Limits, geometric series, cauchy, proof HELP
The discussion revolves around a homework assignment related to geometric series, specifically focusing on the convergence of series using the Cauchy Convergence Criterion. The original poster presents several questions regarding the formulation of the n-th partial sum, conditions for convergence, and expressing a repeating decimal as a geometric series.
  • Mixed
  • The original poster attempts to clarify the formula for the n-th partial sum of a geometric series and questions the implications of summing from 0 to infinity.
  • Participants discuss the application of the Cauchy Convergence Criterion and express confusion about its definition and application.
  • Some participants suggest that the original poster needs to clarify the specific results they are expected to prove and the relevance of the repeating decimal in the context of the assignment.
  • There are inquiries about how to prove convergence and the proper use of the Cauchy criterion in relation to the problems presented.
The discussion is ongoing, with participants providing guidance on the need to establish a formula for the n-th partial sum and the importance of understanding the Cauchy criterion. There is a recognition that the original poster may need to focus on the definitions and initial steps before proceeding further.
Participants note that the assignment requires the use of the Cauchy criterion for proofs, and there is uncertainty about how the repeating decimal should be integrated into the various parts of the assignment. Some participants highlight that the first question may not directly involve convergence, which adds to the confusion.
  • #61
i do realize there's an N so it satisfies both of those properties, i just don't know how to eliminate the logs so N is an integer. I've never done an example this ridiculous... All of my examples worked out nicely, so it's clear we'd just make N an integer/epsilon. How do i eliminate the logs when finding my N? Is it simply 71/99E +anything?
and i do understand what makes it cauchy, we pick any positive epsilon, and pick any two values down the line of the sequence and say the difference between the two is whatever we want it to be...
  • #62
How do you find the N when you prove that 1/n→0? Let ε>0 be arbitrary. We want to prove that there's a natural number N such that for all integers n, n≥N implies |1/n-0|<ε. If we solve this for n, we get n>1/ε. But 1/ε isn't an integer either.
  • #63
...so what's that mean? huh?
Can you just tell me what part of the N i calculated above is wrong? And how i can make it right? ie remove the denominator, add 1 to it, etc??
  • #64
You're going to have to be much more specific about what a Cauchy sequence is when you start working on I (b). It seems to me that you're supposed to use the following:
Definition: A series is convergent if and only if its sequence of partial sums is convergent. If the sequence is convergent, its limit is called the sum of the series.
Theorem: A series with real terms is convergent if and only if its sequence of partial sums is a Cauchy sequence.
You need to use this theorem to prove that your series is convergent. So the first thing you should write down is exactly what it means for your sequence of partial sums to be a Cauchy sequence.
  • #65
You tell me. This is the simplest possible problem of the same sort that you need to solve. So you should probably put your problem aside for a while, and figure out the answer to this one first.
  • #66
Fredrik, I'm sorry but I'm not following you and i don't have any more time to work on this. I HAVE AN EXAM TOMORROW MORNING. I haven't even started studying for it yet because i keep running around aimlessly on this! I specifically posted on here to get HELP and I'm just getting more confused.
Can you PLEASE try to make things more clear to guide me step by step so i can do these problems? Right now i need to know why my N was wrong. Can you follow my work that i scanned above?
  • #67
why can't i make my N= [ln(71/99E) / ln(100)] +1
  • #68
I'm not going to break any forum rules because you have an exam tomorrow. I have given you much more information than you would have needed if you had done a few more exercises before you came here. And I have spent a lot of time giving you that information. So don't act like you haven't gotten any help. We have made significant progress, but we would have made more if you hadn't been so unwilling to write down definitions and answer questions.
I have done that for all parts except what you need to finish I(b), but since you haven't even followed my instructions on how to start I(b) yet, you have no need to for the rest of it yet.
What N are you talking about? The one where you say that N is equal to an inequality? That doesn't even make sense.
  • #69
Do the brackets mean something different than parentheses here?
  • #70
on the scanned sheet, ignore the inequality, so N= everything to the right of the inequality sign.
and you mean the floor function?
  • #71
can anybody tell me where my cauchy proof doesn't look right so i can fix it??
And how to i answer the "determine the conditions on a and r..." question?
  • #72
Yes, I was wondering if you meant that [x] denotes the integer part of x (i.e. the largest integer n such that n≤x). (I actually wasn't familiar with the term "floor function"). I highly recommend that you use that function here. How else would you make N an integer?
I'm not sure I understand what you're doing in post #54. You wrote down [itex]71\big(1/100\big)^n < \varepsilon[/itex]. But we started with [itex]\frac{71}{99}\big(\frac{1}{100}\big)^{n+1} <\varepsilon[/itex]. Is there a first step that you didn't write out, where you replaced 99 by 100? If so, I think you did it wrong. However, there's no need to make any simplifications like replace 99 by 100. Your N doesn't have to be pretty.
