How is it possible that 3d orbitals are more contracted than 4f?
  • Context: Graduate
  • Thread starter Thread starter Chemist20
    3d Orbitals
The discussion revolves around the energy and contraction of 3d and 4f orbitals, exploring the factors that influence their relative energies and shapes. Participants examine quantum numbers, relativistic effects, and the implications of orbital characteristics in the context of atomic structure.
  • One participant suggests that the energy of an orbital is influenced by its quantum numbers n and l, proposing that more contracted orbitals should have lower energy.
  • Another participant clarifies that the comparison of orbitals must consider both n and l values, indicating that changing l complicates the characterization of orbitals solely by size.
  • A different participant asserts that 4f orbitals are indeed more contracted than 3d orbitals, expressing confusion over this observation.
  • Some participants mention relativistic effects as a potential explanation for the energy differences between orbitals, referencing concepts like spin-orbit coupling and the fine structure of hydrogen.
Participants express differing views on the contraction and energy levels of 3d and 4f orbitals, with no consensus reached on the reasons behind these differences. The discussion includes competing explanations and acknowledges the complexity of the topic.
Participants note that the understanding of orbital energies may depend on relativistic effects and the specific characteristics of the orbitals involved, which are not fully resolved in the discussion.
Chemist20
just thinking... the energy of an orbital depends on:
a)quantum number n
b)quantum number l.
an orbital will be of less energy when it's more contracted. So technically, 3d should have a lower energy than 4f and hence be contracted. BUT IT'S THE OTHER WAY AROUND!
help?
thank you!
I think you mean the 4s, not 4f, correct? Your reasoning works if you compare orbitals that are similar except for their n value, so if they have the same l value then the n will control how contracted they are and what their energy is. But when you also change the l value, you can no longer characterize the orbital by just its "size", there's also an issue about its "shape". It turns out that s orbitals have a probability of the electron being extremely close to the nucleus, so s orbitals have significantly lower energies then the other l states. As n rises, the energy differences between different n states becomes less than this dip in the s states.
Nope! I actually mean the 4f. the 4f are more contracted than 3d. And I don't see why! ;)
If I remember correctly (and I'm vaguely remember something I read in an inorganic chemistry textbook several years ago), it has something to with relativistic effects.
I try to find the actual reference rather than just waving my hands.
You are right. The Hydrogen spectrum would be entirely dependent on n if relativistic effects are not taken into account.
Relativistic effects in the momentum-energy relation, the spin-orbit coupling, and the so called "Darwin term" account for the l (L, not I lol) dependence of the energy spectra of Hydrogen. The sum of these effects are usually called the "fine structure" of Hydrogen. They are called "fine structure" because these effects are alpha (~1/137) suppressed in comparison to non-relativistic effects (alpha being the fine structure constant). But, as Ken says, at the higher n's, the regular energy levels of Hydrogen get very close together, and these fine structure effects can become factors in which states have higher energy, etc.
  • · Replies 18 ·
