What is the history of L1 and L2 cache in microprocessors?
  • Thread starter Thread starter otomanb
    L2
The discussion revolves around the history and evolution of L1 and L2 cache in microprocessors, examining whether L2 cache is internal to the processor or external, and how this has changed over time. Participants explore various architectures and historical contexts, including the transition from external to internal caches in modern processors.
  • Some participants assert that L1 cache is internal while L2 cache is often external, referencing various sources.
  • Others argue that modern processors, such as Intel Core 2 Duo and Core i7, have L2 cache integrated on the chip, challenging the notion of L2 being external.
  • A participant mentions that Intel and AMD phased out external L2 caches over a decade ago, suggesting a shift in design philosophy.
  • Another participant recalls that early processors like the 386 had only external caches, while the 486 introduced internal caches, leading to a decline in external L2 caches.
  • Some contributions discuss the technical reasons for having multiple cache levels, emphasizing the trade-offs between speed, size, and cost of cache memory.
  • There are mentions of specific historical models and their cache configurations, with some participants recalling personal experiences with older systems.
Participants express differing views on the historical context and current configurations of L2 cache, indicating that there is no consensus on whether L2 cache is primarily internal or external across all processors. The discussion remains unresolved with multiple competing perspectives.
Some claims rely on historical context and may depend on specific processor models, leading to potential misunderstandings about the evolution of cache memory. The discussion highlights the complexity of cache architecture and its implications for performance.
otomanb
Hello!
According to many sites L1 is internal cache
and Level 2 cache, cache memory that is external to the microprocessor.
but according to this intel core2duo box (photo) , intel is selling this L2 cache on processor not on another chip.
http://i40.tinypic.com/i4fu4n.jpg
why is this so ?
Computer science news on Phys.org
Can you give the links? I thought L1-L3 were always on the chip. It's just faster than having to look up a basic instruction from the RAM every time you need it.
There is nothing saying that the L2 cache needs to be on another chip, or if it is on the same chip, that it needs to be distinctly separate from the core processor. Putting cache of any type on a chip other than the CPUs would drastically reduce the advantage of having a cache. The primary reason cache exists is because main memory access is so very slow compared to the rate at which the CPU operates. If memory access was just as fast as the CPU itself there would be little need for cache at all. (If main memory was just as fast as the CPU, it might still be handy to have separate data and memory caches so that the machine could be Harvard architecture at its core (faster) but Von Neumann architecture to the outside world (simpler).)
Specialized memory can be made that has very high clock rates. This specialized memory is necessarily small, and increasing the size decreases the operating speed. Hence multiple levels of cache. Primary cache, or L1 cache, is very small but very fast. Because L1 cache is so small, it is helpful to have an intermediate cache(s) to bridge the gap between main memory and the CPU. L2 cache is significantly larger than but is also slower than the primary L1 cache. Because the gap between main memory and CPU operating speeds has widened, some newer machines even have a tertiary cache on the same chip as the CPUs.
It's my understanding that L2 caches were often external when they first came out but have since been added to the same die on newer processors. On most multicore systems, theyre actually part of the core, and L3 cache is shared between cores. I think I had a pentium system that had an external L2 cache chip that looked similar to SDRAM in a DIMM package, but I can't find any documentation and it's late.
Thats correct, L2 cache tended to be external on early CPU models, specifically some Intel models. Additionally some L2 cache used to actually sit in RAM direct onto the MOBO.
I designed a memory controller before. Let me try to explain. Processors or micro controllers run at a much higher clock rate than its peripherals. Accessing instructions or data outside the processor reduces the overall performance because the processor has to stop and wait for its peripherals to respond. A built-in cache inside a processor is a trade off between the cost of a large high speed RAM inside the processor and the hit rate of the instruction/data requests. The higher the hit rate, the better the overall performance, i.e., CPU doesn't need to stop and wait for stuff from the outside. More layers of the cache increases the hit rate, but also increases the cost, because internal high speed RAM, such as SRAM, is more expensive than external slow pace RAM, such as SDRAM. An L2 cache outside of the processor is cheaper than a built-in one. Whether a built-in one is needed depends on your application.
External caches were a hit around the 386/486 times, when processors became fast enough that the memory access was becoming a bottleneck. 386 didn't have an internal cache, so there was only external, one level cache. 486 had an internal cache and could be built without cache on the motherboard (that was the idea behind), in practice most of the computers sold at the time had an external L2 cache on the mobo (although in some cases L2 cache was a fake). I guess that's what people refer to when they speak about L2 external cache. In general external L2 caches disappeared after the introduction of Pentium (on die L2).
http://en.wikipedia.org/wiki/L2_cache#In_x86_microprocessors
16K
11K
  • · Replies 17 ·
  • · Replies 19 ·
