Laplace equation in 2d problem, Dirichlet problem
The discussion revolves around solving the Dirichlet problem for the Laplace equation in two dimensions, specifically within a circular domain defined by polar coordinates. The boundary conditions involve various functions of the angle φ and constants A and B, prompting exploration of potential solutions.
  • Participants discuss the use of separation of variables and the resulting ordinary differential equations (ODEs) derived from the Laplace equation. There are inquiries about the implications of complex solutions and the physical meaning of different forms of solutions, including logarithmic terms.
Several participants have provided insights into the nature of the solutions, particularly regarding the periodic boundary conditions and the significance of separating cases for different values of k. There is ongoing exploration of how to handle specific boundary conditions and the implications for the solution's physical validity.
Participants note the importance of considering the physical context of the problem, especially regarding the behavior of solutions as r approaches 0 and the implications of periodicity in φ. There is also mention of homework constraints that may influence the approach to the problem.
fluidistic
Consider a circle of radius a whose center is in (0,0). Let [itex](r, \phi)[/itex] be the polar coordinates and (x,y) the corresponding rectangular coordinates of the plane. Calculate the solution to Dirichlet problem (interior) for Laplace equation [itex]\nabla ^2 u =0[/itex] with the following boundary conditions:
1)[itex]u(r=a)=A[/itex]
2)[itex]u(r=a)=A \cos \phi[/itex]
3)[itex]u(r=a)=A+By[/itex]
4)[itex]u(r=a)=Axy[/itex]
5)[itex]u(r=a)=A+B \sin \phi[/itex]
6)[itex]u(r=a)=A \sin ^2 \phi +B \cos ^2 \phi[/itex]
where A and B are constants.
Already given I think.
So I've been checking out internet to confirm my result so far but I've a few questions.
I wrote the Laplacian in polar coordinates [itex]\triangle u = \frac{u_r}{r}+u_{rr}+\frac{u_{\phi \phi}}{r^2}=0[/itex].
I use separation of variables, proposing a solution of the form [itex]u(r, \theta )= \varphi (\phi )R(r)[/itex].
Plugging this back into the Laplace equation I reached 2 ODE's.
[itex]r^2 R''+rR'-k^2R=0[/itex] and [itex]\varphi '' +k^2 \varphi =0[/itex].
The second ODE is easy to me to solve, I reached [itex]\varphi (\phi )=c_1e^{ik \phi }+c_2e^{-i k \phi}[/itex]. However on the Internet they prefer to keep all real values if I understood well, though I don't know how it's possible to do this.
I kind of cheated to solve the first ODE and one solution (I checked out and it indeed is a solution) is of the form [itex]R(r)=c_3 r^k+c_4 r^{-k}[/itex]. Now for R(r) remains finite when r tends to 0, [itex]c_4[/itex] must vanish so that [itex]R(r)=c_3r^k[/itex].
So my solution so far is [itex]u(r, \phi )=c_3 r^k(c_1e^{ik \phi }+c_2e^{-i k \phi} )[/itex].
I've also found out that it's possible to get another form of solution for the first ODE, namely [itex]R(r)=c_5+c_6\ln r[/itex] which would really complicate the number of possible solutions to the PDE. I don't understand what it means physically to have 2 different possible solutions.
Also, how do I deal with the solution that contains complex numbers?
The log solution is possible when [tex]k=0[/tex]. There's nothing mysterious about it.
Write the complex exponentials in terms of sin and cos.
Regarding the solution only containing real values for phi. Think about the physical nature of the system you're solving. Since your solution exists on a disk what can you say about the boundary conditions on phi?
Ok thanks to both.
I reach [itex]u(r, \phi )=c_3 r^k [A \cos (k\phi ) + B \sin (k \phi ) ][/itex].
To answer CN's question, I don't know what you mean by "boundary conditions on phi". Do you mean that [itex]u(a,0)=u(a, 2 \pi )[/itex]?
k is worth [itex]\pm \sqrt {\frac{R'-r^2R''}{R}}[/itex].
Edit: I can even write [itex]u(r, \phi )=r^k[A \cos (k \phi )+B \sin (k \phi )][/itex]. But this solution doesn't look good to me, indeed [itex]u(0 ,\phi )=0[/itex] no matter what the boundary conditions are. This means that if I heat the boundaries of the disk, the center will always be at 0K unless I'm mistaken (when the temperature reaches a steady state).
Yes, that is what I meant for the BC's on phi. With periodic Boundary Conditions on phi we can write:
For k = 0
[tex] \varphi_{0} = \frac{1}{2}A_{0}[/tex]
and
[tex] R_{0} = D_{0}ln(r) + C_{0} [/tex]
Otherwise
[tex] \varphi_{k}(\phi) = A_{k}cos(k\phi) + B_{k}sin(k\phi)[/tex]
and
[tex]R_{k}(r) = C_{k}r^{k} + D_{k}r^{-k}[/tex]You have to be careful here though to ensure your solution is bounded. Think about the physical nature of your solution.
