New Reply
How come the ocean hasn't been absorbed into the ground?
Share Thread Thread Tools
Dec31-11, 02:23 PM   #1
I've tried researching this question and I couldn't find a satisfying answer. How come the water on Earth hasn't been absorbed by the ground over billions of years? The Earth's water evaporate but get's replenished when it comes back down as precipitation. Is there a similar process that occurs underground? Is it buoyancy issue? If the water does slowly get absorbed does it come back up somehow?
PhysOrg.com
PhysOrg
earth sciences news on PhysOrg.com
>> Alaska volcano shoots ash 15,000 feet into the air
>> NASA sees Cyclone Mahasen hit Bangladesh
>> Satellite sees Tropical Storm Alvin's life end quickly
Dec31-11, 02:33 PM   #2
Quote by Flatland View Post
Many reasons, but a big one would relate to permeability. There are layers of clay, rock, etc, which prevent the water from going down beyond a certain depth in certain locations.
Water which does percolate down tends to flow along underground rivers and things like that, and back to visible bodies of water.
Dec31-11, 02:46 PM   #3
Don't cracks and fissures form regularly that would allow water to seep down to deeper levels? From what I understand there can be lots of moisture even deep underground so evidently water can get there somehow.
Dec31-11, 04:30 PM   #4
Perhaps there is too much of it?
Any given body of ground can only hold just so much water before it becomes saturated. The 'water table' (or phreatic surface if you want the posh term) is an underground surface below which the rocks are saturated.
Dec31-11, 05:21 PM   #5
D H
Mentor
In a sense it is. Wet sediments are deposited on the ocean floor and water does seep into the oceanic crust. However, this oceanic crust is fairly short lived, 200 million years or less. The oceanic crust arises at mid-ocean ridges and subsides back into the Earth at subduction zones. Those wet sea-floor sediments and saturated oceanic crust lose their water as the material subsides into the Earth. That migrating water comes back to the surface in the form of steam. The volcanoes near those subduction zones can sometimes be quite explosive because of the large amounts of steam they produce.
Edit
See Ranero et al., Bending-related faulting and mantle serpentinization at the Middle America trench, Nature 425, 367-373 (25 September 2003)
doi:10.1038/nature01961
Jan30-12, 07:54 AM   #6
Remember the water body is larger than the land itself if this could happend the whole world will be in a sticky mess of water
Jan30-12, 08:27 AM   #7
D H
Mentor
Quote by Amiri Daudi View Post
The other way around. The original post by Flatland essentially asked why the Earth has oceans at all: Why isn't the Earth all dry land? After all, rainfall does soak into the ground and even into the bedrock to form aquifers. So what stops all of the surface water from soaking into the ground? Why do we have oceans?
The answer is that this does happen. The ocean's waters do indeed seep into the mud and crustal material that underlies the ocean. What the OP missed is that the ocean crust is young and is constantly being recycled. Volcanos at the subduction zones spew out immense amounts of water expelled from saturated ocean crust as it dives into the Earth due to subduction. The Earth is more or less in a steady state between water lost due to seepage and water added due to volcanos. It is plate tectonics that maintains this steady state.
Mar13-12, 02:31 AM   #8
Almost all crustal rocks have some amount of porosity (i.e. the volume fraction of the entire rock that is not composed of solid minerals, like holes in swiss cheese) either through the natural packing configuration of grains or fractures on crystalline rock. All the porosity in these rocks is completely filled with water (except for the rare occurrences of hydrocarbons, CO2, etc), from the surface to large depths where the water is absorbed by the surrounding minerals through chemical reactions forming new hydrous minerals precipitated in the place of the porosity. So there is a depth at which no more porosity exists and water cannot keep going down.
Then, as others explained, through crustal recycling, the hydrous minerals are exposed to incredibly high temperatures when they make contact with the mantle. This generates a melt that includes water in the form of bubbles. In fact, the presence of water drops the melting point of the entire rock allowing this to happen at relatively shallow depths. Then that melt makes its way up through more crustal rock, taking in all the water in its path, and releasing everything at the surface in the form of a volcano. Also, water surrounding the path of the melt may also be heated and its pressure raised such that it ejects at the surface through fractures in what we call geysers.
