Register to reply
Isotropic surfaces questions...
by Dr Bwts
Tags: isotropic surfaces
Share this thread:
Dr Bwts
#1
Jan25-12, 08:48 AM
P: 18
Hi,
I have the following definition for an isotropic surface: the normals to the measured surface are randomly distributed.
Am I right in thinking the following:
1) The surface of a sphere is isotropic?
2) The surface of a cube is anisotropic?
I think (2) is correct but not sure about (1) well to be honest I not that sure about (2) either!
Thanks to anybody who can put me straight.
Dr B
Phys.Org News Partner Science news on Phys.org
FIXD tells car drivers via smartphone what is wrong
Team pioneers strategy for creating new materials
Team defines new biodiversity metric
chiro
#2
Jan25-12, 09:52 AM
P: 4,573
Quote Quote by Dr Bwts View Post
Hi,
Dr B
Hey Dr Bwts and welcome to the forums.
When you say randomly distributed are you talking about a uniform distribution?
Dr Bwts
#3
Jan25-12, 10:08 AM
P: 18
Hi Chiro,
I dont rightly know. I am reading some papers on morphology and it was one of the easier to understand definitions of an isotropic surface.
Would the angular distribution of exterior surface normals be uniform for a sphere?
chiro
#4
Jan25-12, 10:13 AM
P: 4,573
Hi Chiro,
Well usually when we something is 'purely random' that it is uniformly distributed since every possible outcome is as likely as everything else. In an information theoretic context, uniform distributions maximize entropy and if entropy is large, that means that its 'hard to compress' information about a specific set of data.
For the sphere, I would imagine that it is indeed isotropic. The way you could start to prove this is by showing that all normal vectors have the same rate of occurence as every other normal vector (in fact this is the general method you would use). By showing this you would have provide isotropy if the distribution is indeed uniform.
Dr Bwts
#5
Jan25-12, 10:19 AM
P: 18
Thanks for the reply.
So just so I'm clear, in the case of the cube I would get a distribution that would be orthotropic?
chiro
#6
Jan25-12, 10:24 AM
P: 4,573
I don't know what means in terms of specifics (type of distribution and what normal vectors are included/allowed). Could you link me or tell me what orthotropic refers to?
Dr Bwts
#7
Jan25-12, 10:29 AM
P: 18
Orthotropic - multually perpendicular planes of symmetry (a particular case of anisotropy)
chiro
#8
Jan25-12, 11:36 PM
P: 4,573
That sounds right but I would just make sure what the definition is.
For a cube if the normals for the edges of the cube are the same as one of the other normals in the set, then that seems to be ok.
Also I think you should clarify the specific nature of a 'random' set. My interpretation is that it includes every possible normal possible within a specific geometry: in this case 3D space corresponds to every unit vector in cartesian 3D space.
For the cube you should also get a uniform distribution but the number of unit normal vectors is countable unlike your sphere example. If we allow that we have any uniform distribution then this would not be anisotropic but if we specified that is to include all possibilities within some certain space, then it would still be anistropic even though each possible unit normal in the cube case is still as likely as the others.
Dr Bwts
#9
Jan26-12, 04:24 AM
P: 18
OK thanks chiron that has been very helpful
Register to reply
Related Discussions
Minimal surfaces questions Calculus & Beyond Homework 2
Local and isotropic the same? General Physics 3
Is Plexiglas Isotropic Materials & Chemical Engineering 0
Isotropic Tensors Advanced Physics Homework 14
Questions about forces on surfaces Introductory Physics Homework 2