Edit - I notice above you are already almost at the final solution. You need to also consider the condition for k = 0 and include that in the final form of your solution.
Ok thank you.
For k = 0
Hmm why this particular value? I mean why not [itex]A_0[/itex]?
and
I trust you but this function isn't definied for r=0. I don't understand why such a function is possible physically.
Otherwise
and
Ok. Your [itex]D_k[/itex] coefficient must equal 0 otherwise the function isn't bounded when r tends to 0.
fluidistic said:
Ok thank you.
Eh, it's just a matter of convention, I believe it comes from solving for the coefficients of the Fourier sine/cos series. ultimately it doesn't matter.
It isnt, but the math initially requires it, your intuition tells you that you can't have this function, i.e. set the coefficient to 0. This will generally always be the case, which is why its so important to think physically about your solution instead of just assuming that because the math is right then the solution is right.
I think you're ready to piece it all together and determine your final solutions for each initial condition
Ah ok I understand.
However if [itex]u(r, \phi )=r^k [A_k \cos (k \phi )+B_k \sin (k \phi ) ][/itex], I don't see why I have to separate the special case of [itex]k=0[/itex] since if I plug [itex]k=0[/itex] into this, I get exactly what I should, i.e. [itex]A_0[/itex].
So I used the fact that the angular part of the solution is periodic and I reached that [itex]A_k=B_k[/itex]. (I will show my work if this is wrong). Thus [itex]u(r, \phi )=r^k A_k [\cos (k \phi )+ \sin (k \phi ) ][/itex].
Applying boundary condition, I reach [itex]A_k=\frac{A}{a^k [\cos (k \phi )+ \sin (k \phi) ]}[/itex].
This gives as final answer (looks too simple in my opinion): [itex]u(r, \phi )=\frac{r^kA}{a^k}[/itex]. There's no dependence on phi which looks good. Also the boundary condition is/are satisfied.
What do you think?
You should always evaluate the separate cases for k<0, k=0 and k>0 from the start point of the differential equation. This is because as evident with the DE for R it won't be the same thing. For k>0 R(r) ends up being a function of r^k and r^-k. but for k=0 the DE yields ln(r). While this solution isn't physically valid it demonstrates my point that just plugging in k=0 for a solution given for k>0 won't always yield the correct solution, however in this case it does for your phi solution.
Edit - k is an integer > 0 so the periodic boundary conditions just tell you that A = A, so you can't be setting A = B. e.g.
phi(0) = A
phi(2pi) = Acos(2pi k) + Bsin(2pi k)
phi(0) = phi(2pi) is true if k is an integer. The sin term will disappear and you're left with A = A
Your final solution should be
[tex] u(r,\phi) = A_{0} + C_{0} + \sum_{k = 1}^{\infty} r^{k}(A_{k}cos(k\phi) + B_{k}sin(k\phi))[/tex]
Now I would just use observation to determine your solution for each 1 through 6, for example:
1) [itex]u(r=a) = A[/itex]
It's easy to see that the following is true
[tex] A_{0} = A[/tex]
[tex] C_{0} = 0[/tex]
[tex] A_{k} = 0\ \forall\ k > 0[/tex]
[tex] B_{k} = 0\ \forall\ k > 0[/tex]
phi(0) = A
Thank you very much for all this useful information, I indeed made an error and can't get [itex]A_k=B_k[/itex].
However I do not know why k is an integer >0 nor how to get the final answer. I'm stuck at [itex]u(r, \phi )=r^k [A_k \cos (k\phi )+B_k \sin (k\phi )][/itex].
k is an integer because of what you need from the boundary condition [itex]\varphi(0) = \varphi(2\pi)[/itex]
We have then:
[tex]\varphi(0) = A_{k} = A_{k}cos(2\pi k) + B_{k}sin(2\pi k) = \varphi(2pi)[/tex]
So we need the following to be true:
[tex]A_{k} = A_{k}cos(2\pi k) + B_{k}sin(2\pi k)[/tex]
After taking a course in PDE's it just comes naturally to me that we should make the cos term = 1 and everything else will fall out. So if k is an integer then it should be evident that we are just left with [itex]A_{k}[/itex]
If it isn't evident then plug in k = 1,2,3... and you'll see.
Now, for your final answer you need to take the summation over all k values, including k = 0.
so we have the solution for k = 0: A + C,
and k = 1, A_1 cos(phi) + B_1 sin(phi)
and k = 2... etc etc
so ultimately we have:
[tex]u(r,\phi) = \frac{1}{2}A_{0} + \sum_{k = 1}^{\infty} r^{k}(A_{k}cos(k\phi) + B_{k}sin(k\phi))[/tex]
This time I just combined the first two k = 0 constants, it really doesn't matter because a constant plus a constant is a constant, I don't know why I didn't do it the first time.
