What Went Wrong with My Photoelectric Homework?
The discussion revolves around a problem related to the photoelectric effect, specifically identifying the work function of an unknown emitter electrode based on experimental data involving varying light wavelengths and corresponding minimum voltages required to stop the cathode ray from generating current.
  • The original poster attempts to derive the work function using the relationship between light wavelength, voltage, and energy, but expresses confusion over the results obtained from their calculations. Some participants question the accuracy of the original poster's method and results, while others suggest checking the input values used in calculations.
Participants are actively engaging in clarifying the original poster's approach and discussing potential issues with the calculations. Some guidance has been offered regarding the correct input of wavelength values in the calculations, indicating a productive direction in the discussion.
There is a mention of the need to convert wavelengths from nanometers to meters for calculations, which may impact the results. The original poster also notes that they are only solving for the work function and not the subsequent identification of the material composition.
dontpunchme
So, I got the following question.
http://imageshack.us/photo/my-images/528/problemsl.jpg
This is figure 13.1.
http://imageshack.us/photo/my-images/100/131lg.jpg
C is the cathode material. S is the light. The voltage begins at A. The circuit carrying any current that makes it through the potential difference is everything else to the right.
So I think, okay, to identify the cathode material I need the work function value. Not too hard.
http://imageshack.us/photo/my-images/710/excelx.jpg
Note the formula I used for row 3.
http://imageshack.us/photo/my-images/4/attemptsolution.jpg
What did I do wrong? Why am I... what? These answers don't make any sense to me.
Thanks!
edit
Since the images aren't appearing, I just linked to them. Imageshack.
Would you please type in the problem and your attempt of solution?
ehild
Alright.
First off, apologies to the boards. I didn't look for the "homework" subforum hard enough. (Being moved on my first post is embarrassing. :shy:)
So, here's my question, typed out.
I have an emitter electrode of unknown composition. There is a source of controllable light to the side, pointed right at the electrode. The cathode ray created by the electrode will have to travel through a potential difference between metal plates before reaching the anode where it is converted into a current.
My goal is to identify the emitter electrode composition. To determine this, I am given the following information.
I can vary the wavelength of the light created by the light source. I can also measure the minimum voltage (potential difference) required to stop the cathode ray from becoming a current completely.
If the following are the results of said experiment:
Code:
wavelength (nm)		250	300	350	400	450	500
minimum voltage (V)	2.70	1.90	1.30	0.80	0.50	0.10
This is my attempt at solving it.
(1/2)mv^2]max=eV'=(Planck's constant)(c/wavelength)-(work function)
Where V' is the minimum voltage.
So eV'+(work function)=(Planck's constant)(c/wavelength).
The only property here that is of the electrode is the work function, so...
(work function)=(Planck's constant)(c/wavelength)-(eV')
Now, since everything here has is measured in units of electron volts, I figure I might as well cancel all the e's from both sides.
(work function/e)=((Planck's constant)(c/wavelength)/e)-V'
Which makes things a bit simpler for the numbers. But it doesn't matter.
So I stuck this in Excel, hoping to come out with a single work function. But instead, my results were pretty much repeats of the minimum potential difference.
To which I said, "This can't be right."
(I'm only solving up to the work function in my answers, because finding the material composition from the work function is fairly trivial for this problem.)
Thanks in advance for the help!
(I need to learn LaTeX at some point.)
Your method is all right, and I do not know what your problem can be without seeing the results you got for the work function. I got values scattering between 2.2 and 2.4 eV, 2.29 in average. Have you got a table of work function values of different solids? This is rather a low value, but there are metals with work function close to that.
ehild
ehild
This is my input into Excel. (For the work function row.)
Code:
=((4.135667516*10^-15)*(299792458/A1))-A2
This is my result.
Code:
2.7		1.9		1.3		0.8		0.5		0.1
-2.699999995	-1.899999996	-1.299999996	-0.799999997	-0.499999997	-0.099999998
Take care, the wavelengths are given in nanometers. So you need to have 250E-9,... and so on for A1.
ehild
Oh. Okay.
Thanks.
  • · Replies 19 ·
  • · Replies 63 ·
  • · Replies 34 ·
  • · Replies 30 ·