  • #73
What do you mean? You haven't even started yet. At least you haven't posted anything about it. Post #64 is telling you how to start.
  • #74
yeah that was an error... if you only knew how much crap i have scattered around me right now... so is this how i write the proof? if not, can you point out or fix the errors?
  • #75
The first inequality under the horizontal line is unnecessary but correct. The second is correct too when n≥N, but you don't seem to have considered these inequalities together. You're creating a string of inequalities that look like this ε > something < something < f(N). And then you appear to be solving f(N)>ε for N. But your string of inequalities did nothing to prove that f(N)>ε.
You have convinced me that you understand the general idea now (even though you still seem to have difficulties expressing it), so I will tell you a bit more. When you hand it in, you don't have to explain how you found your N. You just have to prove that your choice of N works, i.e. that it ensures that for all integers n such that n≥N, we have
[tex]\frac{71}{99} \left(\frac{1}{100}\right)^{n+1} <\varepsilon.[/tex] You will have to prove that even if you do explain how you found your N.
If you want to explain how to find N, then do it like this: We're looking for a natural number N such that the inequality above holds for all n≥N. If the inequality holds for all n≥N, it holds for n=N. So now you can just set n=N in the inequality and solve for N. You get a result of the form N>f(ε). This tells you that f(ε) is a lower bound on the set of acceptable choices. This obviously means that you can choose N to be any integer that's >f(ε). It's simple and convenient to choose the smallest one: N=[f(ε)]+1.
When you first solved for n in post #50, you found your f(ε) (the right-hand side of the last inequality). All you had to do after that was to choose N=[f(ε)]+1.
  • #76
but in post 50 i had 9900 as the denominator... should it be 9900 or 99?
  • #77
It's 99 if the exponent is n+1, 9900 if the exponent is n (as in post #50).
  • #78
ok, so how would the "string of inequalities" look when i enter in big N? In all of the examples I've done, the string ended with something like
if N=90/361E...
90/361n < 90/360N < 90/360(90/361E) = E
but in this problem I'm not getting the last thing to be =E
  • #79
I don't understand what you're doing there. As I said in #75, the best way to find N is to realize that the equality holds for n=N. So when you "solve for n", you're really solving for N. You can even set n=N in the inequality before you begin. And as I said earlier, there's no need to simplify anything. So you don't need a string of inequalities. You just need to set n=N in the inequality you started with and solve for N.
  • #80
and once i solve for N, how do i show that abs(Sn - thing it converges to) < E?
  • #81
Ah, I see. You do need a string of inequalities for that. I would use that n≥N as early as possible. You have already showed that |s_n-thing it converges to|=(71/99)(1/100)^{n+1}, and now you should immediately use that n≥N. Then you use your choice of N.
Edit: This might be slightly easier if you use base-10 logarithms when you solve for N. You will still have to use some stuff you know about logarithms to work it out to the end. (I just did, so I know it can be done).
  • #82
k, but if i pick my N as blah blah +1 i don't get a nice = E in the end. I get 1/100E. But if i just keep blah blah without the +1 it works out, like below:
  • #83
That's fine, because N=[x]+1 implies N≥x, and that's the inequality you actually use to evaluate (1/100)^n. [itex]n\geq N\geq x[/itex] implies
[tex]\frac{1}{100^n}\leq\frac{1}{100^N}\leq\frac{1}{100^x}[/tex]
  • #84
so my proof looks good? :D
  • #85
Yes. Only I(b) left now. Not sure I will stay up much longer though. I'm thinking about asking someone else to take over. Do you want to continue?
  • #86
if you can, yes please. I'm clueless.
  • #87
You will have to start with what I said in post #64. I'm going to bed, but I will make a post in the Science Advisor forum (hidden for normal users) asking if someone else can take over. I have already prepared some instructions for the person who takes over, including the solution to the problem. The good news is that the problem is much easier than I thought at first.
  • #88
oh thank you! It doesn't involve cauchy, right?
  • #89
It does. That's the only one of the problems that does involve Cauchy sequences or the Cauchy criterion. :smile: I have posted a request for someone to take over now. Not sure how long it will take for someone to show up. It's 4:40 AM in Europe, so a lot of people have already gone to bed.
  • #90
oh damn... yeah, i didn't use cauchy for that. I just did this. But I'm guessing i'll need cauchy.
Wow, you're in europe! That's awesome, where i am in the US it's 10:43pm!
If no one else chimes in, what should i do? Only because i need to get some sleep myself.. This assignment is due 6 hours from now, and that would be the minute before i have class.
Here's what i did already, which I am sure is wrong