Thank you very much for your time and useful information Clever Name.
This is starting to click a bit in my head now.
I understood all your steps, except the idea that if I have a solution say for k=2 and for k=50, the sum of these solutions is also a solution. I know this is true for linear ODE's (and probably PDE's), but this one isn't linear as far as I know. So why is this true, I do not know. I'd appreciate if you have a few words to say about this.
I expressed the solution as [itex]u(r, \phi )= \sum _{k=0}^{\infty } r^k [A_k \cos (k\phi )+B_k \sin (k\phi )][/itex] which I think is equivalent to yours.
Ok for 1). The solution looks good. If I heat the contours of a disk with a uniform temperature and I wait an infinite amount of time (time required for steady state temperature), the disk will have a uniform temperature, the one I use to heat it up/cool it down, A.
I'm going to try the other i)'s.
Edit: For 2): [itex]A_k=B_k=0[/itex] for [itex]k \neq 1[/itex]. [itex]B_1=0[/itex]. [itex]A_1=A/a[/itex].
Thus [itex]u(r, \phi ) =\frac{rA \cos \phi }{a}[/itex].
Edit 2: Hmm not sure this makes sense physically, probably made an error. Oh I see your new post now.
Surprisingly yes, your form of the solution is equivalent, though I would stress caution in doing something like that. The k=0 solution will not always be present, and sometimes having the k=0 solution outside of the sum will make it easier to see (by simple observation) what the final solution will be when given initial conditions. Also, the k=0 solution might end up being something like [itex]A_{0} + B_{0}t[/itex]. Which would not fall under the sum. So again, just be careful when doing that.
As for why it's true that you can do the sum. Laplace's equation is linear. http://mathworld.wolfram.com/LaplacesEquation.html Thus the solutions obey the principle of superposition.
Ok thanks once again.
For 2), I edited my last post.
For 3):
[itex]A_0=A[/itex]. [itex]A_k=0 \forall k \neq 0[/itex].
[itex]B_k =0 \forall k \neq 1[/itex]. [itex]B_1=B/a[/itex]. Thus [itex]u(r, \phi )=A_0+ \frac{rB \sin (\phi )}{a}[/itex].
So far so good?
Edit: I'm having a hard time with the 3 last boundary conditions. Inspection doesn't work for me, is there any other way I can get [itex]u(r, \phi )[/itex] for those cases?
For 3, [/itex] for\ r=a,\ y = asin(\phi) [/itex], thus [itex]u(r=a) = A + Basin(\phi)[/itex]
So [itex]B_{1} = B[/itex] gives the right answer, because with what we have now:
[tex]u_{0} = A[/tex]
[tex]u_{1} = a^{1}B_{1}sin(\phi) = aBsin(\phi)[/tex]
Thus all together we have [itex]u(r=a) = A + Basin{\phi} = A + By[/itex]
Or [itex]u(r,\phi) = A_{0} + rBsin(\phi)[/itex]
At least that's how I'm interpreting the I.C.
For the other cases you'll need to do some trig substitutions. I.e. for 4) we have:
[tex]u(r=a) = Axy = Aa^{2}cos(\phi)sin(\phi)[/tex]
Using the sine double angle identity this give sus:
[tex]u(r=a) = \frac{Aa^{2}sin(2\phi)}{2}[/tex]
The solution should be evident now, you just need [itex]B_{2} = A[/itex] which is no big deal.
For problems like this since you haven't come across the actual method for solving the Fourier sine or cosine series I would strongly suggest you keep to the method of inspection. Going the other route might make it more complicated than it needs to be. Wait until you come across it in your studies.
5 Doesn't look too hard.
6) use the identities [tex]sin^{2}(u) = \frac{1}{2}( 1-cos(2u))[/tex] and the respective one for cos^2.
Okay. I get:
4)[itex]B_2=\frac{A}{2}[/itex] so [itex]u(r, \phi )=B_2 r^2 \sin (2 \phi )[/itex]. All other coefficients are null.
5)[itex]u(r, \phi )=A_0+r B_1 \sin \phi[/itex] with [itex]A_0=A[/itex] and [itex]B_1=B/a[/itex].
6)[itex]u(r, \phi )=A_0+A_2 r^2 \cos (2\phi )[/itex]. With [itex]A_0=\frac{A+B}{2}[/itex] and [itex]A_2=\frac{B-A}{2a^2}[/itex].
I'm going to dig into Fourier series stuff. I'm self studying this course and the final exam is around mid February, I want to be really ready. I am in holidays till early March so I have time to study hard this course. :)
I don't have the means to work it out right now (sitting on a train), but at first glance it looks fine.
Good luck!
Thanks for all and have a nice trip!
