Formula of doppler effect for sound,relativistic?
The discussion revolves around the Doppler effect for sound, particularly in the context of relativistic effects and the implications of special relativity on the formulas used. Participants explore the differences between classical and relativistic treatments of the Doppler effect, the definitions of relative velocities, and the conditions under which various formulas apply.
  • One participant presents the classical Doppler effect formula and questions how relativity might modify it, particularly regarding the observer's and source's motion.
  • Another participant introduces a relativistic formula for the Doppler effect, emphasizing the role of the Lorentz factor.
  • Some participants argue that sound propagates in a medium, suggesting that special relativity does not apply to sound waves in the same way it does to light waves.
  • There is a discussion about the definition of "v" in the context of the formulas, with some suggesting it should be expressed as a ratio to the speed of light (β).
  • Participants debate the concept of relative velocity, with differing views on whether velocities can be considered absolute or relative in the context of flat spacetime.
  • One participant emphasizes that the Doppler effect should be treated classically, while others suggest that relativistic effects must be considered, especially in the context of time dilation and signal delays.
Participants express differing views on the applicability of relativistic formulas to sound and the nature of relative versus absolute velocities. There is no consensus on how to reconcile classical and relativistic perspectives on the Doppler effect.
Discussions include unresolved definitions and assumptions regarding the nature of velocities and the conditions under which the Doppler effect formulas apply. The conversation reflects varying interpretations of the relationship between classical mechanics and special relativity.
ShayanJ
Insights Author
As you know,the formula for doppler effect is:
[itex]f^{'}=\frac{v-v_{o}}{v-v_{s}}f[/itex]
relativity suggests(at least I think) that [itex]f^{'}[/itex] for [itex]v_{o}=u[/itex] and [itex]v_{s}=0[/itex] should be the same with [itex]f^{'}[/itex] for [itex]v_{o}=0[/itex] and [itex]v_{s}=-u[/itex],otherwise,there will be a way for the listener to know that which one,sound source or listener,is moving with constant velocity.
So does relativity suggest a correction or simply I am wrong?
thanks
The complete formula is:
[tex]\Large {\frac {\sqrt {1-{v}^{2}}}{1+v\cos \left( \theta \right) }}[/tex]
which simplifies when theta is 0 to:
[tex]\Large {\frac {\sqrt {1-{v}^{2}}}{1+v}}[/tex]
Note that the Lorentz factor is:
[tex]\Large \gamma={\frac {1}{\sqrt {1-{v}^{2}}}}[/tex]
Sound propagates in a medium, and the usual Doppler formula holds only in the rest system of the medium, so SR does not apply.
Good point clem,I should have thought about that.thanks.
But what are the formulas in flower's post?
The "v" that he is using is what is normally called β, the ratio of the relative velocity between the two observers divided by the speed of light.
The more common formula for when theta=0 is:
√[(1-β)/(1+β)]
But with a little algebra, you can transform the one into the other.
These formulas apply when the two observers are moving away from each other, their reciprocal works when the two observers are moving toward each other. You also have to keep in mind that these formulas only apply when the two observers have been in their constant relative motion for a long enough time that the signals have stabilized. Or another way to say that is the formulas tell you the Doppler at an earlier point in time, whatever the signal delay is between the two observers, and, of course, that delay is frame dependent and so in the rest frame of each observer it will be different.
But it is this delay that makes Relativistic Doppler an easy illustration of what each observer sees in the Twin Paradox. While they are moving away, they each see the same Doppler, that is they each see the other one's clock running slower than their own. When the traveling twin turns around, he immediately sees the Doppler of the stationary twin go up (it becomes the reciprocal) and so now he sees his twin's clock running faster than his own. Meanwhile, the stationary twin continues to see the traveling twin's clock still going slower than his own. Eventually, the stationary twin will see the Doppler from the traveling twin's clock go up (it becomes the same reciprocal value) and then they reunite. If they both keep track of the cycles of the waveforms they see from the other twin, they can determine the relative age difference between them when they reunite. The traveling twin sees his brother's clock running at the two rates for exactly half the trip while the stationary twin sees his brother's clock run at a slow rate for most of the trip and then the high rate for only the tail end of the trip.
If you mean by the 'ratio between the relative velocity' simply the velocity between two observers then I agree. Otherwise we should discuss.
OK, let's discuss.
ghwellsjr said:
OK, let's discuss.
OK what is the ratio between the relative velocity between two observers if not the velocity between two observers?
Maybe my grammar wasn't exactly correct but what I mean is it's the relative velocity (in whatever units you want to use) between the two observers divided by the speed of light, c, (in the same units). Your "v" cannot be a velocity in the normal sense of the word because it is not a unitless value until you divide it by c. The normal nomenclature when doing this is to use β to refer to the ratio of a velocity and the speed of light.
Does that clear it up?
The ratio of which velocities? You still have not explained by what you mean by the ratio of a velocity.
How is a velocity between A and B relative?
There is only one velocity between A and B it is neither a ratio nor is it relative.
Beta is the ratio of the one velocity you are talking about and the velocity of light, c.
I'm only pointing out that the "v" in your formula needs to be divided by c in order to make it possible to do the computation.
Is there any difference between saying "the velocity between A and B" and saying "the velocity of A relative to B" or "the velocity of B relative to A"? Or is your point that since these two velocities are equal, you can rephrase it and use the word "between" instead of "relative"? You certainly aren't meaning to say that a velocity is absolute, are you?
The velocity between two observers in flat spacetime is certainly absolute.
Are you saying it is not?
A relative velocity between two observers does not make any sense to me as there is nothing relative here.
It's fairly standard terminology to say "the relative velocity between A and B" to mean to "the velocity of A relative to B" (in other words, "the velocity of A measured by B"), which is the same as "the velocity of B relative to A" (referring to inertial frames in SR, at least).
All velocities are relative in the sense that it only makes sense to talk "the velocity of A relative to B"; "the velocity of A" is meaningless (unless the "...relative to B" is obvious by context).
Is the angle, theta, also absolute?
No it is not.
Is it relative?
You guys are talking about two different things.
Yes PassionFlower,the velocity between two observers is absolute but ghwellsjr is saying that each individual veclocity depends on the frame of reference you choose which is indeed correct.
Now I understand that to use the formulas given by PassionFlower,we need to determine the velocity between the two (the procedure differs in different frames)and of course divide it by c.Or simply take the frame of fluid the frame of reference and use the classic formula.
And one more point ghwellsjr,you talked about time dilation.The doppler effect is not about the frequency differences because of the different time speeds in different frames.Its sth classical which needs just a little bit modernization.The effect you talked about,is sth that should be calculated in a different context.
No, I'm not saying that the velocity between two observers in relative motion is frame dependent, because it's not. An observer does not need to estabish or know anything about a frame in order to measure the velocity of another observer or object that is moving in line with himself. In fact, he can use Relativistic Doppler to measure that velocity.
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 17 ·
