmeter, make sure the positive dc voltage goes to the top of your schematic, and the negative to the bottom. Your schematic is too small to read and analyze, but I see 4 PNP's and 3 NPN's. Make sure you have the base, emitter, and collector properly selected on all 7 transistors.
I'd have to agree with what on this one.
There shouldn't be any audio on the heatsinks because there should be insulating washers between the transistor bodies and the heatsinks. They might be little rectangles of mica or some other insulator.
If you have a multimeter, make a chart of voltages (relative to the negative rail), redo the picture of the schematic so it can be read and put the list and the new photo on this Forum.
That schematic is pretty bad. Get some more light on it and focus it and hold the camera steady on a tripod. And don't shrink it so much.
Measure the resistance from the junction of the two output transistors (on the heatsinks) to the large capacitor that leads to the speaker and then from the capacitor to the speaker. There seems to be a fault just there, somewhere.
Check that you have the right transistors in the right positions on the board, particularly the transistors on the heatsinks.
I am sorry to bring such an old tread back from the dead. I am building the same amp and also having trouble. I have a schematic but can't post it now, as I am writting this on a tablet. I have finished this amp, and the only output I get from the 4 ohm speaker is a constant clipping with no music. When there is no source pluged in it sounds lime static with a pulsing noise in the background. I have swaped out all the transistors for new ones, in case there was a bad part, with no results. I am using the exact same power supply as the op. This amp is based off a tip32c and tip31c power transistor. The rest of the transistors are small signal amplifers for the first stages. Any advice would be greatly appreciated.
mike_drz said:
I am sorry to bring such an old tread back from the dead. I am building the same amp and also having trouble. I have a schematic but can't post it now...
Well, the unreadable schematic attached to this thread is useless, so, without seeing your circuit, we can't tell you much of anything. Is the schematic you're using available online anywhere?
Here is the schematic scanned out of the same book that the first picture was taken of. It's a simple circuit, well it is supposed to be... haha. However it has been a while since my electronics engineering courses. I have found that a few of the resistors I am using have a loose tolerance (ie. 22k, is 21). I'm not sure how tight these need to be.
The obvious thing missing from that circuit is decoupling. This would be why you are getting that pulsing effect. It is sometimes called "motor-boating".
If you feel experimental, you could open the wire between the tops of R5 and R8 and put in a 470 ohm resistor between them. Then put a 22 uF capacitor between the top of R5 and ground.
I'm just guessing the values, so be prepared to alter them. If it improves, but doesn't fix the effect, make the capacitor bigger.
I suppose the original was meant to be used with a VERY low impedance power supply, not something knocked together from a full wave bridge rectifier and a 1000uF smoothing capacitor. If your reference has a section on power supplies, try doing what it says. Otherwise, try what vk6ro said.
Or your could find an amp design by somebody who doesn't have such strong opinions on why everybody else is doing it wrong...
http://www.zusaudio.com/technology/randyslone.htm
http://www.zusaudio.com/technology/zusaudioengine.htm
Hello folks, sorry that I haven't updated anybody on the situation. I had a little bit of a melt down when I shorted out the circuit while testing voltages. I have had to start from scratch and test all my components to see which ones survived. I am working with several forums, most posters have mentioned the "decoupling" situation. However somebody with access to good software was able to build and simulate this circuit exactly as it is in the schematic; and it worked. It is an unorthodox design from what I've gathered. The book calls for a raw 24VAC 2A power supply with a 1000uF @ 50V cap for smoothing. However I have a 4700uF @ 50V cap and will try that after I'm done picking up all the pieces.
Decoupling is like this:
[PLAIN]http://dl.dropbox.com/u/4222062/amplifier.PNG
I enclosed the proposed components in a red box.
The idea is that with an unregulated supply, there will be some variation in supply voltage due to the supply, the fuse and the assorted supply wires.
Without decoupling, the variation can be applied to the sensitive preamp stages and produce feedback effects.
Because the preamp draws relatively little current, it is easy to filter out this variation in the preamp's supply line rather than try to filter it out for the whole amplifier.
Success! I have finally been able to get this working. I used the 4700uF cap directly on the breadboard, and cleaned up the circuit after testing all the components. This amp doesn't sound all that great for all the trouble it's caused me, but I am happy to say it works haha.
Now I have some MJ15003 and MJ15004 power transistors waiting for my next project :biggrin: However I don't feel like frying those, so I'll save that for another day.
I've attached a picture of the circuit below, I'm aware that I'll have to put the heat sinks onto the power transistors; but just lost my patience. Also the diodes should be attached to the power transistors for thermal stability, according to the book.
Thank you for everybody's help and suggestions. @vk6kro thanks for the mod, I will try that tomorrow and see how it sounds, for now I think I'm putting this one to rest though. haha
mike_drz said:
... Now I have some MJ15003 and MJ15004 power transistors waiting for my next project :biggrin: However I don't feel like frying those, so I'll save that for another day. ...
You can save yourself a lot of headaches (and destroyed components) by investing in a bench-top power supply. There are also a bunch of online instructions for building one from an old computer power supply. http://hackaday.com/?s=adjustable+power+supply
I've got a good power supply, with current limiting but it only goes to 30 v @ 3 amps. I am building one that will goto 50 v and will be adjustable, and is a dual voltage supply.