Mar16-12, 02:18 PM   #9
Other Sciences 2012
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
It does penetrate the crust. It's penetration defines the Mohorovicic discontinuity.
Apr1-12, 03:38 PM   #10
Recognitions:
Surely the main reason why most of the water stays on the surface is that it is a lot less dense than most other materials. Any large voids underground may get water in them but they will eventually fill up with small rocks / sand /mud which will displace the water upwards.
The natural place for water is on or near the surface because it just floats up there.
Apr2-12, 06:51 AM   #11
Quote by Tea Jay View Post
A common misconception. "Underground rivers" are rare and only occur in karstic systems, basically limestones and chalk. Groundwater typically flows through pore space and the occasional fracture in the rock.
Quote by D H View Post
I think the important point with water in subduction zones is that water greatly reduces the melting temperature of rock. Therefore wherever and whenever there is water in the system there is much more likely to be melt. Melt (full of hydrous volatiles) travels upward s back to the surface, and indeed water is released by volcanoes. Although careful, the majority of steam (water) is likely inherited from ground around the volcano, not necessarily the rising magma. Incidentally there is believed to be a vast amount of water in the Earth's mantle.
Quote by chemisttree View Post
Umm. what? I don't think so.
Apr5-12, 07:35 AM   #12
I second billiard's surprise at this comment. Please provide appropriate citations to justify this seemingly bizzare claim.
The Moho, taken as the boundary between crust and mantle, is defined by a large change in seismic velocity. This is traditioanlly ascribed, broadly, to a change from mafic to ultramafic rocks with corresponding mineralogical differences. I am unaware of any research that attributes these fundamental differences to water content. I would be fascinated to learn that such was the case and to understand how this functions as the primary mechanism defining the discontinuity.
Apr11-12, 01:07 AM   #13
Other Sciences 2012
Recognitions:
Quote by Ophiolite View Post
Be fascinated.
Apr11-12, 03:39 AM   #14
Recognitions:
As no one seems to have taken up my simple argument based on density, would someone 'who knows' tell me what sort of proportion of the Earth's water content is actually contained in the Oceans, compared with the amount that's underground? The actual (estimated) quantities involved would be nice to know if we want a good picture of what's actually going on. I realise that the total volume of the Oceans is really small, compared with the whole volume of the Crust.
Apr11-12, 07:02 AM   #15
I assume you are referring specifically to the line in reference to the Moho.
'...but it may be an alteration front corresponding locally to the depth of circulation of seawater down fractures and faults into the Earth's interior.'
This MAY be true, but note it is talking about LOCAL phenomena within a MODEL of ocean crust. This in no way is equivalent to the inference that water cannot penetrate into the mantle anywhere at all.
Indeed on the very same page as you linked to we find in relation to the development of textures in serpentinized peridotites a sentence which states:
'Progressive serpentinization and hydrothermal alteration from greenschist to zeolite facies were spatially and temporally related to the development of multiple generations of macroscopic veins and were associate with the penetration of seawater-dominated fluids into the upper mantle rocks.'
It seems that water can and does penetrate into the mantle, and believe me, there is a lot of work on the Earth's deep water cycle to back that statement up.
Apr13-12, 03:18 AM   #16
Other Sciences 2012
Recognitions:
Quote by billiards View Post
Right. I don't believe I inferred that at all.
Of course on the same page it states that where extensive faulting occurs that serpentinization continues into the upper mantle and that the boundary of serpentine and unaltered rock defines the MOHO... within the upper reaches of the mantle!
Apr13-12, 05:12 AM   #17
Recognitions:
Forgive me but is this concentration on the qualitative rather than the quantitative typical of Geological discussion? I should have thought the the quantities involved would be much more important to you guys than this discussion would sugest. I, personally, would welcome some enlightenment as to how much actual data exists about the quantity of water you are discussing.
Are the Oceans the equivalent to the condensation on the ceiling of a swimming baths or the contents of the pool itself?
New Reply
Thread Tools
