Finding volume using integration
The discussion centers on calculating the volume of a solid formed by rotating the area between the curves defined by the equations x=y² and x=1 about the line x=1. The correct volume formula is pi*(1-y²)², which differs from the incorrect formula pi-pi*y⁴ proposed by the user. The discrepancy arises from misunderstanding the method of rotation; the appropriate method for this problem is the disk method, which involves integrating the area of circular disks perpendicular to the axis of rotation.
  • Understanding of integration techniques in calculus
  • Familiarity with the disk method for volume calculation
  • Knowledge of the equations of curves and their graphical representation
  • Ability to set up and evaluate definite integrals
  • Study the disk method for calculating volumes of solids of revolution
  • Learn how to derive volume formulas from the area between curves
  • Practice problems involving rotation about vertical lines
  • Explore the shell method as an alternative for volume calculations
Students studying calculus, particularly those focusing on volume calculations of solids of revolution, as well as educators seeking to clarify integration techniques.
theBEAST
Given x=y^2, x=1 what is the area of the solid when the area between the two curves is rotated about x=1.
I attached my solution and according to the answer key my area formula (pi-pi*y^4) is wrong. Instead they have pi*(1-y^2)^2. Can anyone explain why my area formula is wrong? I thought that it was the area of the upper boundary curve minus the area of the lower boundary curve...
What method are you trying to use? Is it disks? ... or is it shells?
