New Reply
VBA with Access and Excel Help
Share Thread Thread Tools
Dec20-11, 10:58 AM   #1
This is a VBA problem inside access involving an excel sheet.
I have an Access Table "sOrderTable" with [Unique ID], [Resource Group ID], [Priority] columns.
I am trying to Identify "Unique IDs" in Column A of the EXCEL SHEET and where they match [Unique ID] in the ACCESS TABLE matching and pasting[Resource Group ID] and [Priority] from ACCESS into columns AP and AQ in EXCEL.
The current error is 13 type mismatch on the row defining uID. I have tried labeling uID as String, Integer, Long and changing the range from A2:A to just A2
'Open Target File
Set xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
Set xlBook = xlApp.Workbooks.Open(sTargetCombine)
Set xlSheet = xlBook.Worksheets("Tracking")
'Select Data to copy paste and compare
Dim rID As Integer 'Resource ID
Dim pID As Integer 'Priority ID
Dim uID As String 'Unique Id
'Select First Column
xlSheet.Range("A1").Select
xlSheet.Range(Selection, Selection.End(xlDown)).Select
i = Selection.Rows.Count
For i = 2 To Rows.Count
uID = xlSheet.Range("A2:A" + Trim(Str(i))).Value
rID = DLookup("[Resource Group ID]", sOrderTable, "[Unique ID] =" & uID)
pID = DLookup("[Priority]", sOrderTable, "[Unique ID] =" & uID)
Next
xlSheet.Range("AP2" + Trim(Str(i))) = rID
xlSheet.Range("AQ2" + Trim(Str(i))) = pID
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
New Reply
Thread Tools
Similar Threads for: VBA with Access and Excel Help
Thread Forum Replies
Getting into a UK uni via an Access Course Academic Guidance 9
Fortran: help with I/O in Direct Access and Seq. access Programming & Comp Sci 0
Techniques for successfully importing Excel data into Access Computing & Technology 0
TechRepublic's Quick Reference: Microsoft Access Pak helps you understand Access features Computing & Technology 0
Access PF General Discussion 10
