How Does Mass Influence Friction in Physics Problems?
  • Thread starter Thread starter Vick007
    Mass Velocity
The discussion revolves around a physics problem involving a 1.00 kg disk sliding on a horizontal steel plate with an initial speed of 5.00 m/s. Participants explore how mass influences friction and the resulting motion of the disk, particularly focusing on the effects of friction in calculating stopping time and distance traveled.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the role of mass in equations related to motion and friction, questioning how to incorporate the coefficient of friction into their calculations. They explore the relationship between frictional force, mass, and acceleration, and how these factors relate to the initial velocity of the disk.
Some participants have provided guidance on using the coefficient of friction to determine the frictional force and subsequent acceleration. There is an ongoing exploration of the relationships between acceleration, velocity, and time, with participants attempting to derive equations to find the time it takes for the disk to stop and the distance it travels.
Participants note the importance of the coefficient of dynamic friction, which is given as 0.04, and the need to understand its application in the context of the problem. There is also mention of the need for kinematic equations to solve for distance traveled and time taken.
Vick007
With an initial speed of 5.00 m/s a 1.00 kg disk is slid on a horizontal steel plate. How long will it take for the disk to stop, and how far does it travel? ( do not neglect friction )
I don't know how to use the mass in any equations. help.
something with xo= vo + 1/2at^2 ?? how is the mass used?
The question appears to be incomplete. You need to know the coefficient of dynamic friction between the disk and steel plate in order to proceed. You'll use the coefficient of friction and the mass to determine the force that retards the motion, hence the acceleration.
ok so I checked and yeah the coefficient is given as 0.04 what do I do now? thanks
What is the relationship between the coefficient of friction and the frictional force?
weight X coefficient of friction = friction force?
how does that tie in with the velocity given?
Yes.
Draw the free body diagram for the disk. What forces are acting? What is the acceleration of the disk (hint: Newton's second law).
Ff= force of friction
U= coefficient of friction
Fn= force normal
m=mass
g=acceleration due to gravity =9.81
a= acceleration
d=distance
Ff=UxFn
which is the same as
m x a= U x m x -g
divide out the m and you get
a=U x -g
and so
a=.04 x -9.81
a= -.3924
so is it slowing down by .3924 m/s^2?
how do I link the velocity, time, and acceleration now?
Fn= force normal
m=mass
a= acceleration
d=distance
Ff=UxFn
m x a= U x m x -g
a=U x -g
and so
a=.04 x -9.81
a= -.3924
What's the relationship between acceleration and velocity? How about if there's an initial velocity?
the initial velocity is 5.00 m/s and since the acceleration is (I think) -.3924 and I'm looking for the time would this equation work?
a = (V2 - V1)/T
where
(V2 - V1) = change in velocity
so it would say
-.3924 = (V2 - 5.00)/T
but what is V2? or how do I find it?
a = (V2 - V1)/T
That will work. It's a rearrangement of the usual equation, v2 = v1 + a*t .
where
so it would say
What is the speed of the puck when it stops?
so V2 = 0
and now I just have to find T
so according to your equation it would look like this:
v2 = v1 + a*t
and if I fill it in I get
0 = 5.00 + (-.3924) * t
-5 = -.3924 * t
(-5/-.3924) = t
t = 12.42 sec (is that correct?)
thanks a lot for helping, but there's a second part to the problem
how do I begin the second part now that I have the time? Is there some equation?
Vick007 said:
so V2 = 0
v2 = v1 + a*t
-5 = -.3924 * t
(-5/-.3924) = t
Probably a typo, t = 12.74 should be your value.
I'm rather surprised that you don't seem to have had any introduction to the basic kinematic formulas. Yes there is an equation (there's always an equation :smile ). In this case you want one that relates distance traveled to initial velocity, acceleration, and time. Any ideas as to which of the standard kinematic equations might fit?
would it be one like this?
X - Xo = .5(Vo + V)t
which could be simplified to
X = .5(5+V)(12.74)
how do I find the velocity though?
X = .5(5+V)(12.74)
That equation will work. It incorporates the initial velocity (Vo) and the final velocity (V = 0) in order to take care of the acceleration. Remember that you previously wrote: a = (V2 - V1)/T.
So plug in your V=0 and find distance X.
Another equation that you should become familiar with is:
[itex]d = v_o t + \frac{1}{2} a t^2[/itex]
See the Physics Formulary
ok so I got like
X = 31.86 meters?
is that correct?
Vick007 said:
ok so I got like
X = 31.86 meters?
is that correct?
Yes, that is correct.
22K
  • · Replies 34 ·
